Question about Westinghouse Refrigerators
Hi i have a Westinghouse side by side fridge freezer WSE6970SA and there is no water coming out of the dispenser i have replaced the water solenoid at the back where the water comes in ?? any idea
  • johnny rebel Apr 19, 2017
    check that the switch is getting electricity
  • Meredith N Dale Mccabe
    Meredith N Dale Mccabe Apr 19, 2017
    I have water to the connection at the bottom of the door how do you remove the water dispenser from the door ?
    Master:
  • 604 Answers
Turn the water back on
Posted on Apr 19, 2017
Testimonial: "IT is"
Hi i have a Westinghouse side by side fridge freezer WSE6970SA there is no water at the dispenser . how do you remove the front panel from the water dispenser to remove it ?
https://www.bing.com/videos/search?q=replacing+water+switch+on+westinghouse+fridge+door&qpvt=replacing+water+switch+on+estinghouse+fridge+door&FORM=VDRE
Apr 19, 2017 | Westinghouse Refrigerators
I have a Westinghouse side by side refridgerater with water and ice dispenser. The other day I arrived home to find water pouring through the back of the freezer section into the ice maker,and into ice...
Your water control has two sides. One side is for the ice maker and other is the water disapenser. If the ice maker valve becomes mechanically defective the water valve can allow water to continue to flow or not flow at all. Replace the water control valve and I believe this will solve this porblem, Thanks Sea Breeze
Dec 11, 2012 | Whirlpool 25.6 cu. ft. Side-by-Side...
I have a Hotpoint HSS25GFTA WW Fridge that has side by side doors with ice/water dispenser in the freezer (L) door. I still get ice fine but my water dispenser has 'died'. The water has always come out tap...
Hello:
It is very common to have the line in the freezer door freeze up. I would start there first. If that's not it then next step would be your water valve which is located in the back/bottom of the fridge. It is a dual valve( one side for ice maker the other for water dispenser). you can check that by taking off the front kick plate and on the bottom freezer door hinge you will see the line entering the door. Follow it towards the under the fridge and you will find a coupling. Disconnect it and see if there is any water coming out when you press actuator on the door .. If yes then its frozen if no your valve is Kaput.
Cheers
Jun 10, 2017 | Hotpoint HSS25GFP Side by Side...
Ge fridge- water dispenser in door wont work yet ice maker does.
There are a few reasons for this. Most common, is the water filter. After a period of time(literage usage) the filter eventually blocks up.Flow will not continue until a new one is installed. On occasion, the water line in the freezer ices up, but doesn't often happen. If so, you will need to defrost freezer until pipe is no longer iced up(set freezer to about -20 degrees celsius).or very possible, water solenoid at the back of the fridge has gone faulty.You will need help with this check,There will be 2 valves. Very possibly it will be the RHS one at the back. Switch water supply off at the back then go to the water solenoids at the back of the fridge.and disconnect the one pipe on the solenoid that leads into the fridge. Open fridge water tap again and ask member to quickly press water dispenser lever.Note if water squirts out for that brief period.. If not, reconnect pipe again then do the same disconnection to the second solenoid. If no water comes out then,(make sure water is open), then the water valve needs to be replaced.
Oct 04, 2009 | GE Refrigerators
Water and ice won't work on kenmore side by side fridge
I just resolved an issue with my kenmore elite side by side refrigerator icemaker (model 106).
It was expensive because I took the long road to fixing the unit myself.
My problem: No water going up to the freezer water dispenser into the icemaker but the water in front of the door working just fine.
-first thing i tried was the simplest. The Internet is clogged with this miracle fix of using a hair dryer to melt the frozen water line going to the dispenser output. This is highly unlikely for our model since the water line is protected within the refrigerator frame.
-2nd thing I replaced my water filter (thinking that there wasn't enough water pressure to trigger the solenoid valve. $40, and still no luck.
-3rd thing was I tested for voltage going to the solenoid. No voltage going to solenoid, so I wasted $30 for a new solenoid.....still no water.
-4th thing was I ordered a new IR sensor and receiver (since the reciever end is where the relay that sends the voltage to the solenoid to turn on and allow water to go up to the dispenser).
My IR sender and receiver appeared to be working flakey.
Installed, still no water. $58 BUCKS ON EBAY (EVERYWHERE ELSE $100+)
-I finally removed the freezer front little white door, I TURNED OFF THE FREEZER SWITCH SO NO VOLTAGE WAS PRESENT, removed the release latch underneath the freezer unit and disconnected, and removed the freezer unit to inspect it further.
When I removed the protective white cover that covers the mechanical wheel, I had a few parts come flying out of it. Turns out that the wheel accessories were damaged. THERE ARE NO REPAIRABLE PARTS ON THE FREEZER UNIT. I FOUND ONE ON EBAY FOR $39 BUCKS + $9 SHIPPING! $48 BUCKS, SWAPPED THE HARNESS AND BOTTOM COVER, AND IN 20 MINUTES, I WAS BACK IN BUSINESS. STARTED MAKING ICE IN ABOUT A HALF HOUR!!!!!
when in doubt, replace the freezer unit for $48 bucks! 7 out of 10 times it will fix your problems. All techs replace the IR set at the same time too which will set you back another $58 bucks.
Good luck! ;)
Mar 13, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Water dispenser not working on my whirlpool american fridge freezer ? Changed filter a week ago, is switched on but no water coming out of dispenser?
Make sure that the water filter is the right one and that it is pushed all the way in. If that is correct than There should be two solenoids located behind the fridge at the bottom one is for your ice and one for water. Unplug unit and test with an ohm meter across the two terminals if it ohms out or beeps than your solenoid is bad. If that is not it than there is a switch problem at the door.
Jan 02, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Whirlpool American Fridge Freezer
Make sure that the water filter is the right one and that it is pushed all the way in. If that is correct than There should be two solenoids located behind the fridge at the bottom one is for your ice and one for water. Unplug unit and test the water solenoid with an ohm meter across the two terminals if it ohms out or beeps than your solenoid is bad.
Whirlpool fridge freezer us
Make sure you have water to the fridge and then make sure your filter is pushed in all the way. If thats not it
Dec 30, 2008 | Whirlpool 25.6 cu. ft. Side-by-Side...
NO WATER OR ICE AT DOOR OR IN ICE MAKER
This is Gene's solution not mine, for a Ge fridge.
Assuming the ice dispenser works fine, the first thing I would check is the water filter, then the water inlet valve on the back of the fridge.
If the water filter is more than a year old it will cause restriction to the water flow.
Locate the water inlet valve on the back of the fridge. Remove the wires from the blue solenoid and check for 120V coming to the solenoid while the water dispenser lever is depressed.
If there is 120V then the water inlet valve has to be replaced.
May 03, 2008 | Refrigerators
Ice and Water not dispensing. Light button not working
INSIDE THE DISPENSER ASSEMBLY IS A SEPARATE ELECTRONIC BOARD THAT CONTROLS THE DISPENSER.
OCCASIONALLY, THE DOOR SOLENOID OR THE CUBE ICE SOLENOID WILL SHORT OUT CAUSING A BURNOUT OF THE DISPENSER CONTROL BOARD. CHECK FOR A BURNT SMELL COMING FROM THE DISPENSER HOUSING. IF YOU SMELL IT, THE BOARD AND/OR SOLENOID NEED TO BE REPLACED.
Apr 10, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Refrigerators Logo
Top Westinghouse Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Westinghouse Refrigerator Expert? Answer questions, earn points and help others
