Question about Vacuums
I want to register a warranty for a POWER bot vacuum.
How do I register my new Shark navigator Lift Away Deluxe to insure the 5 year warranty?
Not sure if that warranty is by Sharkclean or if it was an extended warranty where you purchased the vacuum but Shark's product registration page is as follows:
http://www.sharkclean.com/cgi-bin/livew/site.w?location=b2c/product-registration.w&target=main&frames=no&sponsor=000006
May 29, 2014 | Shark Helmet NV22L Shark Navigator Upright...
Spot Bot wont spray
Not having the machine spray when you need it is frustrating.
Here's a quick link to troubleshooting steps to assist you.
http://www.bissell.com/FAQDetail.aspx?id=1039&cid=ccsocial
Feb 15, 2013 | Bissell 12005 Spot Bot Handheld Vacuum
Spot Bot leaves mold rings
Hey, the mold ring is showing the carpet is now clean in comparison to the rest of the room.
You may want to have the rest of the carpet cleaned using a BISSELL deep cleaning machine or by calling a professional.
Jan 27, 2013 | Bissell 12005 Spot Bot Handheld Vacuum
Automatic Clean on Spot Bot 1200 dosent work
Ted, it can be bear when the auto settings aren't working. One of our service centers can inspect and fix any warranty repairs needed.
To locate a BISSELL Authorized Service Center, please click on the following link:http://www.bissell.com/service-centers/&=ccsocial
Oct 22, 2012 | Bissell SpotBot Robotic Wet/Dry Vacuum
Need bissell spot bot oners manual
BISSELL User's Guides can be downloaded at www.bissell.com
On the front page under Customer Service click on User's Guides and enter the model number of your unit.
User Guide will be displayed as a PDF file.
Oct 04, 2010 | Bissell 12005 Spot Bot Handheld Vacuum
I need an instruction manual or booklet
I could not find a model 12005 but I did find a 1200. You'll find several different manuals for Spot Bots at the link below. There should not be any significant differences among the Spot Bot models.
http://www.bissell.com/searchresults.aspx?searchtext=1200&mode=userguides
May 18, 2010 | Bissell 12005 Spot Bot Handheld Vacuum
Bissel spot bot water not coming out of tank is not a year old and tried manual wand and the water doesn't come out there either. any advice. Is not a year old yet.
you could take the end of the handle off 2 screws i think check the line for a clog or just take it to a bissell service center it will be covered under warranty
Dec 16, 2009 | Bissell SpotBot Robotic Wet/Dry Vacuum
When I turn on the spot bot it immtediately starts beeping and won't stop
A sensor for the motor is malfunctioning. It is under warranty for a year.
Nov 28, 2009 | Bissell 12005 Spot Bot Handheld Vacuum
I bought an spot bot last year. It makes an grinding noise when I clean my rugs. Yes there is liquid in it. where can I have it checked on
http://www.geeksquad.fixya.com/ThreadView.aspx?prdid=49876&thid=544924
I bought a spot bot
Posted by duchie1948 on Apr 25, 2008
Bissell Spot Lifter #1716 Bagless Handheld
I bought a spot bot last year. It makes a grinding noise when I clean my rugs. Yes there is liquid in it.
Where can I have it checked on?
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure.
Depending on what you paid for it would determine the cost of repair and or labor, typically the item has a one year factory warranty and you would have to check with the manufacturer to see what the warranty is and I will list the Bissell Factory Manufacturer below. The grinding noise could be that you have a build up of dirt in the motor or a broken fan blade or fan, and sometimes it may be cheaper to replace it than to repair it due to the cost of the part and the labor to install. Just a suggestion….
So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.bissell.com/ By Phone Customer Service:
(800) 237-7691 Hours:
M-F 8:00 a.m. - 10:00 p.m. ET
Saturday 9:00 a.m. - 8:00 p.m. ET
Thanks, Don – The Vac Man
Go Ahead. Use Us.
Apr 25, 2008 | Bissell SpotLifter 1716 Bagless Handheld...
Vacuums Logo
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
