Question about Bosch Dryers
Bosch WTL 5410 drier will not heat on auto dry settings but heats in manual dry.
  • 11 Answers
SOURCE: Dryer drum will not turn
check to see if there is a little red button on the back if so push it in thats your re-set button
Posted on Mar 24, 2009
  • 228 Answers
SOURCE: Re-set button location?
you need to remove the back panel the smaller one that covers heater matrix you will find a thermostat with a red reset button on it when you push it it will click and reset however you should find out why this happened before you use it again as it only does this if it overheats.
hope this helps
Posted on Jul 22, 2009
hiltonjug
  • 612 Answers
SOURCE: bosch axxis wtl 5410 dryer takes too long to dry.
You should have a cycling thermostat. this is most likely bad or your dryer vent may be clogged. Something is cutting the heat off before it gets hot enough. Both these cause this problem.
Posted on Nov 17, 2009
  • 51 Answers
SOURCE: WTL 5410 BOSCH AXXIS CONDENSATION ELECTRIC DRYER
the thermostats at the element have to be replaced, they burn out prematurely if the condensor unit is not cleaned on a regular basis.
Posted on Feb 02, 2010
  • 101 Answers
SOURCE: WTL 5410 tumbles just fine but just does not heat
Hi there, First of all, check to see if your lint trap is cleaned. On this machine, you should do this before and after each load. Also, check the air-inlet / heat exchanger to see if this needs cleaning. It's recommended that it be cleaned 3 to 4 times per year. It's very important to disconnect the power cord before doing this. Make sure to pay attention when removing this, because when you wash and clean it, you have to put it back exactly - or the door won't close. It's not difficult, but maybe writing down the steps on a piece of paper will help when putting it back. Make sure it's completely dry before putting it back in. It sounds like this is most likely the problem, so once cleaned - everything should work fine. Remember, just run water through the heat exchanger, clean it out good, and then let it dry completely before putting it back in. If these solution's don't work, feel free to contact me again. But it sounds like you have your machine in a very well ventilated area, which can also affect the dryer. But this would've happened awhile ago if this was the problem. But the biggest feature and task with this machine is the lint build-up. It's a great machine, and it's very sensitive - which is a good thing, because it will protect your dryer and its longevity. Best of Luck, and I hope you've already had this problem resolved.
Posted on Mar 14, 2010
Wte 86300US/05 dryer is not drying clothes shows f.03
This code indicates a problem with the dryer's heating system. The code will appear when the heating circuits are broken or when there is an intermittent break in the power source for the dryer. If the heating circuits are working and the power source is steady, you may need to replace the central control board.
Jan 09, 2012 | Bosch Axxis WTL 5410 Electric Dryer
Feb 02, 2010 | Bosch Axxis WTL 5410 Electric Dryer
Bosch axxis wtl 5410 dryer takes too long to dry.
Nov 17, 2009 | Bosch Axxis WTL 5410 Electric Dryer
My Bosch Axxis WTL 5410 will turn on and spin but no heat comes out of it. I cleaned the heat exchanger and wiped down the moisture sensors inside the drum, but still can't get heat out of it. I've read...
How long have you had the dryer (is it still under Warranty) and do you have the owner's manual and have you looked in it for a solution?
If not then you can contact the manufacturer on line to pose the problem to them.
There may not be a reset button on it at all. If there isn't then it is more than likely the heating element and you will have to replace it.
Oct 17, 2009 | Bosch Axxis WTL 5410 Electric Dryer
hope this helps
Jun 29, 2009 | Bosch Axxis WTL 5410 Electric Dryer
Load capacity of WTL 5410
7 kg is the max this is quoted as dry load not wet halfed when wet.
May 30, 2009 | Bosch Axxis WTL 5410 Electric Dryer
Water builds up behind heat exchanger
I don't know if there is a cure for this. Bosch never answers my calls or my e-mails, but I have found that by blowing in the hose to disengage the lint collecting there and then sucking out the line will remove nearly all of the build up amd drying will resume.
Jul 08, 2008 | Bosch Axxis WTL 5410 Electric Dryer
sounds like a power promblem to me check at out let for 220 volts if you have it there first turn circete breaker off then on try drier if that dont get it check for power at outlet with meter if 220 is there after unplugging drier check cord at back of drier at terminal block if all thats ok then you have a bad door switch a bad start switch or a bad thermal limiter last and rare bad drive motor
Nov 06, 2007 | Bosch Axxis WTL 5410 Electric Dryer
Dryers Logo
26 people viewed this question
Top Bosch Dryers Experts
Lawrence Oravetz
MightyMikeJr
Are you a Bosch Dryer Expert? Answer questions, earn points and help others
