Question about Drills
I have model PD400LG cordless drill and have lost the charger. They have 2 chargers one for drill prior to 2013 one for 2013 and newer. How do I tell which Year I should order?
joboo1
  • 257 Answers
SOURCE: 18V cordless drill charger #981832-001
Hi again, Because of the age of these batteries, this may or may not work but you have nothing to lose. The theory here is that over time, oxides built little bridges in a ni cad battery between the anode and cathode thus shorting the battery, shocking the battery burns those bridges and if the cells are still intact it will work again. So take your stronger battery or cables and being sure to observe the correct polarity touch or brush the positive to positive and negative to negative several times. The first times will spark and then as the bridges burn the spark will decrease. Put the battery in the charger and the charge light should come on. Leave the battery in the charger until it reaches a full charge. If after this procedure you still have the defective indication, then the cells were bad and you will still have to replace the battery. Good luck, please let me know how this works for you!
Thanks for using FixYa - a FixYa rating is appreciated for answering your FREE question.
Posted on Mar 29, 2009
frankzen
  • 19 Answers
SOURCE: Hi. I need a Sears Craftsman 16 volt battery
www.craftsmancordless.info
Posted on Apr 04, 2009
jowen28
  • 9 Answers
SOURCE: I have a Black and Decker 7.2 V cordless drill
Center pin is generally positive - outer ring is negative. But you can use a 9v charger just as easily; in fact, the one supplied with the cordless drill is a 9.0v, 200mA output charger.
Posted on Aug 10, 2009
SOURCE: Need to replace power cord to battery charger of cordless drill
it takes a 24V DC 200mA  The one I have is a Ktec Model KA12D240020034U
Posted on Aug 29, 2009
  • 11 Answers
SOURCE: I have a JobMate cordless drill and 2 batteries.
I found the Ryobi charger fits the jobmate as well.
Posted on Apr 17, 2010
Looking for charger for cordless 19.2v drill
I couldn't find one, looking everywhere. The newer Coleman chargers are a different size. The red charging light would not come on. Using a meter, I figured out it wasn't the charger, but the power adapter. I found one online that fixed my problem and now I can charge my batteries for my Coleman impact drill. From Digikey.com
http://search.digikey.com/scripts/DkSearch/dksus.dll?x=0&y=0&lang=en&site=us&KeyWords=454-1403-nd
Nov 20, 2009 | Drills
I lost the charger for the 18v PSO1800 Type cordless drill
Replacement parts in USA from
http://www.ereplacementparts.com/charger-p-100122.html?osCsid=cv3pj4ntur724eevbt3vhfeor4
does not appear to be a UK model.
Nov 17, 2009 | Drills
R86006 Li Ion 18v Cordless drill - When trigger is pressed, drill runs for a moment and stops. While charging battery, both the green and red lights blink permanently. Is battery and/or drill bad?
Sounds like it is more between the charger and battery. Sounds like a newer model, Can you test it with an alternate battery? Chk the battery voltage and the charger output against the data plates.
Oct 20, 2009 | Ridgid Power Tools Pressing Tools...
I have a Black and Decker 7.2 V cordless drill #9909KC which I have lost the charger for. I have a 7.2 V charger for another application but do not know what the polarity is (+ or -) on the drill where the...
Jul 06, 2009 | Drills
What milliamp is the charger rated at?
9VAC-100mA
this is right off my charger. it also says 6V on it
this is too bad, I have a charger and no tool and you have the tool and no charger
Mar 26, 2009 | Black & Decker Pivot Plus Cordless...
I need a battery charger for Singer Journeyman cordless drill model SJD 480. Charger P-356035. What else could I use?
The Singer Journeyman 3/8" Cordless Drill/Driver Model SJD 480 uses Singer charger model P-356035 which has the following specs:
Input: 120V 60Hz 6W
Output: DC 6V 350mA
Positive-----o)-----Negative
Mar 13, 2009 | Drills
Charger not charging have 2 new chargers neither 1 will work for black& decker 18 volt cordless
You should probably contact Customer Service regarding this. I'd say it's a problem with the batteries rather than the chargers considering this looks like a recent EPC model - 1800 444 224
Mar 08, 2009 | Black & Decker 18 Volt Cordless Drill...
Charging times
I would think not more than an hour or when the lights flash that the battery is charged. The newer chargers go to a maintenance mode after a battery is charger so theoretically you could leave it on for weeks, but I don't recommend this.
Jan 14, 2009 | kawasaki 19.2V 4 Piece Cordless Tool Kit
Dewalt battery charger
You will need he correct charger, the 24V will destry a very expensive battery.
Sep 29, 2008 | Dewalt DW056 18 Volt Cordless Impact...
I want a black&decked battery charger part no 763883-00 for a cordless drill no cd 18c-xe
the charger its self are expensive.better to purchase new unit for a couple dollars more & u have 2 spare battery & charger
Apr 25, 2008 | Dewalt DC920KA Heavy Duty Xrp 18V Cordless...
Drills Logo
94 people viewed this question
Top Drills Experts
Are you a Drill Expert? Answer questions, earn points and help others
