Question about Vizio Televison & Video
I have misplaced 2 of the 4 phillips head screws on the 50" Vizio that are used to attach the stand to the screen. Can you tell me the screw to look for at Home Depot?
  • 27 Answers
SOURCE: Lost Screws for stand for Insignia IS-LCDTV32 32
they are couse scews your best bet is go to lowes or home depot and get a few of each 1/4 inch screws to see which one fits they only cost about .03 each
please rate my answer it is much apreceated
Posted on Feb 13, 2009
  • 6 Answers
SOURCE: Lost screws for stand on Vizio VU42L
If you pay for shipping I will send you my screws. Maybe a buck or two will cover it in an envelope. I just removed them last night as the TV is being junked for the parts. Email me.
MBSimonds AT aol DOT com
Posted on Mar 31, 2009
  • 148 Answers
SOURCE: need screw specs to attach base assy to tv
I
Hi there, if you are trying to just remove the base, then on your model there is one screw in the center of the underside of the base. If you want to remove the neck of the base to then remove the 8 screws on the back of the tvs neck too. I hoped this helped, please rate thank you!
Posted on Feb 05, 2010
SOURCE: Missing screws for detachable stand
www.searspartsdirect.com ,base screws #4x26 tap part#172100042650 $2.16 there in stock
Posted on Nov 05, 2010
SD Tech
  • 14553 Answers
SOURCE: screw size for attaching stand for Sony Bravia LCD TV model# 46W4500
while the owner manual does not specify the length etc of bolts it does show there are 4 of them---look like find thread machine bolt---may be able to buy a few at the hardware sore or Home Depot---if the threads are inside the base take it with you as a guide.
http://download.sony-asia.com/consumer/IM/4106869131.pdf
pretty stupid as owner manual has everything including dimensions and weight etc but no list of bolts size.
Posted on May 20, 2012
I have a vizio E422vl and need screws to attach it to a stand anyone know what size screw I would need
Yadayada is wrong, the screws are listed on page 2 of the manual, you need metric. M6 20x1MM
If you need to buy the stand, the pattern is 200x200MM
Sep 27, 2016 | Vizio Televison & Video
How do I remove the stand to put my LT19C300 Samsung on the wall
Look for holes in the back of the TV just above the stand. There are screws in those holes that hold the stand on. Shine a light in one to see what kind of fastener it uses. Some are phillips head screws, some use hex head screws. Locate the tool necessary to remove the screws and take all of them out. Have someone help you hold the stand while you lift the TV off the stand.
Mar 02, 2015 | Samsung Televison & Video
How do I remove the stand from a toshiba 32hl57 tv
  • 1 & 2 Remove all cables and lay down towels on a clear space.
  • 3 Set the 32HL57, screen side down, onto the towels gently.
  • 4 Locate the four screws at the bottom center of the TV. These screws attach the stand to the Toshiba 32HL57.
  • 5 Using the Phillips screwdriver, unscrew all four screws, one at a time.
  • 6 Once the screws are completely removed, grab the base of the stand and gently pull away from the TV.
  • Read more : http://www.ehow.com/how_7318172_remove-stand-toshiba-32hl57.html
    Jan 20, 2015 | Toshiba Televison & Video
    Missing screws for detachable stand for Vizio VO320E. How can I find replacement screws?
    To get the details of exact size of these screws, you should download its repair manual. The disassemble section of that manual will have all these details. If you wish to get more details, check this link. http://electronicshelponline.blogspot.com/ Selecting the view option, either to Mosaic / Time slide, can be selected by the drop-down list, at the top left of the display window, will make surf easy. You can also do a search, by type in the brand name/model number/IC used, in the search box at the top right of the display window.
    Oct 20, 2013 | Vizio SV421XVT 42 in. LCD TV
    Need Vizio E321VL TV Stand Screws
    I have a M420VT Vizio TV. I used (4) M6-1.0 x 16mm screws to attach the stand to the TV stand adapter. The screws I used to attach the adapter to the TV were (3) M4-0.7x12mm. It worked out perfectly!
    Feb 19, 2012 | Insignia Televison & Video
    LCD screen totally white when turn on
    The HP is a flat screen monitor used with many desktop computers. When the LCD on your HP monitor goes white, it is an indication that your monitor's inverter board has gone bad. The inverter board is a small circuit board that transfers power from the monitor's main circuit board to the LCD screen. Replacing the inverter board means dismantling the HP monitor.
    1. Power down your computer and unplug the HP monitor cable from the back of your desktop. Disconnect the power cable from the back of the monitor. Relocate the monitor to a flat work surface. Place the monitor with the screen facing downward.
    2. Remove the Phillips-head screws from the monitor's base stand and from the back cover. Lift the base stand off of the monitor and remove the back cover. Peel away the foil from inside the monitor around the internal circuit board.
    3. Locate the inverter board near the bottom of the monitor's casing. Unplug the power cables from either side of the inverter. Loosen the Phillips-head screws from the inverter board. Lift the old inverter out of the monitor's casing and set it aside.
    4. Place the new inverter inside the monitor. Replace the Phillips-head screws and fasten it in place. Reconnect the power cables to the connectors on each side of the new inverter. Replace the foil around the outside of the main circuit board.
    5. Replace the back panel and base stand, and their retaining Phillips-head screws
    I hope you find it very helpful.
    Thank you for choosing fixya.com
    Aug 11, 2011 | HP Computers & Internet
    Mar 26, 2009 | Vizio VU42L 42 in. LCD TV
    AOC lm929 monitor
    AOC LM929 or Envision EN-7100 removal instructions:
    DANGER!!! UNPLUG and allow the monitor to discharge before servicing.
    with a small flat head screwdriver, insert into the edge and pop open the small plastic
    pieces that surround where the stand connects to the monitor. put plastic pieces aside.
    lay monitor on soft flat surface front side DOWN. with a phillips head screwdriver,
    remove 4 screws in the center that hold on the stand. put stand and screws aside.
    lay monitor on soft flat surface front side UP. insert flat head screwdriver into the
    side edge of the grey plastic and turn screw driver so the plastic surrounding the
    screen edge pops up exposing an area surrounding the screen. put plastic rectangle
    piece aside.
    slide out plastic buttons piece from the side and put aside.
    with a phillips head screwdriver, remove 8 screws (4 on top and 4 on bottom) that hold
    the screen assembly to the back housing. now lift screen assembly out of the plastic
    housing. put back plastic housing and screws aside AND lay the monitor screen with the
    FRONT side down on a flat soft surface.
    with a phillips head screwdriver, remove 2 screws that hold on the metal electronics
    cover. slide the cover down and remove. put the cover and screws aside.
    USE CAUTION!!! Some components may still contain a charge.
    check fuse... whatever...
    Aug 29, 2008 | Computers & Internet
    Televison & Video Logo
    Top Vizio Televison & Video Experts
    Computer Repairing
    Computer Repairing
    Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
