Question about Sewing Machines
Foot controller not working i think. Can it be replaced
Viking rose 609 model foot pedal will not work
I would suggest you replace the foot pedal speed control.
Jan 10, 2017 | Sewing Machines
I have a "singer" sewing machine, model 1022. Everything was working fine but now the foot pedal won't work. How do I take this apart to repair? How/Can it be repaired?
If you're unsure how to repair it, take it to a repair shop. You can cause more damage trying to fix something, plus parts may be hard to come by for the consumer.
Jun 23, 2016 | Sewing Machines
Brother NX-400. Never used. Error F04. I've looked for a model # for the foot for NX-400 to no avail. The foot that came in the box is Model T/FC-322. I can't help but think this is the wrong foot.
If you mean the foot controller, then the T/FC-322 is a substitute that should work. It's listed as a replacement here: . The manual for the NX400 gives the foot controller as XC1154-051 . Brother changes the part number often but the wiring remains the same. Another substitute controller is available here: .
The F04 message may mean there is an internal failure. This probably needs to be fixed by a Brother authorized repair person.
I wish that I had better news for you.
Mar 13, 2016 | Brother Sewing Machines
Singer 670 2 speed variable foot control. Slower speed no longer works. Blown resistor we think. Any one any idea what size it should be?
I believe you're referring to the 6700 series of machines. I found another foot controller at Sewing Parts Online for $79.00. You might also keep a lookout on eBay; enter "Singer 6700" as a search term. You can often get gently used or even new parts there cheaper, but I didn't find your foot controller right now. Here's the link to Sewing Parts Online.
Jan 17, 2015 | Singer Sewing Machines
Foot control does not work
Does it work by pushing the Start/Stop button. If so the problem is probably with the foot control. Make sure all connections are secure. You may need a new foot control. Contact your local Viking Dealer and try one of their foot controls to determine if it is indeed the foot control or something else. You can find your nearest authorized Viking Dealer from the Viking website - Click on Locate a Dealer for your local dealers.
Jan 28, 2014 | Husqvarna Viking 1
Foot pedal doesn't work
well if the foot pedal isn't working, you can either replace it with a new one or take the machine to a sewing machine repair shop & let them check the foot pedal & see if it's fixable
Mar 14, 2012 | Husqvarna Sewing Machines
Pedal on Elna air electronic gets stuck
can you please elaborate a bit further? do you mean the pneumatic foot control is not working? If so, check that the air line isn't sitting under your chair's leg, any pressure on this line will stop it working as it operates on air pressure into a bellows inside the machine. If you think that the foot control or the air line has a hole in it you will need to replace it, these parts are still available for sale from, just search using your Elna 2 digit model number to find it. All the Elna air electronics use the same foot control so there's no compatibility issues.
Oct 02, 2011 | Elna 2007 Mechanical Sewing Machine
Availability of foot control for Pfaff 1471 sewing machine - I think the electric connection plug to the machine needs re-welding. This has happened before and was fixed by having the connection...
Yes your dealer should be able to get you a new one or rebuild your old. $130 for new $ 50-75 to rebluild I would est. You did not tell what the problem with your machine is. I get people in all the time that think they have a bad foot control but it is motor brushes or bad baseplate. Take in your machine and let them put a different foot on it and test. If you have a bad foot control you will know with that test.
I can help more if you give more info.
Mar 14, 2011 | PfaFF Sewing Machines
The foot control for our 1214 pfaff sewing machine burne out (quit working) we took the machine to a repair shop and they replaced the foot control with a "Supreme" electronic foot control. The machine has...
if the first guy did not replace it with a pfaff foot it will not work right the pfaff machines will work backwards of normal power feet and they have to be replaced with pfaff feet
Aug 03, 2009 | Sewing Machines
Sewing Machines Logo
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
