Question about LG Washing Machines
My 7kg lg WD 1200D won't start. As soon as I turn the dial circuit breaker trips. I unplugged all appliances When again I turned my washer on the circuit breaker tripped again. Plz help .Thanks
    Top Expert:
  • LG Master
  • 45,527 Answers
There is a dead short or an insulation problem
call a service technician or an electrician and have it tested
Posted on Apr 19, 2017
catriver
  • 878 Answers
SOURCE: Dishwasher tripping the circuit breaker
Andy, leave the breaker off and remove the toe panel (bottom panel) from the dishwasher. Remove the cover of the junction box where the cord connection or wiring is made. Look at the wire caps and see if they are not burnt. Sometimes these connections become loose and arch, tripping the breaker. If so, cut the wires, strip a new end and reconnect. Catriver...post back.
Posted on Aug 21, 2006
TJBENGR
  • 121 Answers
SOURCE: my ac circuit breaker keep tripping
If your outside condenser has a locked rotor or short circuit, than the unit WILL trip the breaker - as it should. On the other hand if a breaker is tripped a few times it will have less of a capacity that the rating, (this is designed in it). You will need to determine if the unit is locked (and broken) or the breaker has become too sensitive.
Posted on Apr 22, 2008
SOURCE: LG washing machine trips GFI Circuit Breaker
WASHING MACHINES ARE NOT TO BE CONNECTED TO GFI OUTLETS AND TRY TO CONNECT IT TO A CERCIUT THAT IS NOT WITH YOUR DRYER. (REG) OUTLET.
Posted on Jan 31, 2009
gaeb7
  • 25 Answers
SOURCE: Fridge keeps tripping the circuit breaker
Your fridge should draw no more than 5amp. Presuming your breaker is at least 15amp there's a problem. Move to a different circuit first. If the condition persists check the start relay on the compressor. I have a suspicion the circuit may have another item you are not aware of.
Posted on Mar 01, 2009
mkh5094
  • 145 Answers
SOURCE: Washer trips circuit breaker
Is washer relatively new? Check circuit breaker for proper size (20 AMPS). Washer must also be on its own circuit. It appears that when the motor starts up it is causing a spike in current (as with any motor), so the breaker is either undersized (Note that if breaker is undersized and you up it to the next size you would also need to replace the wire with the next size up which would be 12/2 with ground), or if you have had your washer a while which I believe is your case the circuit breaker is weakening and is tripping on the current spike. Try swapping out your circuit breaker with a new one and try running the washer again.
Posted on May 02, 2010
Trip Circuit Breaker
The circuit breakers may both be functioning properly. What might be happening is that both circuits have other current drawing appliances on them. The circuit breakers react to the sum of all of the currents drawn by all of the devices on that circuit. So, if you have a 15 amp microwave and an 8 amp refrigerator on the same circuit, you would overload a 20 amp circuit by 3 amps.
Apr 14, 2014 | LG LMV1813ST Microwave Oven
Start button doesn't work on King Size Washer
Are there any lights on at the washer? If not check the washer circuit breaker in your house main circuit breaker/service panel. If it is tripped reset it and try start button again. If it trips again you need a service call. If there are lights on try turning the washer main knob to off and unplug the washer from the wall outlet...wait 10 seconds then plug in and try start button again.
Mar 16, 2014 | Bosch Nexxt 100 Series WFMC1001UC Front...
All lights up but as soon as i press the start buttom its trips the sockets out
I assume "trips the sockets out" means that the fuse or circuit breaker that supplies the power to the washer opens or moves to the "trip" position. I'll also assume it worked fine while plugged into this outlet before, too.
This indicates a "direct short circuit" or a very low resistance short circuit, and is potentially dangerous to people and property. Do NOT attempt to reset the circuit breaker or replace the fuse to try it again. This appliance requires a professional repairman to locate and repair the problem before you should attempt to use it again.
Be safe & good luck!
Sep 08, 2010 | Washing Machines
Washer tripped breaker on elec. panel, reset, washer won't turn o
This sounds like something has shorted causing the breaker to trip. You definitely need a qualified LG repairman to check it out.
Jan 11, 2010 | LG WM1814CW Front Load Washer
Put washing machine on and it automatically trips
If it is tripping the breaker, the first question that has to be asked is how many other appliances do you have on the same circuit. When the washer goes to spin it will start to draw slightly more electricity than once its at a full spin(much like the energy needed to get a car moving is greater than once it is up to speed), but it is not enough to trip the circuit unless there the circuit is already near capacity.
Before attempting to check electric of the washer, check and remove items from the circuit. To know what circuit runs your washer you will need to take a pigtail or a radio and plug it into the outlet Go to circuit breaker box and turn on and off circuits until the radio goes out.. Once you acertain what circuit your washer is own, go throughout the house and see what circuts are shared with the washer. Unplug any that are shared with washer. Your Hotpoint needs no more than 15 amps to run but if your overloaded on the circuit, the spin is enough for it to trip the circuit. Try washer and see if you go through the full cycle.
Oct 13, 2009 | Hotpoint Washing Machines
LG Tromm WM2277H washer won't start after tripping breaker
no fuses only control boards.with power off pull the top off and check wires at your power supply board(not the one with buttons). Look for burn or damaged wires. no luck with that, will probably need power board(usually the board that goes out). Call LG and speak to cust service....sometimes will cover the board.
Jun 11, 2009 | LG WM2277H Front Load Washer
My Eaton 20 amp Arc fault breaker tripped during a storm this morning. I tried the usual turn it off and back on deal and its still tripped off. It has a test button, which ive tried in the off and on...
this is going to be a long process, you have a short on the line or the breaker is gone.
you need to unplug all of the appliances that are on that line. (controlled by that breaker).
turn on the breaker. plug in one appliance at a time till the breaker trip again. unplug the last appliance that you have plugged in. that will be the cause of the short.
after all appliance unplugged and still trip the breaker, then you need a new breaker.
May 07, 2009 | Eaton 20A ARC FAULT BREAKER
Washing Machines Logo
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
