Question about Gateway Computers & Internet
Comp starts up and only shows wallpaper, explorer.exe won't start
I was trying to fix my drivers and nothing seemed to work so I wentinto safemode and I saw an older registry backup I thought it might helpso I clicked on it and restarted my computer then all I can see is mywallpaper, there is nothing I can click on. I tried going to task mgrrun new task explorer.exe and all it does is bring my task bar up for asplit second. I tried doing a system restore but when I get to the part to choose the date the ''next'' button doesn't work, I click on it and nothing happens, I can only go back or cancel. My first problem I was trying to fix was my computer couldn't detect my burner, and now I have this bigger problem....Please help! Thanks...I don't know what to do anymore
  • 5 more comments
  • fiona983 Jul 24, 2009
    I am using Windows XP, yeah I tried safemode again and did a scan with malwarebytes, it found infected files and stuff in registry, and removed those, I restarted my computer but everything is still the same. Nothing happens when I right click the screen, i can only open things by going to task mgr. My warranty is expired already =(
  • fiona983 Jul 27, 2009
    Hi, yea I tried to do a system restore but it won't let me because when I get to the part where I choose the date the "next" button won't work. What do u mean by loading windows xp ? Is that the same thing as F10 or system recovery? If I use that method would I lose all my files?
  • fiona983 Jul 28, 2009
    Yeah I have the disc to reinstall windows xp. I think my files will be deleted once I do that, it says it on the disc also. Do you know how I could transfer all my pictures, music, and documents over to my D drive? I'm not sure if I could put my files there D drive says "Recovery", if I do put it there, which folder do I put them in?
  • fiona983 Jul 30, 2009
    OK, so i tried to reinstall my xp, it gave me a message saying that it can't recover c:\i386\DBGHELP.DLL so now i'm stuck and don't know what to do?? Help please....
    Well I got to save all my stuff, but now i can't reinstall xp, it says it can't recover c:\i386\DBGHELP.DLL then it stops the recovery process.
  • fiona983 Jul 31, 2009
    Hi, so how do I format the C: drive and install?? Sorry I'm really not good with computers
  • docbronk May 11, 2010
    what os are you using? did you try safemode again? scandisk, can you right click on your screen? is your warrenty expired?if not id call gateway
  • 60 Answers
Have you tried system restore? what about loading windows xp back on , your old programs will still be there. start with the simple things first before reformatting.
Posted on Jul 27, 2009
  • 1 more comment
  • docbronk Jul 28, 2009
    reinstall winxp. do you have the disk? your files will still be there. unless some major meltdown.
  • docbronk Jul 30, 2009
    all that means is when you reinstall windows it replaces all your (System Files). Unless you reformat,if you reformat you lose everthing. But when you reinstall xp all of your updates to xp from the microsoft website will have to be re-downloaded. Do you have a CD or DVD writer? If so you can backup all your doc,pics,whatever on disk. If not I've never had any problems reinstalling xp and keeping everything in MY DOC's. But i did have to update for hours sometime on MS website. Let me know how it comes out!
    I did'nt know you had a partion seperate "d" drive. righ click on it and see how much storage is left on it. If it has enough for all your pi'c,doc's then create a folder and copy all there. Right click in "D" drive, new folder, name it. go to your pictures right click , copy , paste in new folder on D drive. Makes since?
    New Friend:
  • 47 Answers
You should format your hard drive reinstall your Windows XP. If you have any important data on the drive use Hiren's Boot CD, it has Mini Windows XP, which loads off the CD and you can use it to copy data from your hard drive to another one.
Posted on Jul 25, 2009
  • 1 more comment
  • Th3_uN1Qu3
    Th3_uN1Qu3 Jul 29, 2009
    Like i said, use Hiren's Boot CD and boot Mini Windows XP. It'll show your partitions and allow you to copy data between them.
    On a clean Windows install the C: partition will be wiped. You can use that Mini Windows XP to copy data (such as My Documents, My Pictures and so on, found at C:\Documents and Settings\ to the D: partition, which will be left alone. There is little point in backing up the Program Files folder unless you have saved data/projects there, as any programs you had will have to be reinstalled due to the registry starting clean.
  • Th3_uN1Qu3
    Th3_uN1Qu3 Jul 30, 2009
    Don't do a recovery. In Windows XP Setup format the C: drive and install clean.
  • Th3_uN1Qu3
    Th3_uN1Qu3 Jul 31, 2009
    I assume you do have a *retail* XP disc, don't you? The recovery discs provided by your computer manufacturer aren't going to work. There are plenty of places to get a disc but they aren't all legal, so what you do is your own business.
    Anyway. With the same Hiren's Boot CD i mentioned above start Acronis Disk Director (it's in the Partition Tools submenu), delete the C: partition, then re-create it. Select New Partition, NTFS, the maximum size available, and make sure it's set as Primary and Active. Hit the flag button and wait for Disk Director to do its job. Then install from a retail XP disc, you can find tutorials on how to do that on the net, and it's actually pretty easy. At this point you may try your manufacturer's restore discs again if you don't have retail XP, but if they fail at the same file then their CDs are broken and you should phone them to send you new ones.
After I boot up my computer all that brings is just a by screen saver with nothing else no icons or anything. Any help would be great.
For some reason it seems that explorer.exe isn't start. I would start by rebooting into safemode. After the bios boot screen, but before the windows loading screen repeatedly press F8 to bring up a menu. Try safe mode with networking first and run an anti-virus scanner. Usually virii and other malware tend to do this.
Jan 08, 2014 | Dell Dimension E310 PC Desktop
No start task bar in safe mode
It sounds like explorer.exe is being turned off. When you log in to Safe Mode hit Ctl+Alt+Del to bring the Task Manager and see if explorer.exe is running under Processes. If not, you can go to the Applications tab in Task Manager and click the New Task button and simply type in explorer.exe.
If this does not give you your Start Menu and Task Bar then you need to take your computer back to the repair service and have them fix it properly this time. Otherwise, you'll have to reinstall the operating system.
Jul 06, 2012 | Dell OptiPlex GX260 PC Desktop
Xp cant start after welcome massage
Does it only show the desktop wallpaper and does not show the icons, taskbar, and start menu? well the explorer.exe is missing in the Processes which you can see in the Windows Task Manager
the following are the reasons for the problem
-Your PC is infected by a virus/malware or any harmful softwares which blocks the explorer.exe and disables it to run at startup
-Someone or something deleted your explorer.exe that is why it cannot be found
if this is not the cause of your problem i would be glad to know what is it.
hope it helps
Jul 14, 2011 | Microsoft Windows XP Professional With...
When i start up my pc, the icons do not show - NOTHING shows... Only my wallpaper shows.. Not even my taskbar or desktop. Please assist
press Ctrl-Shift-Esc together WS Task Manager will come up .... click on File you will get the option for New Task .... click on it .... type in explorer.exe and click OK. if that does not work turn off your pc ... disconnect the power cable from the back ... press and hold the power button for 30 secs with power cable disconnected.... plugg the cable back in turn on the pc ..... issue resolved
Apr 21, 2010 | Microsoft Windows XP Professional
Computer starts up windows to screensaver and goes no further. There is no start menu and cannot start it in safe mode.
by screen saver, Im assuming you mean the desktop wallpaper. (screen saver is the program that comes up and shows pictures moving around, or stars flying by, or pictures of pipes building some over-rebuilt plumbing in outer space). Whats going on is, your Windows shell (Explorer.exe) is not loading. that is almost ALWAYS caused by a virus. If you cannot load in safe mode, you may not be able to recover that system without a professional. If there is nothing of major importance on that drive, I suggest you gather your OS discs and your drivers and application discs and reformat and reload.Based on what you describe, your explorer cannot load and cannot process because of an infected file being loaded during startup.
Oct 26, 2009 | Dell Dimension 2400 PC Desktop
My windows display only wallpaper
What happens when you press the windows key at the bottom left of your keyboard?
What happens when you move your mouse to the bottom of the screeen?
If nothing, can you get to the task manager? Press Cttl-Alt-Delete and choose task manager
Under process close explorer.exe
Then under the Applications tab click new task
When booting into Windows press the F8 key and select restore to last known good configuration.
If that does not fix it... then you need to renboot using your Windows XP Installation CD and select repair system
If this has been of help to you please remember to vote kindly.
Oct 09, 2009 | Microsoft Windows XP Professional for PC
The wallpaper shows up but the icons don't show up. I cant get to any programs.
Does the start button work?  If not, run ctrl-alt-delete and go to processes.  Check for explorer.exe.  If it is not there, click on New Process and type EXACTLY explorer.exe and hit enter.
Jun 07, 2009 | Dell Inspiron 1501 Notebook
No icons, start menu, taskbar, explorer not working
backup your data and do a repair install - might take a while longer but at least you know it will clear any issues.
there are a number of things you can do to fix it but will most likely take a lot longer
Apr 20, 2009 | Gateway GT5220 PC Desktop
No short cuts in my screen
are you able to operate your system after it is started. I mean open Windows Explorer ??? Mouse working ?? etc ??
if its only the desktop icons, then try this:
Right Click on Dekstop >> Arrange Icons By >> Show Desktop Icons
Feb 17, 2009 | Dell Computers & Internet
My Hp Laptop
Have you tried to boot into safemode ( f8 on boot before windows comes up, then select safemode ) and then when you get into windows do a system restore to a point before you got hit then use adaware andspybot search and destroy and then instal AVG best AV software I have ever seen.
Apr 29, 2008 | Computers & Internet
Computers & Internet Logo
431 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Matthew Spark
Matthew Spark
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
