Question about Saeco Coffee Makers & Espresso Machines
Saeco coffee machine won't allow milk dispenser to click in
    Visited the website for 10 consecutive days.
  • 31 Answers
If it's under warranty, call Saeco for guidance. If it's not, CAREFULLY clean every possible part using small brushes (old toothbrushes work well, as do coffee percolator/straw cleaning brushes. They're long and skinny and have a long wire stem and handle. found mine at Bed Bath and Beyond), q-tips and "canned air," like "Dust-Off" I'ts available at walmarts, some grocery stores, electronics shops, big box stores, etc.
if you REALLY feel daring and know a little bit about a lot of stuff, and it's NO longer in warranty, labeling every single piece as it's removed, take the machine apart as far as needed to see whether the problem is mechanical (dirty or clogged), or electrical/electronic. then re-assemble and test. ;-) good luck and hope you get it running!
Posted on Apr 19, 2017
Descaling instructions:
  1. Press the " " button until the CACL CLEAN symbol appears. Press the " " button to start the descaling.
  2. The machine reminds you to insert the carafe and pull out the what is in there dispenser. The descaler symbol appears on the display. ...
  3. Take out the water tank. Pour the entire bottle of Saeco descaling solution in the water tank.
  4. Top up the water tank with fresh tap water to the MAX line. (Please ensure the max line is reached otherwise this will require further rinsing). Place the water tank back into the machine. ..
  5. Place a bowl underneath the milk carafe dispenser and the dispensing spout.
  6. Pull out the milk carafe dispenser to the right up to the " " icon.
  7. Press the " " button to start the descaling cycle.
  8. The machine will start dispensing the descaling solution at intervals. The bar on the display shows the progress. This takes about no moro then 25 minutes.
Sep 28, 2016 | Coffee Makers & Espresso Machines
No milk or frothy milk being dispensed
Link to manual
Milk may not be frothed optimally. In these cases simply turn the flow regulator as shown in the figure.
Turn the regulator 2-3 times to perform a quick maintenance.
Note: If the assembled regulator is missing, replace it with the other 3 regulators provided.
There is a pump
English version of manual pages 101 to 149
Dec 21, 2007 | Saeco Primea Cappuccino Touch Plus Coffee...
Milk drawer won't close
its the switches there is 2 one on top and one at the back the milk container is not making contact properly because the container needs realigning
Mar 12, 2012 | Saeco Primea Cappuccino Touch Plus Coffee...
Milk is not dispensing hot enough from saeco Primea Cappuccino Touch Plus coffee maker?? any ideas
I have the same problem, my wife complain me everyday, now we use our coiffe machine 90$ from sears it`s still better then this 3200$....
Apr 25, 2010 | Saeco Primea Cappuccino Touch Plus Coffee...
My Saeco Primea Cappuccino has stopped dispensing milk but no error is displayed
If you don't perform the milk cleaning process for 21 days, the machine will blocked you from dispensing milk product.
Apr 16, 2010 | Saeco Primea Cappuccino Touch Plus Coffee...
Saeco Talea Giro no steam or water from spout
I have the same problem as well, talked to a repair shop and it's definitely a "send in" or warranty repair. I was told it's an o-ring issue. I have no water coming out of the steam wand and it goes into the dispense tray instead.
Apr 11, 2009 | Saeco Talea Giro Espresso Machine
Machine does not dispense milk properly
There is a pin in the cappucinator the needs to be turned slowly to create the venturi action to make it work. If you have lost the pin it won't work.
Mar 16, 2009 | Saeco Royal Digital Plus Coffee...
How to work Spidem Cappuccino Instantly Espresso Machine
the coffee portion of the knob only allows the instant coffee to be added to the mixing process, then when the knob is turned to the milk selection, the milk is frothed and the instant coffee is added and dispensed into a container under the dispenser area on the front of the machine......Hope this helps.
Aug 16, 2008 | Coffee Makers & Espresso Machines
Steam escaping from milk container
When you say change Oring do you mean the Oring in the capp. or in the machine?
Nov 10, 2007 | Saeco Primea Cappuccino Touch Plus Coffee...
Open Questions:
Defect Saeco Odea Giro. Red exclamation flashing fast. Mashine is function only in service mode. A defect in Saeco Odea Giro. TYP 0310R ser. number. 9007SA40523803 Please help for repairing the machine. I bought the automatic coffee machine second hand. After unpacking, I discovered that someone was intruding into it cracked plastics and handles. By common check, I discovered the 1st fault - a broken piston catalog number 11003468. This is quite a common fault with these machines. 2nd defect leakage of the valve. Even one O ring was missing. I replaced all O-rings with new ones. Then I went over to check the individual sensors: Level sensor in the tank - OK Sensor closed coffee bean hopper - OK Sensor of closed door on the brewing unit side. - OK Sensor on the waste container - okay When I wanted to try switching on a microswitch that detects the presence of the brewing unit in the hole, I did not find contact. So I removed the wall behind the brewing unit and found that there were two microswitches near the toothed wheel. I checked their functionality. Both well. I assumed that one of them was not at his destination. The one with the green connector I supposed to indicate that the brewing unit is in place. I moved him to the top. I checked the state of the electric motor and lubricated the gear. I returned the wall back. Next, I ran the diagnostic mode and checked other components: a Boiler - Heats up b The pump - presses correctly and the green diode flashes during its operation and shows the activity of the flowmeter c solenoid valve - switches correctly d the grinder grinds and during its operation the green diode flashes and reveals the activity of the speed sensor in the mill e the brewing unit is moved to the top position and to the basic position without any problems Other things I've done: The whole coffee maker is cleaned, deep decontamination is performed using the diagnostic mode. Check the flow meter clean without oxidation. Check the tightness of all hoses. Both boiler thermostats are checked. Removed and thoroughly cleaned the mill. Despite this, the machine behaves as follows: Turn on the machine and fne the mill shaft. The red exclamation mark flashes very quickly. The green light of the boiler heating is not lit or flashing. However, the boiler is heating up properly. When I eject the tank water flow, the red exclamator lights up permanently. After the tank returns, the red exclamation mark will flash rapidly again and the green indicator the boiler is heated will light up properly. When switched on, the Indycatter does not light the cup. Only a drop of water drops and coffee beans lit up. Can not prepare coffee, can not refuel hot water. All this can only be done in diagnostic mode. In the diagnostic mode, I also de-aerated the machine. Both the nozzle and the coffee outlet through the brewing unit. Self-cleaning will not start. I do not know anymore, maybe there is a bug in the electronic panel. Will anyone advise me? Thank you.
Mar 09, 2018 | Saeco Coffee Makers & Espresso Machines
Coffee Makers & Espresso Machines Logo
Top Saeco Coffee Makers & Espresso Machines Experts
Level 1 Expert
Shehu Pro
Shehu Pro
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
