Question about Lands Phones
How do I report a faulty business line
Our business switchboard does not give us a dialing tone when trying to phone
  • 159 Answers
SOURCE: We can't send or received faxes
Just a suggestion. This effect can happen if you have plugged the line cord into the tel jack instead of line jack.
Posted on Feb 12, 2008
  • 80 Answers
SOURCE: Have dial tone, but can't fax
It sounds like the modem is bad a possible electric serge
Posted on Jan 09, 2009
  • 95 Answers
SOURCE: My vetech cordless phone is not working
DO you have a 2 line model? If so check and make sure the conf (conference) button is not pushed as it will keep the line off-hook forever. Hope this helps!
Posted on Mar 28, 2009
SOURCE: Uniden PowerMax 5.8 - system busy error comes up & no dial tone
Unplug the power supply to the base of the main handset, wait 10 seconds and plug back in.
  • 142 Answers
SOURCE: the tel 1 and 2
When the tel light blinks this indicates that the line is in use. To trouble shoot this issue you will need to connect a phone directly to the tel 1 port of your modem. If you have dial tone when directly connect that means that there is an issue with the internal wiring of the home. If you still do not have any dial tone with the phone directly connect than there is an issue with the modem and it needs to be replaced.
I hope that information above has helped is some way.
If possible please rate this solution.
Posted on Sep 01, 2010
How do I check my phone line? I have no dial tone. When The phone rings, it only rings once.
it rings so that indicates that the land line is ok
for a quick check see if you can borrow a neighbours phone and plug it into the wall socket
If you get a dial tone then , the problem is your phone
if you do not get a dial tone , call the service provider and report a faulty service
Sep 07, 2017 | Lands Phones
All phones are plugged in and operating but i get a busy signal on all in talk mode
I assumed when you say all phones are operating means there's power and are charging.
1. There could be some phones that are loading the Tel line. Disconnect all phones and plug it one by one while checking the dial tone. If all phones gives busy tone, there coulb be a problem in the Trunk line or the Tel Company line.
2. There could be a short or resistance in the line. Check the connection in junction box between your house and the Tel Company cable.
3. If you have an analog Tel set, you can check the dial tone directly from Tel Company cable that comes in to your house.
I hope this helps.
Best Regards.
Sep 01, 2015 | Panasonic KX-TGEA20 Additional Digital...
Why can't I rec or make calls?
What is happening when a call comes in are they getting a busy signal? If so your line is shorted out.. unplug all phones and see if caller hears a ring.. Then 1 at a time plug phones in. Check for a dial tone and press a digit, hang up and check and see if dial tone returns, repeat this on all phones, until you get to the phone that does not give you dial tone back after dialing a digit. That will be your bad phone... If the line was ring busy after all phones unplugged, call repair service..
Aug 10, 2015 | Lands Phones
I run a hotel and put a phone in a room that was a storage room and never had one before. I have a dial tone but anything I press doesn't register. I cant get out and when I dial 0 for the front desk, I...
Hello -
Since the telephone works fine when plugged into phone jacks in other rooms, then, the problem is with the phone line in the room which was a storage room.
You will need to find an hire a technician who is familiar with new phone line installation and switchboards.
Best wishes.
Feb 13, 2018 | Lands Phones
Phone not working
Hi Pam,
Try these..1...remove your telephone line from base unit and fix it into a working land phone and check whether is it having normal dial tone.If it's having engage tone(beep beep...)remove paralleled phones and re connect to cordless base unit.
2.If line is ok (normal dial tone with full volume) & still display indicates line is busy, your main base unit must be having faulty components inside.Commonly these defects happen in thundering or surges through telephone lines.You have to take full set to a repair shop.
Dec 28, 2013 | Gigaset As300 Twin Dect Cordless Phone -...
My fax machine will not send faxes. After a number is dialed, it will give me a report saying that there is no response/busy.
The only thing that could stop you from sending a fax or not get a dial tone, would be the connection to the phone line. Make sure the telephone wire is plugged into the line jack (not ext jack) and should go straight to the wall, without splitters or extensions. If you still cannot send a fax, try another wire or jack
Apr 19, 2010 | Brother MultiFunction Center MFC-440CN...
The phones worked last night, this morning nothing
If the phone rings but no dial tone, possible phone unit is faulty. I suggest to try a different phone unit to verify if it's faulty. If the other phone isn't working too, then report the issue to your phone provider.
Jun 10, 2009 | Linksys SPA-2102 NA Analog VoIP Adapter...
I cannot dial out.
The dial may be defective and when you dial it is putting out erronous tones. When the Phone Company heres digits that do not correspond to a legal phone number it will give you a error tone or busy tone. It could be the phone got put on pulse and the line won't recognize the pulses
Dec 28, 2008 | Lands Phones
Trying to launch internet gives me error 680.
680 - There is no dial tone.
All versions of Windows are affected by this error.
No dial tone: There are many possible causes of a No Dial Tone Error.
First, try testing the modem's ability to detect dial tone and to dial by using HyperTerminal with the direct to COM port connect method - see Using HyperTerminal. If you give your modem an AT&FX1 command, and then a dial command, dial-tone detection will be disabled; if you still do not get dial tone, the modem may not be installed correctly (especially if it is a PCI or soft-modem); or the cable from the modem to the phone-line jack may be bad or installed in the wrong connector on the modem - try another line cord, and make sure you are plugged in to the LINE - not phone - jack on the modem. Plug a regular phone into the phone jack on the modem and make sure it has dial tone. The modem may also be defective. Many new modems come with an electronic circuit instead of the traditional electro-mechanical relay used to take the modem off-hook. Some of these designs are proving less reliable; often, they will be 'stuck' in the off-hook position, so unplugging, the plugging in the phone cord may give dial-tone. If this is the case, the modem needs repair or replacement.
If the modem will blind dial (x1), but not detect dial-tone otherwise, the problem is likely to be in the proper selection of the Country in Windows->ControlPanel->Telephony or in improper installation of the modem or lack of support for your country in the driver you are using. Check to see if there are updated drivers for your modem.
If the modem dials properly with detection (x3) in HyperTerminal, but does not detect dial tone when using DUNs, the problem may be DUNs (check for upgrade or re-install) or the proper setup and modem selection for the DUNs connectoid.
For Embarq telephone service customers, this error can indicate that you have a message waiting in your voicemail. Embarq changes the dial-tone sound to a "fast" busy signal when a new message is present in your voicemail box. This "fast" busy signal can confuse the modem into thinking there is no-dial tone present on the line.
Jul 02, 2008 | Microsoft Windows XP Home Edition
Lands Phones Logo
27 people viewed this question
Top Lands Phones Experts
Are you a Lands Phone Expert? Answer questions, earn points and help others
