Im using toshiba aw-9770s.What does overflow rinse means and how it works? i am washing my cloth diapers and it requires extra rinses as possible to wash off the detergent so does overflow rinse help?
gdmisp
  • 66 Answers
SOURCE: hot water doesnt work, switch to warm and warm comes out.
If the cold works on cold wash but the hot don't work on hot wash . Then yes the switch is bad.give What model is it?
Posted on Jan 16, 2009
stephanos18
  • 144 Answers
SOURCE: Leaves white marks on coloured clothes
I'd try putting the machine on a hot fill wash, max water level put in half a cup of baking soda when the machine starts to washer turn it off and leave it to soak overnight, then let it finish the cycle the next day. Also make sure you tip some of the hot water down the beach dispenser and clean all around the top of the machine
Cheers
Posted on Mar 25, 2009
Healeyman
  • 1198 Answers
SOURCE: rinse cycle
If the machine has a soak cycle, you can use that. If it does not, you can have it fill on a cold rinse, and then stop it for a soak. Restart it on a hot wash with a cold rinse. Tumble dry low.
Posted on May 14, 2009
SOURCE: Bleach remains in bleach dispenser after washing and even after extra rinse cycle
I put the bleach in with the load right on top of the whites, so I dont have bleach left in the dispenser for the next load. Seems to work okay.
Posted on Jun 10, 2009
jumptrout51
  • 3361 Answers
SOURCE: Awful noise won't rinse wash or spin, on my whirlpool washer
http://www.youtube.com/watch?v=WLPGs2UMUJc
This video will show how to replace the direct drive coupling that runs the transmission.
Posted on Jul 05, 2009
Clothes not clean after washing
Were the settings appropriate for the clothing?
The settings on the machine should be set properly for the load. Different fabric types require different wash/rinse temperatures, spin speeds, and wash times. Always follow the instructions printed on the fabric care label. The soil level needs to be set in accordance with the load type. Heavily soiled clothing will not come clean with a light soil level setting.
Was the proper detergent used?
If too much detergent is used, or non-HE detergent is used, the machine will not wash properly. Too many suds present during a wash decreases tumbling action and will not rinse out well. Furthermore, detergent residue built up in the machine over time will deposit extra detergent on clothes and deposit soil back into clothing.
Was the washer overloaded? If the machine is overloaded, the machine will not wash and rinse properly. When the washer is overloaded, the clothes have no room to tumble, and the cleaning performance of the washer is reduced. In addition, when the clothes are packed tightly inside the drum the detergent and water will not distribute evenly throughout the items.
Front loaders require regular maintenance to ensure optimum performance. If this maintenance is not followed, residue can accumulate in the drum resulting in detergent and soil being deposited back into clothing. This can also lead to odor and other issues. Perform the required maintenance regularly (once or twice a month).
Jan 11, 2011 | Asko W6021 Front Load Washer
Whirlpool washer won't rinse or spin w/o manually turning knob
It is most likely that you have a faulty water inlet valve. Some machines have a seperate valve for rinse to flush in a fabric softener I suspect that your detergent flushing valve is faulty.....Good luck Nomess
Apr 23, 2010 | Washing Machines
Rinse cycle
May 14, 2009 | Ariston Technologies AWD 129 NA Washer/...
Washing Cloth Diapers with Extra Ingredients
You can strip cloth diapers to help bring back absorbency. I use a simple method of washing clean diapers in the hottest temp possible with blue liquid Dawn dish detergent (1 teaspoon for HE washer, 1 tablespoon for older machines). I also add 1/2 cup bleach because it disinfects and sanitizes. Bleach has always been safe for me but im sure there are alternatives if you don't like bleach. Then a few hot rinse cycles and a regular dry cycle and diapers are more absorbent and odor free.
Mar 29, 2017 | Frigidaire Affinity ATF7000E Front Load...
Disposable diapers
should resolve itself with repeated rinses
Oct 18, 2008 | Maytag EPIC MFW9700S Front Load Washer
Washing cloth diapers
You could, however do not add above the bottom of the door glass. I do this alot on our machine. also use the extra rinse option.
Sep 22, 2008 | Frigidaire Affinity ATF7000E Front Load...
My hotpoint aqualtis smells awful. the smell is coming from the drum. we have taken the pump off and although this smelled it was nowere near as bad as what is coming from the drum.
run a large load with no clothes and no soap. use hot water and a full gallon or more of bleach. do an extra rinse to make sure all the bleach is rinsed out before putting clothes in it again.
Jun 28, 2008 | Hotpoint Washing Machines
How to work my washer?
the timer change by itself. You don't have to change anything.
But cold rinse only works if you have the cold water connect to the washer
May 08, 2008 | Kenmore 24032\24036 Top Load Washer
Washing Machines Logo
94 people viewed this question
Top Washing Machines Experts
