Question about Intel Computers & Internet
Intel notebook says thermal shut down pls help
It is only 3 months old it shuts off when shays thermal shut down
    Master:
  • Intel Master
  • 246 Answers
To speak technical support representative dial +1 (800) 204-4427 (U.S.) 1800954262 AUS, +44 (800) 046-5216 (UK)Am to 6 Am, Pacific Time, Monday through Sunday. If you needs a technical diagnosis you can call on our tech support team 1-800- 204-4427, which is especially open round-the-clock for online assistance.
Posted on Apr 19, 2017
SOURCE: Forgot password to notebook, have no access, how to fix?
My Acer Travelmate 240 bios password is unknown. Please help
pcp.csl@hotmail.com
Posted on Mar 18, 2008
bunnydawg
  • 5158 Answers
SOURCE: Computer Shuts Down Randomly
is the fan running.... check how hot it is on the bottom.... could very likely be thermal shut down... if it gets to hot it shuts down before there is any damage.... see if you can remove the shield around the fan and clean out the dust and dirt and in my case cat hair. if you can't figure out how to get the cover off let me know... i should be able to find the service manual for you
Robert
Posted on Dec 19, 2008
SOURCE: Shuts down for 5 minutes
I have the same problem with my new magic cheff over the stove microwave oven. I call magic chef and they gave me the 800 number for the service center (1-800-775-0202). When I described the problem they told me to just put a plate under the popper and this wouldn't happen anymore. I haven't tried it yet but here's hoping.
Posted on Jan 20, 2009
  • 70 Answers
SOURCE: My HP Pavillion DV100 notebook shuts down whenever
Sounds like classic overheating, check your power supply fan, or the fan of your heat sync that seats over your CPU as well as the heat resistant insulation thermal lubricant that's there to keep it cool.
When fans starts to go the bears or motor starts to stick and will intermittently stop. When when it goes altogether it ceases to turn and can cause serious overheating damage to your circuitry.
Posted on Jul 27, 2009
maintenacemi
  • 95 Answers
SOURCE: motor gets hot & the thermal cut-out shuts
one of the windigs in the stator has an open circuit
Posted on Nov 18, 2009
Random shut down
Clean the cooling sistem and change the thermal paste
Feb 03, 2014 | HEWLETT-PACKARD HP Pavilion dm4-1165dx...
Unexpected shut down
Good chances this is a thermal shutdown. if this is the case, the computer is shutting off to protect itself from permanent damage. if your OS is old enough (Snow leopard, I think) then the system logs show what caused the shutdown. it will give a number. anything other than a 0 or a 1 are bad. if I recall correctly 1, 5, 13 are thermal shutdowns. Newer OS's don't seem to show these codes. and Apple does not publish their meanings.
Dec 11, 2013 | Apple 13inch Economy MacBook laptop Intel...
Dell d610 shuts down while playing games
Some games require more processor use, some less.
If the games that cause your computer to shut down feature high resolution graphics or fast 3D rendering, then the problem could be insufficient processor cooling. Once the processor gets overheated, it goes into thermal shut down.
If, while you play, the computer runs hot before it shuts down (check the cooling fan outlet), then these are some of the possible reasons:
-cooling fan blades could be obstructed by dust - cooling fan needs to be cleaned or replaced
-heatsink radiator and / or air outlet could be obstructed by dust - also need(s) to be cleaned
-thermally conductive grease on the microprocessor heatsink could be
partially or entirely dried up - old grease needs to be carefully removed and new grease applied (caution - do not use any kind of thermal grease that contains metallic particles like silver or aluminium - you might short out the processor - only use the kinds which are electrically nonconductive)
of course the problem could be elsewhere, but the above mentioned problems turn out to be a common issue with many laptop computers after a few years use, regardless of manufacturer brand and model, also it could be any of or the combination of any or all of the above problems (obstructed air outlet leads to more dust being deposited on the fan blades, more dust on the fan and outlet leads to processor overheating which leads to thermal grease drying which leads to even more overheating and so on...)
hope this helps somewhat
regards
triarcuate
Mar 31, 2012 | Dell Latitude D610 Laptop Computer -...
Won't power up the on off switch is orange and
have you tried holding down the power button till it shuts off ?
Oct 15, 2009 | Acer Aspire One PC Notebook
Shut down problem
somthing is running in the background ... maybe spyware ... maybe just some application ... try shutting everything off manually in ur taskbar and then shutting down ..
or Else You can also right click the task bar and select "task manager" from there go to "user" and above that you find the shut down selection in one of the menus.
Mar 15, 2009 | Dell Inspiron 1525 Laptop Jet Black (15.4"...
Laptop shuts down often when using battery power
Often, this would be a battery problem given the age of the laptop. A way to verify is if the AC adapter/charger is plugged in and the problem persist, then it would be "something else".
Hope that this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Oct 27, 2008 | HP Compaq Presario v3000z Notebook
Computer won't shut down.
Dear Catobion,
its a OS related problem, please call some technical guy ,which can reload the Operating system again in your pc, and i'm sure it will be work fine and faster.
Be Happy always
Scorpion
Sep 15, 2008 | ASUS P5Q3 DELUXE/WIFI-AP CH1-11 LGA 775...
Laptop power light is on, wont shut off and screen is blck
You could shut down your by forced shut down. to do this, press and hold the power button for 5 seconds, during which a long beep is heard. The system will shut down.
Try reinstalling the operating system to resolve this problem
May 13, 2008 | Dell Latitude D600 Notebook
First, you need to find out what is causing the shutdown problem.
Most likely since you have this laptop for 3years now and (i am assuming you havent had this serviced). You might be suffering from overheat problems since you are using a DESKTOP P4 cpu.
Try to dismantle your laptop and remove the Fan and Heat sink. CLEAN them and put new thermal paste to the cpu.
Do that and see if this fixes the problem. If not, let me know again
If i was able to help please rate this solution as a fixya!
thanks
Apr 11, 2008 | Toshiba Satellite A75-S231 Notebook
Computers & Internet Logo
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
