Question about Kitchen Ranges
My baby touch the canmera i can fixed it its says out of range can u help me please
  • 711 Answers
Must have broken antenna
Posted on Apr 19, 2017
Why does it keep "saying" out of range?
if camera and base are within a few feet of one another does it have a problem obtaining a signal (syncing ) ?? as if it works ok then there might be a object that is getting in the way of the signal , radio waves move from its transmitter (camera) towards its receiver (monitor) in a straight line , if there is too large a mass in the way then the radio wave can't penetrate it and will be "lost" also ck both the camera's and bases battery levels (if they have one) for proper peak power level , as it takes energy to drive the radio signal towards its receiver .
Feb 09, 2016 | Summer Infant Secure Sight Handheld Color...
When I push the on/off button on my model 790.36603603 Kenmore 30" range, I get a fault code"F14". Any hints on how to fix it? The sears repair guy showed up and unplugged/replugged the...
Sorry to read about your problem with the f14 code.
You have a keyboard issue.
1. Check/reseat ribbon harness connections between keyboard touch panel and EOC..
2. Test keyboard circuits using test matrix (below). Replace touch panel if defective.
3. If keyboard circuits check good replace EOC.
I have tried to help you.Please help me by vote/rate my response. Thanks and good luck.
If you live in the Denver Area I can help you.
Dec 23, 2010 | Frigidaire PLEF398AC Electric Kitchen...
When I press bake and start it beeps and gives me a code of F1, can you please help me figure out how to fix the F1 so I can have an oven?
F1 touch pad / ERC test This simple test will help determine whether the ERC (Electronic Range Control or Clock) or the touch pad is defective when F1 error code is present.
Note: Some models incorporate the touch pad in to the ERC as a single assembly, in which case this test is not necessary. Simply replace the ERC (Clock).
Warning: If you feel in any way uncomfortable performing this test or making this repair, please contact a qualified appliance repair technician.
1. Disconnect power to the range (unplug the range power cord or turn the power off to the range at the circuit breaker). It is very important that the power to the range has been disconnected, so please double check before continuing.
2. Gain access inside the control panel.
3. Disconnect the touch pad (also called keypad or membrane switch) ribbon from the ERC.
4. Make sure there are no lose wires, or anything else that may cause a short when power is turned back on. Assemble the control panel back the way it was.
5. Turn the power back on.
6. Wait for at least one hour to see if the F1 code comes back (usually accompanied by a beeping sound).
7. If F1 comes back, replace the ERC. If it does not, replace the touch pad.
Nov 25, 2010 | Whirlpool RBS305PDS Electric Single Oven
Jenn air range model # jds9860acp fault code f1
i need your help someone please my jenn air oven does not heat up quickly at all it takes for ever to get to 250 i have replaced the sensor and the touch pad still no fix can anyone suggest anything else
Nov 09, 2010 | Jenn-Air JGS8750ADS Gas Kitchen Range
Model 5770ACW 19401490Z. An hour into self cleaning I heard a beep and a F1 appeared on the screen. Can you tell me what happened and what I need to do to fix the problem. Thank you
Sep 11, 2010 | Maytag MER5870 Electric Kitchen Range
What is error code F1? Can I fix it myself?
Sep 07, 2010 | GE Kitchen Ranges
The Alarm keeps buzzing to my Jenn Air ww2780w wall oven. The code reads F1. What can I do to fix?
Defective touch pad or clock (ERC)
Replace touch pad or clock (ERC). Touch pad is a more common problem.
You can use the test procedure below to narrow the actual issue.
Jul 09, 2009 | Ovens
How do i fix an F1 error on my magic chef 6498xrs.
Hi this f1 error code indicates a bad touch pad or bad electronic oven control, if you have a touch pad on this model unplug the range, access the control panel and remove the ribbon or wires from the touchpad to the e.o.c making sure nothing is going to short plug the range bac in....If the error code clears and does not come back after say a couple hours it's the touch pad and needs to be replaced, if the error code reappears then it is the e.o.c and although more expencive needs to be replaced...I hope this helps you.
If you have any other questions please feel free to post again...Good Luck!
Jun 23, 2009 | Kitchen Ranges
KX-TG2632 causing static to my baby monitor.
Baby monitors apparently are all on 2.4GHz frequency range. Phones have to be either beneath ie 1.8GHz or above eg 5.4GHz and no interference will occur. So simply had to change the phone because its frequency range was 2.4GHz.
May 27, 2009 | Panasonic KX-TG2631 Cordless Phone
F1 Error Code on MayTag range
migs, on a Maytag the F1 indicates there is a problem with the touch-pad or control itself. Usually, it's the touch pad. Try killing the power to the range and remove the touch pad ribbon from the control board. Clean it with an eraser. Power back up and see if the error comes back. If it does, remove the ribbon cable again and power up with-out it attached. If the same error still returns, then I would suspect the control board itself. Catriver..post back.
Jun 05, 2007 | Maytag MER5875QA Electric Kitchen Range
Kitchen Ranges Logo
22 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
