Question about Daewoo Refrigerators
Daewoo fridge freezer FRS-U201A1 freezer upper section not freezing has been icing up half way down just on the little white circle which is on the freezer Middle bo
  • 183 Answers
SOURCE: need help
With this model it suffers with the evaporator freezing up, try to defrost overnight with the doors open, restart the following day and it should start to work ok within 24hrs. Regards Advisor
Posted on Sep 01, 2007
  • 29 Answers
SOURCE: Our beko frost free fridge
the thermostat in the fridge is turning off your compressor before the freezer has completed its job.this is because it doesnt care about the freezer temperature only the temperature where its located in this case the fridge,try completely defrosting the fridge and restarting it
Posted on Aug 13, 2008
SOURCE: Daewoo FRS-2031IAL instruction manual
Hold down the [ice make lock] and then the [lock] button simultaneously for 3 seconds. It took me a couple of attempts but I got there in the end (the manual mentions holding them down at the same time).
Posted on Apr 21, 2009
Sea Breeze
  • 4655 Answers
SOURCE: Kenmore elite - Water dripping from freezer to refrigerator
Your refrigerator has a defrost drain blockage behind the evaporator in your your freezer compartment. Some models like yours have leak in the turns as the water leaves the freezer. I recommend that you unplug and remove the cover to the evaporator and check the defrost condensate tray below the evaporator. A wet vacuum cleaner and poring a solution with clorox in the drain will help you clean locate the leak and where the blockage may be downline.. I do have the manual on yours and can help you solve this. Some times this is a factory defect and I can help you solve the freezing drain problem. Let me know, Sea Breeze
Posted on Jul 01, 2009
  • 70 Answers
SOURCE: Miela fridge freezer freezes food in the fridge
Most likely reason is fridge evaporator sensor faulty. The sensor is screwed to the back wall of the fridge behind bracket next to light and has a green band near the end . The sensor come as a repair kit (part no. 7323301). Just follow instructions in the packet.It is quite straight forward
Posted on Aug 10, 2010
Ice maker problem daewoo frs-2031 IAL
I wouldn't buy a Daewoo fridge with Donald Trump's money!
Jun 27, 2016 | Daewoo Freezers
Daewoo side by side fridge freezer FRS-U201CW-N186. Freezer is not self defrosting and fridge isn't maintaining a cold temperature
start with locating and cycling the defrost timer switch, generally found in the refrigerator side. The timer controls a heating element designed to melt off ice build up on the interior freezer coils. if the timer is bad, ice will build up, blocking air flow to the refrigerator section (making it not cool) and eventually build up enough so that the internal fan actually hits ice, making unusual noises. most timers can be manually driven with a flat head screwdriver, do it with the power connected, when you reach the defrost cycle you will hear the fans and compressor shut off, and you should be able to feel warmth on the back panel in the freezer after a few minutes.
if you find the timer isn't working properly, it is not difficult to replace, take your time, take pictures as you go along so reassembly is easier, and of course have the frige unplugged when you do it.
Sep 14, 2014 | Refrigerators
Why isnt the top part of my Daewoo FRS-U20BG larder fridge/freezer working although rest of freezer seems ok?
Is it just the freezer section? Open the freezer door for a minute and then, without shutting it, press the button on the inside that makes the light go out. The fan at the back at the top of the freezer should start whirring. This circulates the freezing air. If it doesn't start then that's your problem as the freezing air isn't getting to the top of the freezer. It's simple enough to replace. Buy a new part (30 pounds?) and replace from the inside by removing the back panels to the freezer. Turn the freezer off and unplug first though, obviously! Hope this helps.
Jun 16, 2014 | Daewoo FRSU20IA Freezer
We have a FRS-U20FA
The water dispenser tube has a low wattage element to prevent the water from freezing in the tube. its normal. Check to see if the evaporator fan is running. Open the freezer door and when the fridge is running, press the switch on the side wall. The freezer light should go out and then you should hear the fan running at the back of the freezer compartment. Common symptoms of a failed fan is ice growing down the back of the freezer compartment , poor refrigeration in the food compartment and partial or poor freezing of food in the freezer. If the fridge is less than 2 years old, it will be under warranty. (Contact Castel Electronics in Melbourne 13
00733962) If its over, they can give you the name and number of a local agent. There are a lot of bits and pieces to remove to get to the fan on an ice and water model, also the rear panel inside the freezer should be removed to make sure ice hasn't blocked the air ducts. If you are not confident in doing it, get one of their agents to sort it out. Cost of fan motor, call and labour should be around $200 to $220
Dec 26, 2013 | Daewoo Refrigerators
Top of freezer not freezing
your cooling matchine get damaged,there having a cooling matchine.
Mar 25, 2013 | Daewoo FRSU20IA Freezer
Mar 24, 2009 | Refrigerators
Whirlpool gold:upper half of refridgerator side not cold
Either the evap fan has a problem, or the defrost system has failed. You should never see frost in the freezer section as the defrost sensor should sense that the coils need to be defrosted before that much frost accumulates.
Unplugging to clean out helped because the frost got a chance to melt away.
If you find the evap motor is running, then the things to check are the defrost sensor, the defrost timer, and the defrost heater.
Reply back if you would like more info.
Jan 27, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Refrigerators Logo
49 people viewed this question
Top Daewoo Refrigerators Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Daewoo Refrigerator Expert? Answer questions, earn points and help others
