I have a pyrox space heater stay lite for ten minutes then cuts out is it a over heat switch problem
  • 139 Answers
SOURCE: Hayward H250 FDP Pool heater won't stay lite
sounds like a flame sensor.remove ignitor assembly and clean with fine emory cloth or steel wool.when properly cleaned it should feel smooth for entire length of sensor
Posted on Jun 21, 2009
SOURCE: My Toshiba 32wlt58 cuts out every ten minutes.
I have just had that problem. Repairer said it was a chip in the power supply. Just got the set back this morning, ok for about 6 hours then cut out. Felt quite hot on LHS Will switch on again after a while, then cut out again. Suspect overheating problem took out PSU chip. Chip replaced but original fault still present
Posted on Oct 06, 2009
Testimonial: "Many thanks for your response. I have now left the set with a local repair service, so it will be interesting to see what they say.Thanks for yourtime"
co7196
  • 3433 Answers
SOURCE: draper dhs80i space heater cutting out after 25
Does this heater have a fan,forced heat? If so, the unit will shut down if the fan is sluggish or stops. It could be getting too hot or the rhermal safety is weak.
Posted on Oct 10, 2009
SOURCE: my 441 model monitor heater kicks on but cuts off in about ten
Mine cut off also. I thought it was the wall plug. But as it turned out, I took the cover off the back, cleaned the filter (kinda like a blow dryer clogs in the back) and it is working fine now..... Hope that helps...
Karen
Posted on Jan 04, 2010
roniecon
  • 6927 Answers
SOURCE: Pyrox natural gas heater not functioning properly
Clean the burners out with air pressure,like from a air tank,and a blow gun,then clean the pilot light orifice(this is where the pilot light is)if this does not help,replace the thermocouple ,it will be the problem,if this was at all helpful,please rate,thank you.
Posted on Jun 15, 2010
Testimonial: "Thanks for your help. Have located the problem now thanks. It's the gas line. Strong smell of gas outside. Grateful for assistance. "
Heater won't stay lit
could be caused by many things. could be an flame sensor error, open saftey switch, stack flue error, etc look on back of circuit board and tell me what errors are lit up
Mar 08, 2014 | Sta Rite Sta-Rite Max-E-Therm High...
Living solution
Does it have a timer cut off switch or a heat cut off switch? Sometimes when a heater reaches a pre-set temperature it cuts out, otherwise it could over heat and cause a fire.
Jan 18, 2014 | Heating & Cooling
I have a Pyrox Deluxe Wall Furnace (2011 model) that cuts out every five minutes (it seems). I have both the heat and fan set to the highest setting. I am sitting between it and an electric heater to...
I'm not sure if this is a heat pump or an electric heat unit. If it's a heat pump, it may be low on charge and cycling the low pressure switch. If it's an electric heater it could be limit switches tripping it because of a closed,blocked or improperly mounted discharge flu. It just may be a bird's nest that's blocking it.
Aug 22, 2013 | Heating & Cooling
Jun 15, 2010 | Heating & Cooling
I have a deer born heater will not stay lite
Change the thermal couple (sensor next to pilot)
Jan 21, 2010 | Heating & Cooling
My 441 model monitor heater kicks on but cuts off in about ten
Karen
Jan 04, 2010 | Heating & Cooling
I have 98 eddie bauer ford explorer with headlight problems. Headlights work when first starting up and then about ten minutes into drive the dash lights flicker and then headlights go out. If i pull the...
The headlamp switch will cause the lamps to turn off. The switch heats up and turns the headlamps off. It will cool down and work for about 10 minutes and cut out,
Oct 06, 2009 | 1998 Ford Explorer
Gsw heater pilot stays lit, but when the main
It sounds like your main valve. The diaphram may be loose fitting or it has a small leak.
Oct 03, 2009 | Fasco GSW Hot Water Heater Exhaust Draft...
I have a Comfort Glow propane heater connected a 20lb tank. The pilot has a hard time staying lite but when I do get it lite ang turn the hearter on low it will shut off in a minute or in some cases 20...
If you have a pilot, you have a thermocouple. I would start with the thermocouple. The thermocouple is supposed to be heated by the piolet and to keep the pilot gas on. If it is faulty, the pilot will quit and the heater will not reignite until you light it again. Good luck...Lee
Sep 21, 2009 | Desa International Comfort Glow Infrared...
Laars lite 2 LG or LD Pool Heater- Heater won't stay on
the control module is the problem it allows the heater to come on then turns off power to the gas valve.if you are not getting enough water flow the high limit is turning the heater off then your problem is flow.
Sep 20, 2007 | Lite On Laars Lite 2 Heaters: 250,000BTU...
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
