Question about The Computers & Internet
How to enable two xDSL ports of the MA5600 to communicate with each other?
    Habit-Forming:
    New Friend:
  • 12 Answers
Two xDSL ports of the Huawei MA5600 communicate with each other through service ports.
If the two Huawei xDSL ports are on different boards, establish a standard VLAN, create one service port for each Huawei xDSL port, and then add the created two service ports to the established standard VLAN.
NOTE:
The service ports can be added to the standard VLAN only when the attribute of the VLAN is QinQ.
If the two xDSL ports are on the same board, establish a super VLAN, create one service port for each Huawei xDSL port, and then add the created two service ports to the sub VLAN of the established super VLAN.
Posted on Apr 19, 2017
How to Change the Service VLAN to Which the xDSL Port Belongs
Changing the service VLAN to which an Huawei xDSL port belongs means changing the service port configuration, namely, the PVC configuration, of an xDSL port. To change the service VLAN, run the undo service-port command to delete the service ports (PVCs), and then configure a new VLAN for the Huawei xDSL port.
The prerequisites for deleting a service port are as follows:
When you specify parameters, all the matched service ports will be deleted.
A service port cannot be deleted in the following conditions:
The port is encapsulated as PPPoA, IPoA, or Auto.
The port contains the BTV user.
The port is bound with an IP address or a MAC address.
The port is configured with a static MAC address.
Huawei MA5600
Huawei MA5616
Huawei DSLAM
May 04, 2017 | The Computers & Internet
Can I configure a MA5616 with 256 ADSL2+ ports?
Yes, but the 64 ADSL2+ ports board price is high, also have requirement on main control board which may make your cost high, so suggests for small site purchase the Huawei DSLAM with 128 ADSL2+, if need more than that consider big MA5616 MA5600 or 2 units MA5616 using cascading.
http://www.thunder-link.com/HUAWEI-DSLAM_c126.html
Nov 27, 2015 | Computers & Internet
What is the typical configuration of MA5600?
http://www.huanetwork.com/huawei-ma5600-price_p3862.html typical configuration: you may follow below steps:
1, Choose the main control board SCUB quantity, one or two;
2, Choose the uplink pinch board, O4GS(4GE Optical), O2GS(2GE Optical) and E4GFA (4 GE/FE Electrical) are commonly used;
3, Calculate how many ADSL2+ or VDSL2 subscribers to be connected, Huanetwork most stock are 64-port ADSL2+ over POTS(with 600ohm Splitter) board ADEE;
4, Choose the subscriber cable length;
5, Choose accessory, SFP module, patch cord.
Sep 09, 2014 | Ericsson T202g Gpon Sbu Voice, Data, And...
Can the Lan port of AR1220-S or AR2204-S be divided VLAN? Please help!
AR1220-S the two layer ports, can divide 8 VLAN, one port for a VLAN, the AR2204 can not divede VLAN. Huawei AR1200 Series routers are designed to provide secure and scalable unified voice and data communications for small enterprises or large enterprise branch offices. It supports wired and wireless access modes, including E1/T1, xDSL, xPON, WiFi, 3G, and more.
More information about Huawei router,please visit:c:\docume~1\admini~1\locals~1\temp\[5uq[bl(6~bs2jv6w}n6[%s.pnghttp://huaweirouter.blog.com
Mar 28, 2014 | Computers & Internet
My computer cannot detect my scanner. Error Code: 0x0070800
The FB320P is a parallel port scanner and is having problems communicating with the computer. Are you connecting it directly to the parallel port on the computer? In that case, you may not have bi-directional communication enabled. Turn off the scanner and the computer and disconnect the data cable from the computer. Turn on the computer and enter the BIOS. (Press Esc, F1, F10, or Del repeatedly after you turn the computer. You should see a screen with the correct key to press; it varies depending on your BIOS and motherboard. If you miss the timing, shut down the computer and try again.) In the BIOS, search for the parallel port settings and see if you can enable bi-directional communication.
Not all parallel ports support bi-directional communication. If you can't enable the feature, you need a different parallel port. Try a PCI slot add-on card; just check the features and check the manual for enabling bi-directional communication.
If you are using a USB to parallel port adapter, get a different one that supports the bi-directional communication.
What OS are you using? There are a few that had ASPI driver issues; a third party app, ForceASPI, may help. See http://www.afterdawn.com/software/cd_dvd/dvd_tools/frcaspi.cfm for information.
I hope this helps. Please add more information about the configuration (cable, OS, etc) for extra ideas to solve the problem.
Sep 16, 2012 | Canon CanoScan FB320P Flatbed Scanner
CANT ENABLE BIDIRECTIONAL COMMUNICATION X4550
I have tried to set up this wireless printer on my laptop (windows vista basic). I run through installation and get message - installation complete and the green indicator light is fully on. When I try and print I get message Printer cannot communicate with computer - please turn on 'Enable Biodirectional Communication' in printer properties. I go to control panel/printer/propertie/ports/ and I see Enable Biodirectional communication - the box is grayed out and I cannot enable it. Any suggestions?
Jan 22, 2010 | Lexmark X4550 InkJet Printer
What it means Enable Bidirectional Communication
To enable bi directional printing:
Open Printers and Faxes in control Panel
Right Click on the Printers Icon
Select PROPERTIES
In the Properties dialog box select the PORTS tab
Near the bottom there is a check box to enable Bi-directional printing
Make sure it is checked
Click OK to exit the dialog box
Feb 17, 2009 | Lexmark X2470 All-In-One InkJet Printer
Playstation Party error
Try opening ports for the game on the router. This could be a firewall problem. Contact your game provider for the ports needed on your router
Apr 29, 2008 | Sitecom xDSL/Cable Broadband Router DC-200
Computers & Internet Logo
29 people viewed this question
Top The Computers & Internet Experts
Darren  Means
Darren Means
d3yavu3
kimblebear
Level 1 Expert
Are you a The Computer and Internet Expert? Answer questions, earn points and help others
