Dw60 dishwasher error code has come on and cannot remove
2 Suggested Answers
  • 62 Answers
SOURCE: THE kid put a whole bowl of cornflakes in the dishwasher
If you have access to a wet/dry shop vac get it! Start pouring in water and vacuum it out. If you can remove the impeller assembly in the bottom center do it. You also might want to blow ait thru the drain hose back into the dishwasher!
Posted on Mar 17, 2010
E5
Make sure the water inlet tap under sink is fully opened. The water pressure in mains could be lower than the setting on the dishwasher. Assuming it is DW60. See this manual.
http://manuals.appliancesonline.com.au/dw60cdx2/dw60cdx2_user_guide.pdf
Mar 30, 2014 | Fisher and Paykel Dishwashers
Replace dishwasher drain hose F&P DW60
The attached assembly document might be helpful. To access the drain hose at the dishwasher end your best bet is to pull the dishwasher out from under kitchen cabinet and lay it on the floor on its side. Make sure you disconnect the mains power and the hose connections first. The hose should be accessible from the bottom of dishwasher.
http://www.jordansmanuals.com/ServiceManuals/FP/Dishwasher/DW60CDW2/DW60CDW2.pdf
Mar 25, 2014 | Fisher and Paykel Dishwashers
Stoves dishwasher leaking from the door
Check the latch at the top, this can be adjusted to seat the door better against the seal, another couple of places they can leak is around the powder dispenser in the door and also check the door seal for nicks or splits.
Mar 10, 2012 | Stoves 27 in. DW60 Built-in Dishwasher
Drying doesn't work, there is no water heating
what is the model number of your dishwasher most likely the heating element has gone south for the winter but in order to check if it has you would have to do a continuity test on the heater itself the heater is also the main thing that heats the water as well message me back with your model number and i can send you some schematics on how to remove as well as who has the part the cheapest Thanks again Rick
Jan 05, 2011 | Stoves 27 in. DW60 Built-in Dishwasher
THE kid put a whole bowl of cornflakes in the dishwasher-i have removed and cleaned what I can see. THE flood sensor is still beeping at me!!! elba dw60
Mar 16, 2010 | Dishwashers
Fisher&Paykel DW60 drain pump is blocked.
Check the drain hoses by removing the dishdrawers from the machine and pulling on the hoses. I installed a Fisher Paykel DD602 about a month ago and the bottom drawer was not draining. I removed the drawer and freed up the drain hose and the machine worked fine.
Feb 07, 2009 | Fisher and Paykel 23 in. DD-603SS Built-in...
New world wd60
i made sure drain hose was not blocked found gunk at bottum , but to reset alarm e4 , had to drain dishwasher put it on its side - must have remove an airlock. checked turn on and e4 had gone , all ok now suggest rinse all dishes before washing
Aug 24, 2008 | Stoves 27 in. DW60 Built-in Dishwasher
New World DW60 dishwasher not working originally had E4 fault Power comes into the PCB the switches and led's light up but nothing happens. After about 5 mins there is a short beep. Does not show any...
I f you have warranty on this please call them, you have a defective D/W.Unless there is no charge for repairs ,don't spend a dollar on what is going to be a on going problem ahead.To explain how to fix this is what the manufacturer should have done in the factory and not made 1 dollar off of this defective D/W until it proved this to be ready .What has happened to Quality Control ? Does it no longer matter ? Very sorry ,you should seek a refund ASAP.
Jun 23, 2008 | Dishwashers
New world DW60-flashing lights
This dishwasher uses the program lights a s a fault code. Usually it is due to food jamming the impeller. If you are competent you can get at it from underneath. Mine was under warranty when this happened and the engineer was heard to say, 'this is a dishwasher not a waste disposal'. The engineer cleared it with a wire coat hanger down the drian hole inside the machine. Not happened since we really scape off plates.
Oct 20, 2007 | Stoves 27 in. DW60 Built-in Dishwasher
23 people viewed this question
jasbo
jasbo
