Question about Samsung Refrigerators
How to replace the Samsung DA97-07365A ice maker?
I took off the wiring cover and disconnected the wiring. I push down on the tab and try to pull it out but the ice maker isn't moving.
    Master:
  • 347 Answers
Are you certain that you are fully depressing the tab? It may be a piece of ice holding it from sliding out. Try a blow dryer to warm the area of the slides and try again. There isn't anything else mechanically holding it in. Good Luck
Posted on Apr 19, 2017
1974@sbcglobal.netmy LG LFX25971ST refrig will not stop makiing ice. The metal arm will not stay up to stop the icemaker. How do I fix the problem?
They Usually become disconnected internally or brake on the inside, The only way to find out is to Remove the ice maker pull it apart and see. First unplug the refer. Unscrew the 2 upper and 1 lover screw where the ice maker attaches to wall. Lift the harness tab and unplug the ice maker set on counter. Pull off the white cover and unscrew the housing. Pull apart the housing and see if you can re insert the wire to the toggle lever. If not you can replace this unit in a similar order. Hope this helps.
May 26, 2011 | LG LFX25971ST Bottom Freezer French Door...
Gi5fsaxvy french door fridge ice maker has frozen ice blocking it. However, can't get into it to melt the ice. Looks like a tab on the left holds it in and it should slide out, but it does not. Must be...
This diagram shows two screws on the top and there is one on the bottom. Loosen the screws and ice maker should lift off. You may just want to use a hairdryer to melt it and your water inlet valve on the back where the water supply is connected may be leaking letting the water drip into the ice maker and freezing when it gets there. http://www.searspartsdirect.com/partsdirect/partsdirect/showSubComp.pd?imageUrl=http%3a%2f%2fc.searspartsdirect.com%2flis_png%2fPLDM%2fW1010173-00005.png
Nov 17, 2010 | Whirlpool GI5FSAXVY Stainless Steel ...
I have a Samsung RF267ABRS french door refrigerator. It is two years old and it quit making ice. I have replaced the filter and the water dispenser works fine. I have also reset the ice maker. What can...
If you hear a clicking sound sometimes, it is your ice maker. Replace ice maker, all you need is a short phillips screwdriver. Remove ice bucket, to the left you will see a philllips screw holding a long plastic panel going all the way to the back, remove the screw and the panel, it has clips that slilde in, unplug ice maker and push down on tab on top of ice maker and pull out
Sep 03, 2010 | Samsung Refrigerators
How to remove ice maker, it is jammed
moz-screenshot.pngRemove the ice bin first by pushing the button on side and pulling out.
Next look on the lower left side of where the ice bucket was, you will see a slot, insert a flat screwdriver into the slot tilt the screwdriver up, this will push down on a tab inside the slot and the cover will come loose.
Remove the cover and unplug the wire harness to the ice maker
Release the locking lever on the side and the ice maker assembly will slide out.
Apr 18, 2010 | Maytag MFI2568AE Side by Side French Door...
We have a KitchenAid side by side Refrigerator Model KSRG22FKWH15 with style 2 ice maker. Have water but ice not being made. Have checked all normal reasons for not making ice. How do I remove ice maker...
try this:
1. Remove the bucket from the door to get some room.
2. Put a piece of tape on the sensor flapper to hold it down so you won't damage it while removing the ice maker.
3. Remove the ice maker service cover door by spreading the two hinge fingers apart away from the center and the door should lift out of the slot.
4. Remove the screw in the right rear bottom side of the ice maker.
5. After removing the screw that cover should lift up from the rear and just work it out from the rear and you see the electrical harness.
6. On the left track the should be a tab toward the bottom which you need to push up.
7. Push up tab and start working the ice maker towards you pulling it out of the track.
8. Careful with the electrical harness in the back as you're pulling out.
9. Disconnect the electrical plug by lifting the clip on the plug.
10. Remove the side cover on the side module by pulling off.
11. Remove the bottom shield by removing the 3 screws on the bottom.
12. To install reverse the order as it came out.
Apr 02, 2010 | KitchenAid (KSRD22FKST) Side by Side...
I am trying to replace the ice maker for my Whirlpool fridge, model number GS5SHGXLS01, I can get the wiring off, please advise?
remove the white cover there is a release tab on end of harness where it goes into IM. push it in and pull wire plug out.
Jun 13, 2009 | Whirlpool GC5SHEXNS Side by Side...
Ice maker removal
first of all remove the ice bucket. then you will see a wiring cover on teh left hand wall just below teh icemaket. there is a rectangular hole in this cover. using a small precision scredriver carefullly insert into this hole and push up or and down to release a hidden clip. the trick is to pull on the wiring cover while you try to maneuver the clip. first time you do it it can be very frustrating but keep working at it and you will get it.
alternately you could just leave the Icemaker in place and use a hairdryer to melt the jammed ie out of the way. good luck peyton
Dec 14, 2008 | Maytag MFI2568AES Stainless Steel Bottom...
Ice maker doesn't work
try as little bit harder and the ice maker should pull out stright from the freezer. watch out for the holders they are on the back and they sometimes are broken if you are not carefull with them. there is also two wire that have to be unconected when you do this. they are moilex connectors and if you push the tabs they should pull apart real easily. Thanks for using FixYa And have a great new year.
Sep 09, 2008 | Samsung RS2578BB Side by Side Refrigerator
Sub zero 532 ice maker
When my repair tech came out, he showed me that the fill tube sometimes retracts toward the rear of the freezer. He simply pulled it forward with a pair of needle nose pliers until it rested in the delivery reservoir. This placement allows the detector to know when the tray is full and shut off; thus not overfilling the freezing tray and/or splashing additional water onto the freezer wall and into the ice cube drawer.
Nov 21, 2007 | Sub-Zero 632 / S
Samsung Icemaker Problem
I also had the ice tray stuck in the dump position. I unplugged it waited 5 minutes and pluged it back in. And the Ice tray moved back into the correct fill position, and the arm did drop down, But now it has not filled with any water. So now what should I try?
Feb 20, 2007 | Samsung RS2534 Side by Side Refrigerator
Refrigerators Logo
70 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
