Question about The Computers & Internet
Poulan pb1638lt lights don't work
THEY WORKED THE LAST TIME USED IT?
    Habit-Forming:
    New Friend:
  • 22 Answers
Hi mate, i am going to assume you have checked the globes :) other then that below is the manual, there appears to be a note on the wiring diagram about the headlights see below:
NOTE YOUR TRACTOR IS EQUIPPED WITH A SPECIAL ALTERNATOR SYSTEM. THE LIGHTS ARE NOT CONNECTED TO THE BATTERY, BUT HAVE THEIR OWN ELECTRICAL SOURCE. BECAUSE OF THIS, THE BRIGHTNESS OF THE LIGHTS WILL CHANGE WITH ENGINE SPEED. AT IDLE THE LIGHTS WILL DIM. AS THE ENGINE IS SPEEDED UP, THE LIGHTS WILL BECOME THEIR BRIGHTEST.
basically the lights run directly off the alternator with a switch in between,
before you proceed : if you know how to test power and earth wires with a test light then i would look at the attached diagram, if your not familiar with test lights and testing for power and earth then i would call a mate who can help
with the mower running i would use a simple light tester ( one that just lights up when there voltage) test and see if there is power to power side of the light bulb socket when the switch is on ( the red wire), if theirs no power at the light bulb socket then try the same test on each terminal of the headlight switch
if there is power at the light bulb socket - then check the earth wire is connected ( the back wire connecting to the light bulb socket) or replace the bulbs :) if not proceed to test the switch below
if there is power one one side of the switch but its not going to the bulbs - replace the switch, or ensure the wire that goes from the switch to the bulb is connected as there is a joiner in between that could be unplugged or corroded
if there is now power to the switch or the bulb at all then your alternator my be faulty and not providing power to the bulbs, your mower could just be running and starting off the remaining charge in the battery as the lights dont connect to the battery they will not function even if the battery is charged
see below for link to the manual with wire diagram
http://www.poulan.com/ddoc/POUI/POUI2006_USen/POUI2006_USen_401536_.pdf
poulan pb1638lt lights don't work - tractor-ray0hjyhdiz4pf0utlyrskko-2-0_0.png
Posted on Apr 19, 2017
How does a clutch cable work in a poulan pb1638lt tractor
When engaged, the cable moves an idler pulley. This applies tension to the belt and engages the blades.
Sep 19, 2016 | Poulan Garden
Why is the Transmission jerky when starting to move (especially in higher gears)?
Sounds to me like a worn belt,even if is a hydro still has a belt!
Aug 11, 2014 | Poulan Garden
How to install a solenoid on a Poulan pb1638lt
the starter switch is the correct answer the starter switch allows a current to flow to the remote wire which is the wire that tells to solenoid to allow voltage to the starter on some systems may require a jumper wire that connects the two small lugs but i don't believe this is required for your application
Oct 16, 2012 | Garden
Poulan riding mower grinding noise
Sounds like bad gears in transmission.
Sep 07, 2017 | Garden
2006 poulan rider
is there power going to the solenoid on the bottom of the carb? is the solenoid stuck from old fuel sitting in the carb?if there is no power to the solenoid check the safety switches
Jun 06, 2012 | Poulan Garden
The problem the pull rope on a Homelite blower UT08934D doesn;t always retract. While working on it i found that the rotor was loose on the shift. I tighten the nut but didn't seem go all the way...
The Homelite/Poulan starter mechanism is of poor engineering and design. Problems with them are constant in the industry. They seem to work sporadically at best. If you have taken it apart, you have seen the inferior workmanship. Granted, all metal construction would wear also, but would be more heavier-duty and last longer. Another reason (the main one) why they don't last if from working the starter/recoil unit so much because the engine won't start. And when it doesn't, 9 times out of 10, it is a fuel system (carburetor) problem. Pulling on the wimpy unit 50 times so it can start once greatly reduces it's life expectancy, and overuse is the main reason they fail.
Aug 12, 2011 | Garden
My gauges just stop working,and they are frozen in one spot,the temp gauge still moves a little but not like its supposed to.and the dummy lights wont work but the turn signal lights work,also the light...
The gauges have a memory. They will stay where the last read was when you turn the key off and don't move until you turn the key back on. If something happened between the time you turned the key off and back on then they could be stuck in that last position.
Sounds like you may have a ground issue. The cluster uses a common ground. Maybe start by checking the ground wire under the dash that uses one of its mounting bolts in the corner.
Jun 27, 2011 | 1988 Chevrolet Camaro
Does poulan make anything last longer than 1 summers use or is that how they stay in buisness?
no there stuff sucks. you want quality buy husqvarna.i had a poulan chain saw lasted a yr and half then stopped working.
Mar 23, 2010 | Poulan Featherlite Gas Blower, with Low...
How to remove clutch on Poulan Pro PPB350 gas trimmer
Poulan makes a tool, part # 530031112, with two prongs that fit the grooves on the sides of the clutch. It fits most Poulan saws and trimmers made in at least the last decade. I use a butterfly impact and 3/4 impact socket and turn CLOCKWISE to remove. There should by an arrow and the word off stamped on the clutch This is the tool... That should work for you. Dwainb076e56.jpg
May 18, 2009 | Poulan "Poulan" Pp325 17" Gas Brushcutter...
Computers & Internet Logo
43 people viewed this question
Top The Computers & Internet Experts
Perry Ralston
Level 1 Expert
ashu k...........
Level 1 Expert
ted dux
Are you a The Computer and Internet Expert? Answer questions, earn points and help others
