Question about IFB Washing Machines
IFB Front End loading machine shows H6 error - IFB Washing Machines
  • 641 Answers
SOURCE: error codes for indesit front load washing machines
The F002 error codes relates to a motor problem. Do you know if the motor spins ?
Posted on Aug 16, 2007
rockfixya
  • 679 Answers
SOURCE: washing machine error code h6
hi,
seems a spade connector had dislodged itself from the back of the machine reattached and all works seems it was a heat problem.
Hope this helps
please give me a FixYa rating if the solution works.
Thanks
Posted on Jan 04, 2009
  • 6277 Answers
SOURCE: my ifb washing machine digital
You will need to type into your search engine the '(make) washer manual' and you should be presented with a number of sources from which you can either download for free or have to pay a nominal amount. During the process you will be asked for the actual model number!
Good luck,
John C
Posted on Feb 13, 2011
ercupa190
  • 12223 Answers
SOURCE: H6 error code on a NEC NFL-1065 washing machine
see this causes, and fix it. God bless you
If the washer stops mid cycle the timer might be defective. This part is often misdiagnosed, check other components before replacing this timer.
f the washer stops mid-cycle the main control board might be defective. This is not common. Check other causes first such as the lid or door switch and other components
f the washer stops mid cycle the water inlet valve cold water side may have failed. Most washers have a cold water rinse and so if they can't fill with cold water they just sit indefinitely waiting for the cold water to enter. If there is cold water to the water inlet valve and the cold water works in other parts of the cycle - or to make warm water - the valve is not the problem.
If the washer stops mid cycle the door lock assembly should be checked. The door lock can fail either mechanically or electrically. Test any switches on the door lock with an Ohm meter. The switches should have continuity according to their design
If the washer stops mid cycle the lid switch assembly might be defective. This is a very common problem. The lid switch assembly can fail either mechanically or electrically. Test any electrical switches with an Ohm meter for continuity. The switches should have continuity according to their design.
Posted on Sep 26, 2012
  • 45 Answers
SOURCE: We have an Atria 3000 EKG machine. It is displaying the message "Front End Failure" Help!
It's a guess but I think the "keyboard" and its associated processing parts are fried from a staticelectricity charge hitting the unit. See page 4-8 of the linked manual which references a "Front End Digital Board".
Good luck if you try to repair as Motara issued an End-of-Life notice effective 8/1/13 so no official repairs or parts are available (second link).
http://photos.medwrench.com/equipmentManuals/5658-3399.pdf
http://www.mortara.com/index.php?eID=tx_nawsecuredl&u=0&file=fileadmin/user_upload/support/International_Distributors/Marketing_Support/Product_Notifications/EOL_Atria_3000.pdf&t=1417648515&hash=d8f9cc5b3b87eb25ec9120c5c6f38825
Posted on Dec 02, 2014
In the IFb front loading washing machine,the error "heat" is come what will the solution?
Hi, your thermostat may be faulty, call your supplier, they will give you advice for free
Apr 04, 2018 | IFB Washing Machines
Hi i have use ifb front load washing machine but showing e7 error on display
go to the manufactures web site and download the user manual and look in the trouble shooters section to find the answerer
Jan 17, 2018 | IFB Washing Machines
My ifb front load washing machine is showing door error, how can i rectify it
the door is not closing properly so not making the door switch contact to tell the controller to go to the next cycle replace the door lock problem solved eric
Dec 22, 2017 | IFB Washing Machines
I have IFB washing machine it shows E7 error
1:IFB Washing Machine Not Turning ON OR Turns ON But Does not Starts. 2:IFB Washing Machine Door Does Not Opening. DE Error 3: Water is not coming inside the IFB Washing Machine Inlet problem 4:Water is Leaking from the washing machine, drum or hose pipe damaged 5:Wash is not happening / Spin not Happening in the IFB Washing Machine 6:Drum NOt rotating or Drum Making Huge Sound while spin cycle, 7:Water not Draining From the washing Machine 8:Burning smell, Tripping Problem, etc https://electronicshelponline.blogspot.com/
Read more: http://ifbservices-com.webnode.in/error-code-fault-codes/
Aug 05, 2016 | IFB Washing Machines
In IFB front washingmechain AC h1 error is coming what to do
AC h1 is actually AC hi error which means input voltage is too high. Wait for sometime for voltage to stabilize Washing machine will automatically start. If not call electrician to check electrical fault for high voltage
Jul 03, 2014 | Kenmore Elite 45986 Front Load Washer
IFB washing machine front load Showing ' Lo' what
Error code LO normally means the filter is blocked. this would be the best place to start. refer to your owners manual for instructions on cleaning this.
Aug 10, 2013 | IFB Washing Machines
Ac voltage become hihg or low when start ifb washing machine
We got a IFB front loading washing machine last week only after 3 time wash 4 th day it is showing AC-LOW message . the service people came and went but nothing is done what is the next solution?
Same point top loading Godrej 6.5 kgs working fine but water consumption is more in that compared to front loading machine so pls sugeest good solution at the earliest.
Sep 30, 2012 | IFB Washing Machines
Washing Machines Logo
Top IFB Washing Machines Experts
Eric Taylor
Eric Sutherland
Ken Strite
Ken Strite
Are you an IFB Washing Machine Expert? Answer questions, earn points and help others
