Question about Intel Computers & Internet
Can you pls help my intel notebook says thermal shutdown
    New Friend:
Change. To apple I have had no such problem with my tablet
Posted on Apr 19, 2017
Intel notebook says thermal shut down pls help
To speak technical support representative dial +1 (800) 204-4427 (U.S.) 1800954262 AUS, +44 (800) 046-5216 (UK)Am to 6 Am, Pacific Time, Monday through Sunday. If you needs a technical diagnosis you can call on our tech support team 1-800- 204-4427, which is especially open round-the-clock for online assistance.
Apr 19, 2017 | Intel Computers & Internet
Random shut down
Clean the cooling sistem and change the thermal paste
Feb 03, 2014 | HEWLETT-PACKARD HP Pavilion dm4-1165dx...
Unexpected shut down
Good chances this is a thermal shutdown. if this is the case, the computer is shutting off to protect itself from permanent damage. if your OS is old enough (Snow leopard, I think) then the system logs show what caused the shutdown. it will give a number. anything other than a 0 or a 1 are bad. if I recall correctly 1, 5, 13 are thermal shutdowns. Newer OS's don't seem to show these codes. and Apple does not publish their meanings.
Dec 11, 2013 | Apple 13inch Economy MacBook laptop Intel...
Thermal event
YOUR COMPUTER IS TO HOT YOU HAVE TO CLEAN IT FROM DUST AND OTHER PARTICALS.USE A CAN OF COMPRESSED AIR.THE COMPUTER SHUTSDOWN FOR PROTECTION.
Nov 29, 2013 | Intel Computers & Internet
Aspire 5535 heats up and shuts down when a game is initialized. Fans clean and appears functional. Applied fresh thermal glue to heat sinks. Problem persists.
increase ur ram Scanning computer to eliminate malwares, spywares and the viruses from your laptop.
2- Repairing and cleaning Windows registry.
These two tips are found to be very helpful to fix the laptop shutdown problem. Almost all the computer users surf internet which could result in viruses attacking your system. Some of these infections are really pesky and cause the machines to shutdown randomly.
The registry errors, however, are the internal errors and can become a cause of system crashes and freezes. The registry keys shall be in good health to keep a system perfect.
When I noticed my laptop keeps shutting down everytime, I tested the Intel Software Partner, RegInOut to fix the random shutdown problem with my laptop.
Aug 29, 2010 | Acer Aspire 5050-3242 Notebook
When i shutdown my winxp mediacenter edition i get a bsod telling me FATAL SYSTEM ERROR, this just started yesternight, pls how do i fix this?. my windows boots to login without problems its just when i...
First attempt a registry scan and clean. check that your memory is seated properly, do a DEEP scan of your hdd. a failing hdd can and will cause this problem. have you recently uninstalled or installed anti-(virus-trojan) software? if so make sure you go to manufactuer website for correct uninstaller. hope this helps
May 26, 2010 | Dell Inspiron E1705, Intel Core 2 Duo...
OVER HEATING
Two possibilities:
  • the CPU is really overheating; and/or
  • the motherboard is falsely sensing high temp.
Corrective measure for an overheating CPU would be:
  • clean, re-lubricate or replace the fan;
  • clean or refit the heatsink. If it is overclocked, you may need a better heatsink.
If the CPU is not really heating up abd the motherboard is sensing erroneous temp readings, then the problem may be with:
  • BIOS version, try to flash and update the BIOS; and/or
  • check the temp probe underneath the CPU, it may need cleaning or slightly bending away from contact.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Aug 13, 2008 | Intel D865GBF Motherboard
First, you need to find out what is causing the shutdown problem.
Most likely since you have this laptop for 3years now and (i am assuming you havent had this serviced). You might be suffering from overheat problems since you are using a DESKTOP P4 cpu.
Try to dismantle your laptop and remove the Fan and Heat sink. CLEAN them and put new thermal paste to the cpu.
Do that and see if this fixes the problem. If not, let me know again
If i was able to help please rate this solution as a fixya!
thanks
Apr 11, 2008 | Toshiba Satellite A75-S231 Notebook
Thermal Shutdown
first, try to check the heatsink of the processor if it is full of dust and the air flow from the processor fun cannot penetrate to the processor.
second, double check the brackets that holds the heatsink to the motherboard, bcoz in most cases for socket 478, those bracket will easily get cracked due to aging, the reason the heatsink will not totally hit the processor.
third, remove the thermal pad on the heatsink and replace new one.
if you're done with the above mentioned, and still the same problem exist, may be there is something wrong with the sensor of the motherboard the reason it registered a wrond temp of the processor, but this cases rarely happens, but still it does.
Dec 04, 2007 | Computers & Internet
Intel 845gvsr shutdown problem.
pls change the mother board capacitor of 820uf 6.3 v
Aug 13, 2006 | Enlight 17IN LCD PC SILVER/CHARCOAL W/...
Computers & Internet Logo
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
