Question about Dell Computers & Internet
20 inch 2005 Dell monitor. Pressed one of the buttons, and now cannot get back to # 1 setting (RGB). No image on the screen. How do I fix this?
    Master:
  • Dell Master
  • 247 Answers
Call Dell customer Support Number 1-800-204-4427 if your dell laptop, computer, printer and tablet facing technical problems. Our dell technical support experts will help you out within no time. And much more visit my site :
Dell Technical Support Phone Number 1 800 204 4427 USA Canada
Posted on Apr 19, 2017
My DELL LCD MONITOR E178FP is locked, when i press menu button, on screen it displays lock symbol
Zaheer khan,
To unlock the monitor controls and get rid of the lock you can press and hold the menu button in for 20 seconds. You can also try the information listed in the link below.
http://www.paulstravelpictures.com/Dell-LCD-Monitor-Flashing-Padlock-Icon/index.htm
Thank You,
Dell-Jesse L
Dell Social Media and Communities
Mar 28, 2015 | Dell E178FP 17 inch LCD Monitor
Dell E1909W The color of the screen changed to red
This could mean a broken, loose, bent pin(s) in the vga connector.
Check it first. Try changing the vga cable if your monitor is a lcd flat. These comes with a detachable cable but not on the crt monitors which is fixed.
If you can find the menu button on the monitor. Go to input configuration. The setting could be on "ypbr" setting which is a component setting just like your dvd player. Set it back to "RGB".
Or it could also be that your monitor board is starting to be damage. Sorry to mention it, but possibilities are many.
Good luck mate.
May 06, 2014 | Dell E1909W 19 inch Monitor
My 20 inch dell monitor is only using the left corner the screen and you can only see part of the desktop is visable and the text is upside down.
mcdevito75 here, Press the AUTO button on your monitor, if this does not work, press the MENU button, there you should see a square box with 4 arrows, these are used to center your picture on your monitor, use the left / right arrows also on your monitor to adust the screen picture with this box woth the 4 arrows from Menu.
Jul 16, 2010 | Dell ST2010 20" Monitor
Apple multi scan 20 display. Screen works fine but green is predominant. How and where do I adjust the green intensity?
This can be adjusted by the RGB settings on the menu (monitor setting menu button on the monitor), Brightness color contrast also helps.
That is providing that its the settings thats causing your problem. In my experience the VGA cable sometimes shorts out producing that green hue. You may need to shake the cable a bait to see if it clears up or causes weird iterations. Once this happens it means the cable is shorting. It could be a broken solder to a broken wire. Replacing the vga cable and resoldering the connectors inside the monitor (where the cable jack connects to the main board) fix's the problem.
Feb 25, 2010 | Apple Multiple Scan 20 20" CRT Monitor
Power button stuck in off position on Dell Flat screen Monitor
Does the button move at all? What model LCD is it? Most of the time if the monitor does not power up it is the power supply inside the monitor not the button sticking. The power supply can be repaired if that is the problem. Please let me about the movement on the power button and I can help you get back going with your monitor.
Buddy
Corporate Computer
Jun 17, 2009 | Dell E176FPC Monitor
I pressed rgb on the remote-now i cant get out of that mode
Have you tried changing the TV to another input? Try Press "TV" at the top then press "TV" near the bottom or try pressing the "INPUT" button on the TV itself until you get to TV. RGB is just another input for the TV, just like DVD or HDMI or VCR, but it is the plug in the back for a computer monitor. Yes, if you'd like to hook up your computer to your TV you can through this plug, it looks like a (most likely blue) with 3 rows of holes/pins that you can plug another RGB cable into your computer and have the biggest computer monitor on the block! haha Although, if you have a PLASMA TV (not LCD) you can't use a computer for long (no more than 15 mins) because PLASMA TV's have a tendancy to "burn-in" very easy and it is sometimes not fixable. You'll have a ghost image of any stationary image that is on the screen for too long. That goes the same for any news channels with a "ticker tape" near the outside edge that is on the screen the whole time. If you have LCD, no worries! They're designed just for that problem to never happen. Hope this helps.
Feb 21, 2009 | Vizio L37 Television
61 Hitachi Ultra Vision has double image
Replace both of your STKs big black ics If they are STK392-110s upgrade to 180s better ics Electronix has them call 1-800-223-3205
Dec 18, 2008 | Hitachi 61SDX01B 61" Rear Projection...
Entire image shifted
Press the Select/Auto button. The monitor will then automatically adjust to match the incoming signal and will save that setting in the internal memory of the monitor.
Nov 06, 2008 | Hyundai L90D+ 19" LCD Monitor
Using TV as computer monitor
Same problem!!! Inspiron E1505 connected to a year old LG 47" 1080p lcd. My rgb used to work fine, plug and play with my pc. No luck with my laptop though. I've tried setting up duel monitors, updating all(atleast I think all) of my drivers, and rechecking all connections!! Please Help.
May 06, 2008 | Televison & Video
19" starlogic monitor
If you are getting a "No Signal" message, someone may have inadvertantly pressed the wrong button on the monitor. Use up arrow of button #5 below to cycle through RGB (normal VGA connection) and DVI sources. Down arrow will result in "No Signal" message.
There are five buttons at the bottom of the screen on this monitor. From the left:
1 - sound volume
2 - degausser
3 - power on/off
4 - monitor set-up
5 - RGB/DVI source
Nov 20, 2007 | Star Logic 17" LCD Monitor
Computers & Internet Logo
Alun Cox
