Question about Electric Health & Beauty
I have a electric wheel chair and it's telling me right brake fault,can you tell me what that means
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 137 Answers
Hellllo...C.R.....there are a million of these chairs---fast way--go to google & or utube enter the model # you will be on your way..tkx....g.scott
Posted on Apr 19, 2017
    Master:
  • 224 Answers
Hello Catherine,
Your wheel chair sounds like it has a computer that monitors its systems. When something goes wrong with a system it alerts you that something has gone wrong...in this case your right brake is malfunctioning. To be safe, call for service from your dealer.
My shoprider fpc is flashing 6flash 2sec. off 6 again DL5.2i controller can anyone tell me how to find the codes or tell me what this one means.
A 6 blink means the motors are in free wheel position. Turn chair off put freewheel levers in the locked position. You should not be able to push the chair when the motors are engaged. Leave the levers locked then turn the chair on again. If that does not work the motor/s could be unplugged.
Aug 12, 2015 | Shoprider Health & Beauty
Golden compass power chair
Each wheel is run by a separate motor. This looks like either bad controller box, or bad motor. If it starts out working fine, then the one wheel stops after a short period of time, then it is probably a controller at fault. However if the motor is overheating due to mechanical binding such as a brake failure (the parking brake) or lacks lubrication causing excess power consumpltion, then the controller will shut down at some poiunt to avoid damaging itself and/or the motor. have a helper put the chair up on cememnt blocks, or woodne boxes etc, so you can observe it running. Listyen to the motor by doing left full and right full turns. The motors should be equally quiet and run at the exact same speeds. Dragging noises indicate a problem. be sure your parking brakes are disengaged. Now with the chair off, rotate eaach wheel by hand. They should need the same amount of force to move. if the bad wheel is harder to turn then it may need replacing or has bad brushes, brakes binding or in most cases dried up grease in the gearbox.
Feb 19, 2013 | Golden Technologies Alante' Power Chair
Jazzy select contol panel all leds flash 7 times. what does that indicate?
This problem may depend on which main controller your chair has fitted. It should be a Penny & Giles GC controller. US versions should have a GC3 whilst here in the UK, it would be fitted with a GC2. However, the diagnostic flash codes for these two controllers should be the same. The reason im slightly confused is that you say 5 flashes mean your charger is connected at power up, when in fact it should be a Right Motor Wiring Fault. 9 flashes is indeed a Solenoid Brake Fault, or in other words, the wheelchair is in 'Free Wheel' as you have described. Therefore, IF your controller is in fact a Penny & Giles GC, 7 flashes would mean a Joystick fault. There is not much you can do to diagnose this other than checking connections between the Joystick and main controller. If these are OK, it is likely that a new Joystick controller will be required as having these fixed is usually not cost affective. Hope this is of some help to you.
Jan 27, 2013 | Pride Jazzy Select 6 Indoor Power...
Blinking yellow wrench light on pride jazzy 614 HD
Your version has a Dynamic Controls model controller and joystick.
Unplug the charger and engage the motor/brake lever so the chair is no longer in free-wheel mode (con't push by hand)
Turn the chair off, wait 5 seconds, turn the chair back.
If chair still does not run and your wrench is flashing you have a problem. Count the wrench flashes - the flash count indicates the error detected. 3, 4, 5, and 6 flashes indicate and error with the motors.
3=Left motor fault
4=Right motor fault
5=Left brake fault (may not be engaged)
6=Right brake fault (may not be engaged)
Any other fault code usually means the electronics or wiring is bad and not worth fixing.
Jan 06, 2013 | Pride Jazzy 614 Hd JAZZY 614HD
The wheel chair when I push the button to turn off the power lights will go off but then come back on blinking 6 times, and keeps on doing it until the battery go's dead.
6 flashes indicate a right park brake fault or you have the right wheel in freewheel check the freewheel lever on the right motor to make sure it is in the drive mode Hope this helps
Mar 28, 2011 | Electric Health & Beauty
Wwe have a pronto m41 mobility chair.the service indicator light is telling me its a right brake problem can i fix this and how. also the led lights are chasing left to right. i have to get this working...
First thing you must know is that the error codes are reversed on Pronto chairs with SPJ+ joysticks.
Only one year the M41 was made that the codes were correct. From approximately April 2008 to May 2009 was the only time a left error code ment left motor and a right code ment a right motor. Same for brake codes.
Brakes codes happen when the brake is out of gear, unplugged from the control brain or wire cut. Also from internal coil damage. Unless it's a wire you can reconnect you cannot fix the brake.
Dec 23, 2010 | Electric Mobility Invacare Pronto M41...
I have a Pride 1143 Jazzy Electric wheel chair and the controller is constantly flashing. This happened after I drove into my van and locked into the e-zloc. My husband sid I drove in too fast and caused...
Hi
Rapid flash of lights indicates a fault in the VSI or the electrical system. You need to refer to " VSI Error Codes" on page#32 of this User Manual:
Pride 1143 Jazzy Electric wheel chair User Manual
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Jul 25, 2009 | Select Jazzy Used Electric Wheelchair
THERE IS A TINY YELLOW LIGHT THAT IS FLASDHING 6 TIMES
Depending on your joystick that is either a right brake fault or a controller fault.  Try turning it off, pull both brakes out of and back into drive mode and then turn it back on.  If that doesn't fix it then you may need to get a tech out there to look into it.
May 21, 2009 | Golden Technologies Alante' Power Chair
No drive,flashing green light
Are you sure the FREELEVER is in the right position ? , to test try to push the scooter ?
Battery Low ?
Mar 12, 2009 | Electric Strider Midi 4 Wheel Mobility...
Wheel chair will not stayed charged.
Something is discharging your battery. Possible the unit have ground fault that cause the battery lost its charge. Try to remove this ground fault & you will solve the unit problem.
Feb 19, 2009 | Jet 1HD Power Electric Wheelchair
Health & Beauty Logo
54 people viewed this question
Top Electric Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Colin Taylor
Are you an Electric Health and Beauty Expert? Answer questions, earn points and help others
