Question about Samsung Televison & Video
BN59-01178W This Samsung remote with fresh batteries isn't working. No lights . no nothing. I tried holding down power button to no avail. And I tried holding each button for 3 seconds with no batteries . Nothing.
ThaMp3Doctor
  • 8596 Answers
SOURCE: Sansa E250 Black screen lighted wheel, wont do nothing else.
These are the most common methods for recovering Sandisk's Sansa Mp3 Players. I have been almost universally successful in recovering Sansa players using one or a combination of these methods. These methods do not work if you are having synchronization or music format issues - they are for recovering a player that will not power up, freezes, flashes, is not recognized by the computer, and a host of other issues.
Reset the Sansa Player first. On most models, restart is done by holding the power button in for 15 seconds or longer. Check your specific manual to be sure. The manuals are available from the Sansa website if they have been misplaced.
Download the Sansa Recovery Tool from the Sansa website.
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/DriverDownload/driverList.asp
If these fail, then:
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
If you get the problem where MTP Device keeps popping up continuously, uninstall the “MTP Device” by going to Start à Control Panel àSystem à Hardware à Device Manager (you computer may vary slightly, depending on Windows Version).
You may have to restart your computer after each of these methods to get them to work properly. Disconnect your Sansa player BEFORE shutting down your computer.
-Tha Mp3 Doctor
Posted on May 25, 2008
  • 1214 Answers
SOURCE: i have a brand new
You may need to recode the remote since you changed batteries, and the newly installed batteries are new, and installed correctly.
Posted on Jan 29, 2009
VtToolMan
  • 704 Answers
SOURCE: Can't start the dishwasher, lock button is lit up.
Hello Albert, On the Jenn-Air dishwasher you have, you have to hold down the "Heated Dry" button for 3-5 seconds to unlock the control panel.
This should unlock the controls so you can again use the dishwasher normally.
Since you''re likely going to have this dishwasher for some time, I've included a link where you can download a free owner's manual for it.
I would print out a copy for your future use and reference. I also have a file on my computer that I title "Home Appliances and Equipment" which is where I download and save an electronic copy so I always have a backup copy saved, since manuals aren't always readily available on the web, as the appliances get older.
http://www.jennair.com/assets/product/6_920374_A.PDF
The info on locking and unlocking the dishwasher can be found on page 13 of the manual.
I hope you find this Very Helpful and best regards!
Posted on Nov 23, 2009
Testimonial: "Thanks for the detailed info about my question, VtToolMan, I greatly appreciate it. However, I tried to unlock it that way, but it didn't work. "
SOURCE: Hunter Douglas Powerrise blinds don't go up and down smoothly
Hello: First of all how old are the shades? Duette/Silhouette? Try raising the shade and then removing the batteries for 10 sec and holding down the manual button for that 10 seconds, then run the shade thru a cycle. Feel free to call I can help you.
Sincerely,
Christy Campbell
Hunter Douglas
CIC Technical Consumer Support Specialist
1-888-602-8059 ext. 3548
Posted on May 17, 2010
  • 3197 Answers
SOURCE: I have a Chamberlain Garage Master 1/3 HP, Model
Your logic board is bad.
Posted on Dec 13, 2010
Ah59-02342a doesn't control tv anymore
Hi I had exactly the same problem with mine it worked the DVD player fine but not the TV even though previously it had worked both .......... Manual Guide In the manual guide I managed to dig out it says to do the following to set up the remote to work the TV
Press the TV button on the remote
Then whilst holding down the power button you need to enter in the samsung TV codes until your TV turns off (I only got to the first and it did it)
The numbers are 00, 15, 16, 17, 40, 43, 46, 47, 48, 49, 59, 60, 98
Hope this helps
Feb 24, 2012 | Samsung TV Remote Control
My samsung remote for my blu ray player stopped working for my samsung TV today. i have never had this problem before. it still works on the blu ray player which then turns on the TV like it is supposed...
On blu ray remote control hold down TV Power+01 at the same time. If the TV turns off the controller is programmed. If not, try TV Power+02, +03, +04, +05, +06, +07, +08, +09. Different TV BRAND??? ...TRY http://remotes.com/remotes/documents/Samsung/AK59-00104K.pdf
Sep 16, 2010 | Samsung TV Remote Control
Samsung DVD (1500) Remote problem.
Try to reset the blu ray player's remote control.
Remove the batteries and hold down the POWER button on it for 30 seconds.
Then replace the batteries with fresh ones
Jul 03, 2009 | Samsung BD-P1500 Blu-Ray Player
My remote will only control the volume it wont do anything else,
Remove the batteries and hold down the POWER button on it. Then replace the batteries with fresh ones.
Jun 28, 2009 | Samsung Remote Control
We own a Sunsung Home Theatre HTWP38. The remote
Remove the batteries and hold down the POWER button on it for 30 seconds. Then replace the batteries with fresh ones.
Hope this helps!
Jun 07, 2009 | Samsung HT-WP38 Home Theater System System
Samsung DVD r135 no reaction using remote control but recorder reacts on remote control from Samsung TV, batteries check. Disconnect the recorder from the power over night no change, still own remote...
Try this. Remove the batteries from the recorder's remote control and hold down the POWER button on it for 30 seconds. Then replace the batteries with fresh ones. It should work fine after that.
If not, the remote control may be defective.
You can purchase a new remote control at www.samsungparts.com
Mar 01, 2009 | Samsung DVD-R135
Samsung BD-P1200 (Bluray) Remote Control stop responding
Try resetting it.
Remove the batteries and hold down the POWER button on it for 30 secs. Then replace the batteries with fresh ones.
Dec 19, 2008 | Samsung (1012861) Remote Control
SAMSUNG TV REMOTE
You better open your remote and clean circuit board inside.Dirt and dust can caused to malfunction of almost all button.When open already brush it with toothbrush with alcohol and dry it with the use of a hair dryer.
Hope thi may help;
DON'T FOGET TO RATE:
Aug 21, 2008 | Samsung TV Remote Control
Samsung TV remote control
I HAVE THE SOLUTION TO THIS PROBLEM.
Confirmed with Samsung tech support. Problem is with remote. to fix, simple take the batteries out of the remote. Press and hold the UP Volume button for 2 Mintues (no cheating, it has to be at least 2 minutes), this Reset's the Remote Control. Put the batteries back in. Bob's your uncle. all fixed.
Sep 28, 2007 | Samsung TV Remote Control
Televison & Video Logo
Jerry Greenberg
Jerry Greenberg
