Question about Symbol M2004 Barcode Scanner
Cannot Get Symbol m2004-i290 cyclone to work with Beetle /M
I am having trouble getting my Symbol M2004-I290 Barcode Scanner to send data to my POS software or even to any other program on the Computer system which is a Beetle /M. It is running Windows XP. I have connected it to one of the serial ports on the back of the computer COM 4.
I would be grateful if anyone ould help me fiind a solution to this. Please Contact me if more information is required.
Hi, the link in this otherwise excellent article is dead - Symbol appear to have been absorbed by Motorola and you can't get a direct link from their site. To get to the reference guide, go to http://support.symbol.com, wait for the re-direct to Motorola, then look under 'Products' for Barcode Scanners. Click that and type "M2000" in the 'Describe your problem' field. First result should be the Product Reference Guide.
Posted on Apr 28, 2010
    Scholar:
  • 74 Answers
When connecting to a serial port there are a couple of things that could be causing the issue. The biggest problems are usually one of these:
  1. The app does not accept serial data.
  2. The RS-232 settings of the scanner and serial application do not match.
  3. The cable issue.
  4. The data is not using the termination character the application needs.
Are you using a Symbol 25-32465-20 or CBA-R01-S07PAR cable?
If so, do you know for sure your application accepts serial data? The scanner puts the data on the COM port and the application takes it from there. A good test is to try the scanner in Hyper Terminal if you have it. It is usually listed under: Programs>Accessories>Communications.
The M2004 series scanners default to 9600 baud (or bits per second), 8 data bits, 1 stop bit, no parity and no hardware or software flow control.
When starting HyperTerminal you may have to go through a screen that asks for a phone number. Just enter something and click OK to get to the next screen (sorry I can not remember exactly what that screen looks like- once it is set you do not see it again.) Next will be the Connection Description window. You will name the session (name it anything you would like) then click OK. Next is the Connect To box. Select your COM port in the Connect Using box, the first three boxes do not matter. When you click OK a Properties window will open. Most likely you will only have to change the Bits per second to 9600 and the Flow control to None. When you click OK your session should be active. You will have a blinking cursor in the upper left corner and in the bottom left portion of the window you should see the session time counting up. You can now try to scan a barcode. If the data shows up you know the scanner and cable are both working.
If you know your application accepts serial data (Word, Notepad, Excel do not) then it may be the application needs to see a carriage return at the end of the data. The CR is added by scanning Scan Options, Data Suffix, Enter from the M2000 Series Product Reference Guide. Test the scanner. If you still do not get data scan Scan Suffix, 1,0,1,3. Again all of these barcodes are in the M2000 PRG which can be obtained here:
http://support.symbol.com/support/search.do?cmd=displayKC&docType=kc&externalId=3969606apdf&sliceId=&dialogID=116516744&stateId=0%200%2011867900
Hopefully this information will be helpful in getting the M2004 working.
Posted on Jul 24, 2009
  • 2 more comments
  • sachu211 Aug 03, 2011
    i have exct problem and i did that and is not working i dont know why
  • Symbscanners Aug 05, 2011
    As of 5Aug2011 the link I provided is still good. Motorola still uses the Support.symbol.com website.
    Did you test the scanner in Hyper Terminal with the settings I suggested and are using the RS-232 cable listed?
  • sachu211 Aug 29, 2011
    yes i did and it work fine but i am useing (rms 2.0.04 Microsoft rms ) and is not showing any data
How do I set the Cyclone M2004 to auto-scan?
Hi
Contact Motorola Solutions Get Support or Zebra Technologies
Support Downloads. They aren't helping on FixYa yet so it is best to reach out directly.
Mark
Motorola Mobility Support
Jun 20, 2014 | Symbol Cyclone M2004 Scanner
SPACE problem. Hello i have Symbol LS 2208. I need remove space/gap from this code 09/ 5864 I tried to create rule for this (remove all spaces) but it wasn´t work - the scanner scaned no data. I use...
Hello, if all your barcodes have the same structure, it will an easy task. You would need to scan following barcodes from ADF chapter in the Product Reference Guide located at http://support.symbol.com/support/search.do?cmd=displayKC&docType=kc&externalId=5880807apdf
Create New Rule Send Characters Up To Space Character in Alfanumeric Section Skip Ahead 1 Send All That Remains Save Rule
This will by all scanned barcodes send all characters up to the space character, skip the space and send the rest of data.
Oct 22, 2010 | Symbol LS 2208 Barcode Scanner - P/N...
Problems with M2004 Barcode Scanner
If your M2004 is connected with an RS-232 cable such as the CBA-R01-S07ZAR or the 25-32465-20R the scanner defaults to sending data at 9600 baud, 8 data bits, 1 stop bit, no parity, software or hardware handshaking. Is it possible the software needs to see a carriage return after the data? If so, Scan Options, Data Suffix, Enter from Adobe page 135 and 136 of 310 of the M2000 Series Product Reference Guide will make the scanner send a carriage return line feed (7013). If your program needs just a CR then scan the Scan Suffix barcode from page 134 of 310 followed by a 1, a 0, a 1 and a 3 from page 175 of 310.
If this does not help or if you are connected any other way and the CRLF does not help it may be a good idea to contact the Motorola support center for assistance. Their phone number is 800-653-5350.
Oct 22, 2009 | Cyclone Symbol M2004 Omni-Directional...
I have plugged it in, and the laser is on but does not work. It beeps when I scan a barcode but the computer nor the epos software is reconising it. Hlpe!
Make sure the correct port is selected in the Symbol software (or whatever program you are using)
You can check if the scanner is functioning by opening a new "text" document and then scan a barcode and the results should show up in the text document.
If that works then it's probably just your software configuration...
Good Luck!
Oct 10, 2009 | Symbol Cyclone M2004 Handheld Barcode...
How to setup symbol m2000 sanner USB
You would need to use the Synapse Smart Cable Adapter to use this scanner with USB interface. The Product Number for the adpater is STI85-0200R.
This one can be connected between the scanner and desktop PC or other host. It supports the standard USB HID drivers
Sep 25, 2009 | Symbol Cyclone M2004 Handheld Barcode...
I want to my m2004 to enter barcode scan after each scan automati
Print Adobe pages 128 and 129 of 302 of the M2000 Series Product Reference Guide and scan the "Scan Options" "Data Suffix" and "Enter" barcodes. The scanner will give two beeps after the first barcode, two beeps after the second and a warble after the third programming (Enter) barcode.
The manual can be downloaded from this link: http://support.symbol.com/support/search.do?cmd=displayKC&docType=kc&externalId=3969605apdf&sliceId=&dialogID=114420706&stateId=1%200%20114410949
Jul 12, 2009 | Symbol M2004 Barcode Scanner
I did master reset on my motorola i290. now no service, pls help
having problems sending or recieving text messages on my i290 motorola
Jun 13, 2009 | Motorola Mobility I335 Cellular Phone
Symbol M2004 scanner scans bar code using hyperterminal to test.But it will not scan into word or into my pos maid software.Attached via com port. any ideas
I know this is an old thread but it may be useful to someone.
Model: Symbol M2004-I111 cyclone.
Look up no."73-39696-111" for a pdf of programming instructions.
The large jack plug goes to a security tag demagnetiser. Though mine has only two wires, a black and a red. Scanner works with nothing connected to this end. I think pressing the button on the top of the scanner sends a pulse to the demag. to disable the security tag.
The scanner needs a powered com port to work. Usually only on purpose built till machines not ordinary pc ports.
Good luck i have not been able to figure out the complexities of getting it to do what I want yet (no read all code!).
Apr 02, 2009 | Symbol Cyclone M2004 Handheld
I need a driver for my Symbol Cyclone M2004 becouse it has a serial conection
There is no need for drivers for this scanner. You will need to configure it using the barcodes from the product reference guide to use standard serial port. You can test it in Hyper Terminal if you set the com port normally to 9600, 8, n, 1. This should enable the scanner.
Make sure that you actually have the right cable for it.
Mar 18, 2009 | Symbol Cyclone M2004 Handheld Barcode...
Transfer info from the digital weight scaleto quickbooks
You would need to add an criteria or the rule, like barcode length or type. Than is the the scanner able to understand which barcode should be handled by the specific rule.
Dec 03, 2008 | Symbol LS2208 Handheld
Symbol M2004 Barcode Scanner Logo
475 people viewed this question
Top Symbol Computers & Internet Experts
Gareth Cockram
Gareth Cockram
Greg Cann
Greg Cann
Michael
Are you a Symbol Computer and Internet Expert? Answer questions, earn points and help others
