The picture is dull when tv is on is their any way to brighten the sceen
2 Suggested Answers
  • 92 Answers
SOURCE: my display is dull. How do I brighten it up?
If you have graphics control application on the computer from the video hardware manufacturer you can usually turn up the brightness using that. If that is not present or possible then the backlight inverter board needs to be replaced.
Posted on Jan 28, 2010
Very dull screen, will not brighten.
When you installed Windows 7, did you also install the drivers for the graphic card?
Jun 19, 2013 | Acer Aspire 3690 Notebook
Tv dark
It is possible the lamp this set uses is about to fail--they will sometimes go dim just before failure--lamp usually is customer replaceable and if you take a look at it--may be funny looking or somewhat dull looking.
May have to replace it (not cheap) for answer.
Apr 10, 2012 | RCA HD50LPW175 50" HDTV
The Picture on my HD-52G886 Model is really kind of dark I can still see the picture and sound is fine but a little to Dark when I try to brighten it then its really dull white.
Changing the contrast will also help brighten your screen. For best results, try changing the contrast and the brightness, to find the perfect combination for your needs.
Jul 19, 2011 | JVC HD-52G886 52" Rear Projection HDTV
Hello, I got this Model in 2006 and my picture has got dimmer and dimmer. Is their just one bulb that needs to be replaced, and is it the bulb? Thank You!
there is more than one bulb, you need to call samsung to find out just how many. the bulb can be the primary fault , however all plasma tv's will dim more and more over time. It has more to do with the plasma panel though. replacing the bulbs may brighten the picture some however if it were only the bulbs you would have no picture at all. my personal opinion in this case would be to not replace the bulbs, i doubt that will solve your problem even if it does brighten the picture some i doubt it will produce the solution you are seeking. plasma tv's are great but they do have drawbacks, like the bulbs needing to be replaced and the fact that the panels get burn in . the problem you have is more to do with burn in than it does the bulbs. even thought there is no static image in one place ( what people think burn in is only ) the entire panel has " burn in " slightly which dulls the screen. i suggest buying a new tv, lcd or lcd/led to avoid this in the future. you can try to use the same thing they do to fix actual burn in of a static image, that may brighten the screen a little, however in some instances that is the culprit. to truely explain all this it would take a very long time , look up burn in on the internet and read about all the causes and solutions, you will then understand in a rather short period of time.
Jan 09, 2011 | Samsung HL-S6187W 61 in. HDTV
Can i brighten tv picture with the urc-4220?
Hi ,
If you are using the URC 4200 remote for TV then you can brighten your picture.
Press MENU it will show the selected device main menu,From there you can adjust brightness.
Thanx
Jul 22, 2010 | One For All URC4220 Remote Control
All of the people are red and I have no blues and green
This is a fluid problem...in the lens...
  • Dull looking picture
  • White looking picture
  • Halos around objects
  • Red/Orange looking picture
You can see some more examples and find a fix here
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Mar 28, 2010 | Philips 55PW9363 55" Rear Projection...
The screen is very dull you can only just see it
Have you tried adjusting the screen's brightness? There should be two buttons with pictures of fading and brightening suns on them to adjust this.
Mar 20, 2010 | Sony VIAO P4 PCV-RS712 3.0GHz 512MB 200GB...
My display is dull. How do I brighten it up?
Jan 28, 2010 | Samsung N120-12GBK Netbook
Philips 60p8342 projection tv 1)Color distorted, whitish and dull 2)Picture bowed at top and bottom 3)Set turns off by itself 4)I can't turn on set unless its been off and unplugged for many hours and then...
These sets have several common problems listed below.
Problem #1) Convergence
Symptoms:
  • Screen Looks Distorted/3D
  • Colors wont align
  • Screen may look distorted
  • No Audio/Video - makes a chirping sound.
Problem #2 CRT Fluid has clouded over. Symtoms
  • Dull looking screen
  • White looking sceen
You can see some examples and find a fix here...
Jan 16, 2010 | Philips 60P8342 60" Rear Projection...
Toshiba telivisions picture brightens
It has a bad solder connection inside the set. Requires qualified individual to find the connection and resolder it.
Jan 02, 2008 | Toshiba 36AF62 36" TV
Televison & Video Logo
21 people viewed this question
Top Televison & Video Experts
