Question about Cameras
While replacing AA Batteries, it does not make proper contact. i use EVEREADY AA 1.5V 1015R6.
  • Cameras Master
  • 5,412 Answers
Into what item of photographic equipment are you inserting them ? All batteries are the same dimensions, so maybe there is corrosion within your camera.
Posted on Apr 19, 2017
What is the correct globe for the Eveready Model AV425 7 Watt U Tube lantern?
Hi, Check and clean the contacts from the batteries to the lamp.
There maybe corrosion in there. Also the switch maybe bad. Clean and retry. Use a bit of emery paper to clean contacts. good luck.
Jan 12, 2015 | Eveready Camping, Backpacking & Hiking
Change battery
For up to 1000 hours of operation, use Panasonic
LR-44, Ray-O-Vac RW-82, Union Carbide (Eveready) A-76, or equivalent battery types.
For up to 2500 hours of operation, use Mallory 10L14 or D357, Union Carbide (Eveready) 357, Panasonic WL-14, Toshiba G-13, Ray-O-Vac RW-42, or equivalent battery types.
1. Remove slide cover. Place calculator face down.
2. Using a small Phillips screwdriver, remove screws from back case.
3. Pull off back case.
4. Remove discharged batteries.
Caution: Avoid contact with other calculator
components while changing batteries.
5. Install new batteries positive side up, as shown on diagram inside case.
6. Replace back case, and then replace screws.
7. Press ' ! !.
Battery Information
The BA Real Estate calculator cannot hold data in
memory when the batteries are removed or become discharged.
Aug 18, 2010 | Texas Instruments BA Real Estate...
Where do I find replacement batteries for my Braun 4775?
>These units are not really made to be taken apart.
totally false. there are two plugs on the bottom that reveal two T8. loosen those and the shaver slides right open, there's even a video on youtube showing how easy it is to open. The seals are all rubber gaskets, there is no seal that gets "broken" by opening in this way. The batteries aren't even soldered down! pop them out and pop in replacements. easier to replace batteries in this model than most others due to no soldering required. I'm having a little difficulty finding the AA size batteries with the pin ends though, there's someone on ebay right now selling the AAA size with pins, I'm contacting them now to see if they can get the AA that the 4775 uses.
Jul 14, 2010 | Braun 4775 Electric Shaver
Is there a rear cap on a mini maglite. I am
Yes there is a cap. I had the same problem most likely the battery inside has corroded and leaked fusing the cap shut, contact MagLite at www.maglite.com if there were either Duracell, Eveready or Ray-O-Vac batteries in there they will replace it for free under warranty.
May 26, 2010 | MagLite Mag Lite Led 2 Cell Aa Flashlight...
What kind of rechargeable batteries do I get for my camera? Kodax Easyshare C875
You can get any type of AA rechargable batteries. Doesn't matter what brand as long as there are AA. You can get a charger/battery kit from amazon.com or newegg.com
Oct 23, 2009 | Kodak EasyShare C875 Digital Camera
I have a Unitech model PT-815 that will not power up.I received the unit today from my company and it did not come with the lithium ion batteries.I have installed new AA Eveready akaline and it still will...
You have to clean the contact terminals of the batteries, but most likely no longer serve the terminal. You should uncover the terminal and check it thoroughly. If you want to repair it, I have spare parts.
Roberto Martinez
Jul 09, 2009 | Unitech PT815
Camera will not work after Ni-MH and Ni-Cd batteries used
Its not good for the batteries to combine different types but it shouldn't have affected the camera as the voltage they produce is the same. Try a couple of Eveready AA lithium batteries.
Feb 10, 2009 | Panasonic Lumix DMC-LZ7 Digital Camera
Batteries
The E-10/20N battery holders are designed to fit the longer type CRV-3 lithium batteries and conventional sized AA NiMH batteries. Once installed into the battery compartment the AA sized batteries will make an electrical contact with the camera
Aug 31, 2005 | Olympus Camedia E-20N Digital Camera
Coolpix 2200/3200 Battery Compatibility
The Coolpix 2200 / 3200 camera is designed to use 2 (two) AA type batteries. Due to Nikon’s advanced power management technology, two standard AA Alkaline batteries can provide more than 100 photographs. For better performance, please consider using Nikon EN-MH1 rechargeable batteries. These are available as an optional accessory at Nikon dealers and at The Nikon Mall Recently a new type of battery, the CR-V3, has been released to the market from several battery venders. The CR-V3 is similar in shape to two connected AA batteries and easily fits in your Coolpix camera compartment. Nikon has confirmed compatibility only with the following battery brands. Please use one of the following brands when using CR-V3 type batteries. Duracell Sanyo Panasonic Due to it’s unique design the Eveready Energizer® brand CR-V3 battery may not be compatible with the Coolpix 2200/3200 camera.
Aug 30, 2005 | Nikon Coolpix 2200 Digital Camera
Aug 30, 2005 | Nikon Coolpix 3200 Digital Camera
Cameras Logo
35 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
