I'm trying to hook up my Xbox up to my TV using the HDMI ports but it keeps comeing up with the message.... Not supported... Any ideas?
SOURCE: XBOX 360 Elite HDMI SOUND PROBLEM
First you have to activate the HDMI audio option in your Sony suround system options so as to activate it. Please try this and then tell me what happens.
Posted on Dec 18, 2008
SOURCE: Receiving "Unlock" message and "Not Used" on my reciever
The HDMI inputs are pass through inputs only. The reciever cannot recieve any sound signals through the HDMI's. The reciever acts as a selector switch for the HDMI inputs. Whatever input you have selected on the reciever is the one that is being sent through the output to your TV. The "unlock" display shows when there is no sound signal sent to the reciever. There is no code to unlock. This is the reciever's way of telling you that there is no sound being sent to it from that input. Since there is no sound being processed from the HDMI's, you need to hook up an additional audio cable from the device to the reciever (preferrably an optical cable). When the reciever recieves an audio signal, it will then "unlock" and you will get sound. The only purpose for the HDMI jacks on this reciever is to give you a bonus HDMI jack so you only have to use one on your TV. I know it is confusing. I had to look into this problem myself, so I'm happy to help. Higher end recievers will actually recieve and process sound signals from the HDMI's.
Posted on Feb 06, 2009
gage8405
  • 5 Answers
SOURCE: TELEVISION - PS3 AND XBOX HDMI COMPATIBILITY
You have to use the scart connector for on screen menu settings. Go to the video option and enable HDMI and/or match resolution output to your set.
You did not mention the model of the TV so here is another scenario,
Just because the TV is 1 year old doesn't mean that it is a 1080p capable, you could have set the HDMI resolution settings to 1080p and you will not get any picture if your set cannot process the information.
Posted on Jul 03, 2009
smarthome2
  • 1114 Answers
SOURCE: TV blanks out..."pcm" light flashes on receiver
You need to Bypass the Receivers HDMI port and use HDMI directly to the TV. Your receiver has HDMI version 1.2a and is not 100% effective. Use the optical out from your Xbox to the receiver and all will be well. 1.2a has issues in every receiver on the market. Supposedly 1.3b on the "new" receivers has fixed this issue. Hope this helps
Posted on Aug 13, 2009
SOURCE: Sharp Aquos 46" HDMI problem
I have a similar problem. The Sharp TV aquos appears to be shutting down my blue ray player and dvd recorder when connected via HDMI. They work fine and never close down when I connect them via the rca cables either single video connection or a composite 3 cable rca lead. I have 3 HDMI inputs on the tv and the problem occurs on all 3. Any suggestions?
Posted on Apr 25, 2011
Playing bluray through xbox one on toshiba TV
Make sure the display resolution is set correct for your TV,
How to change the display resolution for your TV on your Xbox One...
Also make sure the TV is on and set to the correct HDMI input before using the Blu Ray.
It is also possible the TV does not support HDCP, if not, it will not work with the XBOX one Blu Ray. You may be able to use the Component (Red Green and Blue) cable though.
Apr 07, 2014 | Toshiba Televison & Video
Hook up xbox 360 tv
What kind of receiver? Do you have anything else like DVD player going thru receiver? My receiver has 3 hdmi in and 1 out (to tv) so all those equipment would just go to "hdmi" on tv.
Another way to do it is put your tv on exterior audio... for all sound to go thru your receiver.
Jan 05, 2014 | Televison & Video
Emerson hdmi not working
Double check to see if your TV can support the resolution that your laptop is using. You can try reducing the resolution on your laptop to one supported by your TV.
If the laptop is configured to use the HDMI port as a second (in Windows 7, you can configure multi-monitor support in the display preferences) you will need to adjust the resolution for that monitor.
Failing that, try rebooting your laptop with the TV plugged in - I have found in some cases that this helps the system to propery detect a new display.
Dec 16, 2013 | Televison & Video
Lt-50a330 trying to connect laptop but it says "not supported"
If your laptop has a HDMI port just use a HDMI cable to connect it. Unless you are trying to do it wireless in which case you need the data from the laptop to go first to a receiver, then the tv.
Apr 13, 2013 | Televison & Video
I have an Emerson 42in flat screen lcd. It has 3 hdmi ports, a pc port, etc. What I need is an audio out port and the only audio out port is the Digital audio out. My ps3 and xbox 360 are hooked up through...
If you have a home theatre system, most receivers have a digital audio input that you can use and hook that up to the digital audtio output on your TV. I have the same TV, and this is how I am doing it.
The other option is to get a new receiver that supports HDMI, and feed you HDMI into the receiver and then use the HDMI out from the receiver to the TV.
These are about the only options you have.
Dec 09, 2010 | Audio Players & Recorders
I have a Sony bravia 32" (KLV-32T400A) and have just bought an xbox.. On trying to connect it using the HDMI input an error comes up saying that it's not a supported signal. I also tried plugging my laptop...
All hd-ready tv's only support max 1080i and not 1080p. The default setting on the Xbox is 1080p, that's why you get that message. There is a way to fix this, just follow the steps below:
Connect TV and X box via HDMI cable with units switched off.
Switch both units on.
  1. Press the right arrow 7 times (Left top jog knob on game controller)
  2. Press "A" button 4 times (Green button)
  3. Press "up" arrow once to set to 1080i
  4. Press "up" arrow once again to set to 720p.
  5. Press "A" to store setting
Sep 12, 2010 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
Aug 12, 2009 | Yamaha RX-V663 Receiver
HDMi ( no signal, not supported) doesn't work with Dmr-Ez47v
Any HDMI cable manufactured in the last couple of years should all be HDMI 1.1 compliant, your problem is most likely the logic board in the TV itself or the HDMI connector on the logic board has a bad connection..
Have you tried hooking-up a standard DB15 VGA cable to the AKAI TV and your laptop?
If this works your problem is in the TV and will most likely have to be repaired to receive the HDMI signal since your Panasonic DVR and your laptop are not recognized by the HDMI input on the TV.
Ren
Jun 03, 2009 | Akai LCT2785TA 27 in. LCD Television
Hooking up XBOX 360
Hi have you tried going into the menu option using the telly controll and switching the hd mode on this should then allow you to use the xbox through hdmi cable
Feb 29, 2008 | Proscan 42LA30H 42 in. LCD Television
Televison & Video Logo
26 people viewed this question
Top Televison & Video Experts
Electro Med Services...
