Question about Refrigerators
I have a Hitachi 660Lt top freezer fridge. Where do I find the model number?
    Master:
  • 604 Answers
Posted on Apr 19, 2017
Testimonial: "Thanks found it by myself - local Hitachi agent could not help"
Top section of my side by side kitchen aid frodge stop cooling bottom is still cooling and freezer still working
send the model number?if the freezer is cold but in fridge the top is warm and the bottom is cold it sounds like you have a bad evaporator fan motor,all it does is cold starts in the freezer at the evaporator coil,and the evap fan blows the cold air into the fridge section,warm air rises so if the fan isn't working the cold air will stay down low and the warm air will stay up on top,open the freezer door,if you don't hear the fan blowing in the freezer i would have to say the evap fan motor is bad,if the fan is working one of the doors could have been left open and the air ducts froze up or you could have a damper in your model,it's just a door that opens and closes to let the air blow in but send the model number so whoever helps you can look up your fridge,usually the model number for a sxs is in the fridge section open the fridge door look up on the right hand wall up near the ceiling or in the middle of ceiling and there should be a tag with model and serial numbers just send the model number,
Jan 07, 2018 | Refrigerators
The lights are on in the fridge and the control panel works but the fridge or freezer will not get cold. What are we doing wrong? The panel says OF on both the fridge side and the freezer side.
Here are some FAQ provided by Repair Clinic. Click Here=> REFRIGERATOR-TROUBLESHOOTING
For a detailed Refrigerator illustration, click below. Side by Side Freezer on Top Freezer on Bottom Under counter If Iknew what model you have I could answer the OF code. LG has the OFF code that tells you that it is i demo mode but different refrigerators have different codes. See if you can locate the model number in the list below and contact me and I will be able to answer you a lot easier.
Freezers
Washers and Dryers
Sep 04, 2011 | Refrigerators
Kenmore fridge. freezer top works, but bottom doesn't.
Either your fan has stopped working, or it is not defrosting. Take the back panel of the freezer off and see if the evaporator coil is iced over, if it is replace the deforst heater, and the deforst thermostat. If the compressor is running the fan if the freezer should be running. Also make sure both your fridge and freezer controls are centered. Putting the freezer on the coldest setting acutally shuts off airflow to the fridge.
Dec 05, 2009 | Kenmore 71192 / 71194
Freezer does not work
Most model numbers are located in places like the photo shows below. It may be the thermostat itself causing the problem with freezer, yet I don't believe I have seen a refrigerator running without using the freezer to cool the refrigerator section. I guess anythings possible. Let me know, Thanks, Sea Breeze
Apr 21, 2009 | Sub-Zero Bottom Freezer Refrigerator
Hey my ge profile top fridge bottom freezer is broken
I had the same problem, It turned out to be a bad circuit board ($350). Also check to make sure you don't have frost/ice build up in the rear of the freezer. The fridge draws cool air from the freezer through a vent in the freezer.
Feb 04, 2009 | GE GDS18LBR Bottom Freezer Refrigerator
Refrigerators Logo
35 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
