Question about Coleman Air Tools & Compressors
I am wanting to know what this one is worth. "27 gal, 5 HP, 115 volts oil free operation. Coleman power mate black max air compressor?
  • 947 Answers
One sold on ebay for $125.00. It is made by sanborn. Sell locally
freight charge will make to expensive
Posted on Apr 19, 2017
  • 7 Answers
SOURCE: i need an operators manual for a Blue Max
Go to hondaengines.com and down load the manual you need
Posted on May 08, 2009
  • 98 Answers
SOURCE: I need a owners manual for a coleman black max
See if this will work for you
http://dl.owneriq.net/1/11e69d39-6fc9-4519-b1f9-268078941160.pdf
Posted on Jul 22, 2009
  • 84 Answers
SOURCE: Black Max air compressor (old coleman model)
Needs 30W Non-detergent oil, and if there is a sightglass, fill to half-way up that glass. Otherwise, try mastertool repair or need a manual websites.
Posted on Nov 26, 2009
  • 885 Answers
SOURCE: i have a 60 gal
You need to use compressor oil, sounds simple but that's what it's called. It's a non detergent oil designed for compressor pumps. Senco has it under part number PC0344, Campbell Hausfeld has it under part numbers ST125312AV & ST125303AV. Make sure you don't overfill the pump; more is not better with compressors. Too much oil makes the compressor and motor work harder.
Posted on Dec 17, 2010
  • 1739 Answers
SOURCE: I want a operators manual for a coleman powermate
You should be able to download a manual from this site:
http://www.powermate.com/productmanuals.php?cat_id=1
The VLF1582019 is a 20 gallon model but you should confirm if this is the model number of your unit.
Posted on May 23, 2011
What oil do I use for a G Force 2 HP air compressor, model 50622
  • www.air-compressor-guide.com/.../air-compressor-oil Keep your compressor in top condition by using the right air compressor oil. Make your compressor run nice and smooth. Using the right air compressor oil for your ...
  • Oil - Air Compressor Oil ' RONA www.rona.ca > ... > Parts and Accessories - Compressors Compressor oil. 473 ml. For all oil lubricated air compressors.
  • Husky 16 oz. Air Compressor Oil-HDA10700AV - The Home Depot www.homedepot.com/p/Husky-16-oz-Air-Compressor-Oil-HDA10700AV/...
    • 5/5
    • 1 REVIEW
    • $2.49
    • IN STOCK
    Air Compressor Oil from Husky is designed to reduce carbon buildup in compressor valves to ensure a longer compressor life.
  • Air Compressor Oil & Lubricant www.ecompressedair.com/compressor-oils.aspx eCompressedair is your source for Air Compressor Oil & Lubricants for major air compressors and synthetic compressor oil brands in 5 gallon air compressor oil ...
  • Oil-free air compressors - Atlas Copco Canada www.atlascopco.ca/caus/products/air-and-gas-compressors/1472896 Oil-free centrifugal compressors. Oil-free reciprocating piston compressors. Oil-free rotary tooth compressors. Oil-free screw compressors. Oil-free scroll compressors
  • Air Compressor - Oil-Free Air Compressor ' RONA www.rona.ca > ... > Products > Tools > Pneumatic Tools > Compressors Air Compressor - Oil-Free Air Compressor. Oil-free air compressor. 26 gal. Vertical, saves 50% more space. 1.7 running HP. 120 V. 15 A. Easy to operate controls with ...
  • May 17, 2016 | Air Tools & Compressors
    Looking for manual for sanborn B51-A24-80V1 model
    PDF]Sanborn Black Max 5hp Air Compressor Manual B51 A24 80 1
    intrigante35hindu.strictlyyouth.org/rzsatzo_sanborn-black-max-5hp-air-...
    Jul 16, 2015 - Sanborn Black Max 5hp Air Compressor Manual B51 A24 80 1 ... Black Max Portable Air Compressor - 5 gallon Item #: 81527 ' Model #: BS0880504 ...Compressor Manual: $4.95: Buy Now: B51-AT24-80V,B51-A24-80V1.
    Aug 28, 2015 | Air Tools & Compressors
    My air compressor gets HOT when you run it for 10 to 15 mins. ,I mean HOT,not the motor but the compressor pump and it kicks the breaker.I have a 6.5 hp 80 gal. Black Max two stage pump by Coleman, can you...
    Sounds like you have a rod or maybe a bearing bad or possibly a piston starting to seize. Maybe all may be on the way out. Have you checked the oil. Is it at the proper level. These units are not pressure lubricated but splash lubricated. So when the rod goes to the bottom of it's stroke it hits the oil in the crankcase and splashes oil thru out the unit. (simply explained) Also if these units are only used a short time condensate can build in the crankcase. Then you're trying to lubricate with water. If it's binding bad enough to trip the breaker I would say it's to late to try and save. Unless it's still under warranty the only solution is to disassemble and repair,or replace depending on the damage done. Good luck!
    Jul 25, 2011 | Coleman 6.5hp - 80 Gallon Vertical ASME...
    I want a operators manual for a coleman powermate air compressor 20 gal tank
    May 23, 2011 | Coleman Powermate 02 - Gallon Air...
    Hi everybody i have a coleman powermate 5 hp ,27 gal. compressor that is about 5 years old . i would like to get some help with it. i really don't know what is wrong with it it only runs for about 30...
    parts are available from any motor repair /rewind shop
    capacitors are only specific for capacitance and voltage and can be obtained from the same shops or from e-bay
    the pressure switch only switches the motor on and lets run until the full pressure is reached
    it then switches off but switches back on when the pressure drops around 10 psi
    If it was doing that there will be nothing wrong with the switch
    if all else fails and it is a belt driven compressor get a new motor
    The brand on the motor is immaterial as long as it is 5 hp or bigger and has the same voltage rating requirement
    Mar 09, 2017 | Coleman Air Tools & Compressors
    Need to know how to put the wires in the right order on a AO Smith 5.0 56 spa pump red white and black
    Red and Black should each be connected to the individual power legs, for 230 V operation. The white wire should be connected to ground.
    Nov 25, 2010 | AO Smith 2 Hp Spl 3450rpm M56 Frame...
    I need to replace the belt on my 5 HP 120 volt 27 gal tank Model WL660001AJ Air compressor. I don't know the part number on the belt, or where to purchase. Can you help?
    Hi, my name is John. Welcome to FixYa. Take the belt with you to most any auto parts store and they will match one up for you. Thanks for choosing FixYa...John
    Nov 19, 2010 | Campbell Hausfeld 26 - Gallon Air...
    I have a Coalman Powermate 6.5 Hp 60 gal. compressor model C650C600VIB103. I want to know to connect the elect. cord correctly.
    Does the unit have a starter or just a pressure switch , if just a pressure switch it should be marked with line and motor , the wires on the motor should go to the motor terminal and the line terminals are the power supply , if the unit is 110 volts make sure you put the wires on by color , the white wire goes to the motors white wire and the black to the motors black wire , if this is 220 volts it does not matter which wire connects just put the two black wires on the line terminals. One wire per terminals please.
    Jul 17, 2009 | Coleman Powermate 60 Gallon Air Compressor
    Wires on Compressor motor disconnected.
    Some compressors come unwired so the purchaser can wire for 110 or 220 by their choice. This I would think would be possibly your case. Was this purchased new? In any case, here is a site where you may be able to obtain a manual,
    http://powertool.manualsonline.com/manuals/mfg/coleman/coleman_air_compressor_product_list.html
    and here is one with a similiar description but a different brand compressor.
    http://www.thestuccocompany.com/maintenance/240-volt-air-compressor-wiring-advice-from-Campbell-Housfeld-25469-.htm
    hope this helps. copy and paste short cut, in case you may not know, highlight text you want to copy by holding down left mouse button and moving pointer of mouse over text desired,while cursor is still over the high lighted area release left button and right click mouse, select copy, then put cursor in the box you want to paste, right click and select paste
    Nov 25, 2008 | Coleman Powermate 60 Gallon Air Compressor
    Air Tools & Compressors Logo
    56 people viewed this question
    Top Coleman Air Tools & Compressors Experts
    John Trevino
    elunsford
    JOHN LAPIER
    Are you a Coleman Air Tool and Compressor Expert? Answer questions, earn points and help others
