Im replacing the electrical cord on a 1500 watt 12.5 amp 120VAC,60Hz heater.Is 14 guage sufficiant?
  • 412 Answers
14 is just fine. 16 would be okay.
Posted on Apr 19, 2017
  • Heating & Co... Master
  • 1,654 Answers
14 gauge will be enough provided your breaker is a 15 amp. If 20 amp I recommend 12 gauge wire.
Will the patton electric heater significantly raise my electric bill
1500 watts is 1.5 kilowatts. Run it for 1 hour and you have 1.5 kilowatt hours. My electricity costs .08 per kilowatt hour so, when I run my 1500 watt space heater, it costs me a whopping .12 per hour to operate. I can afford 12 cents per hour, compared to oil at $3.50 per gallon and a burner that burns up to 3 gallons per hour.
Dec 23, 2012 | Patton Electric Patton PUH680-U Electric...
Can I change out a Hayward H400ID with an electric heater for the spa only? If so what electric heater product brand would you recommned. Raypak?
Hayward has manuals for each type heater, gas and electric.
Hayward also has contact page, and can probably recommend correct change-over product.
You want to switch from propane to heat-pump type.
There are likely 3 areas of difference. Read each manual and generally look for 1) unit size and capability to match spa 2) pipe connections and sizes 3) Electrical requirement
From electrical standpoint, You need GFCI-protected line from circuit breaker box, or GFCI (arc-fault) breaker. This will prevent electrocution risk around spa.
Wire sizes are based on volts and watt-rating of heater.
Each electrical device has rating plate showing volts and watts.
3500 watts divided by 240 volts = 14.5 amps so install double-pole 20 amp breaker and use 12 gauge wire.
1500 watts divided by 120 volts = 12.5 amps so install sinle-pole 20 amp breaker and 12 gauge wire.
Oct 28, 2012 | Raypak Spapak Electric Spa Heater -...
I have installed a Dimplex 1500watt heater. I used a double 15amp breaker and 14/2 wire (I know should've used 12 guage but changed plans post construction and was told 14 would be fine). There is...
A number 12 copper supply cable at the voltage is overkill for this load.
Ohm's Law states: Watts = Volts x Amps. To find Amps: Amps = Watts / Volts. This is 1500W / 240V = 6.25 Amps. Since the max continuous load for a 14 copper is 12 Amps, this size wire is the correct size.
Check to make sure the heater is in fact a 240 volt type, as if it is a 120 volt type, you are likely instantly burning out the heating element. If it is indeed a 120 volt heater, you will need to connect to a single pole 15 amp breaker and place the other wire that was on the breaker to neutral to provide the correct voltage. The load will still be 1500W, but at half the voltage, the current will double to 12.5 amps, and may cause the circuit breaker to trip after a while.
I hope this helps & good luck.
Sep 25, 2012 | Heating & Cooling
I was wondering how many watts the chainsaw would run off if it runs on 120 amps. i would like to use it out in the field but need to have the right amps.
I think you mean 120 volts.
Use a heavy guage extension cord and plug it into a GFCI if you have one outside your house. If no GFCI installed on house, buy a portable one at a hardware store.
The amp draw is on the nameplate on the saw. If it reads 10 amps, for example, you'll need a 16 guage extension cord. If it pulls more than 10 amps, you should use a 14 guage extension cord.
More info, let me know.
Mar 25, 2011 | Poulan 14" Chainsaw
Need to know amp draw for 1VNY1 radiant heater.
on "high" these can draw as much as 1800 watts (or 15 amps.
If there are many other loads on the same circuit, the breaker is likely to trip.
Jan 29, 2010 | Patton Electric Patton PUH680-U Electric...
Motor smokes
If an electric motor is smoking, most likely it is in the process of burning out the windings in the motor. This usually starts from using an extension cord that has too small a wire or a cord that is too long. when you do thid you are forcing the motor to pull more amps than it should to make up for the voltage loss in the cord.
The fuel for the electric motor is a term called watts. Watts equals volts times amps. If the voltage drops then more amps are needed to feed the motor enough watts. This caused the motor to over heat and this melts or breaks down the insulation on the windings. When this happens the motor starts to short out and once this happens then you can not save the motor.
Electric lawn equipment should be used with #14 or #12 (never use #16 or #18 gauge ) guage extension cords and should not be used with cords longer than 50 feet. Also you should not run the equipment more than 10 minutes with out a 30 minute rest.
Aug 27, 2009 | Toro Electric Ultra Blower/Vac 12 Amp
I would like to know how much is this heater minimum watts? Model: 6507L
with one switch on its 700 watts, second switch is 800 watts, thats 1500 total. even though a 14-2 wire could support this ...I would recommend a 12-2 wire with a 20 amp breaker
Mar 26, 2009 | DeLonghi 6507L Oil Filled Radiator Heater
The heater plug melted
Induction coil heaters draw very high amperage (12-14 amps) when turned on. If your outlet is worn or old the heater plug prongs will not have a good connection and the current will jump or arc from the outlet to the heater plug prongs. This arcing causes tremendous heat, enough to melt the outlet and the cord end. First thing to do is change the outlet.
Jan 31, 2009 | Dimplex Compact Electric Flame Stove...
Remington electric tiller circuit breaker goes off
For about $20.00 you can buy 50 feet of 12 guage 3 wire yellow extention cord. You will then get all the amps you need to run your unit. If it still fails, you have a problem inside the tiller.
Tom MN
Jan 30, 2009 | Remington 109312 - 01 Garden Wizard...
Basboard heater installation
if the heater is 120 volt or 240 volt its really pretty easy. at either end is a cover. remove the cover and you'll see a wirenut or maybe just two wires. one side has an integral thermostat. connect your supply to the two wires on the thermostat. connect the other end in your breaker box with the appropriate sized circuit breaker. wire size feeding it will depend on its current draw. how many watts is the heater? 1500 watts will draw 6.25 amps at 240 volts so you can use 14 ga wire. 2000 watts will draw 8.3 at 240 volts - so 14 ga is still ok. 2500 watts at 240 draws 10.41 amps. 3000 watts draws 12.5 amps at this stage I'd use 12 gauge on a 20 amp breaker.
Oct 25, 2007 | Fahrenheat Electric Convector Baseboard...
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
