Question about Fujitsu Heating & Cooling
Fujitsu halcyon ac model ASU7RLF1 w/remote. I'll put it on what mode I need. But nothing happens.I'll choose auto or adjust the temperature. it'll come on for a few seconds and then turn off.
    Master:
  • 272 Answers
Is this unit battery powered?
Posted on Apr 19, 2017
  • Asia Lawson
    Asia Lawson Apr 19, 2017
    I think so. It's mounted on the wall. I don't know the specifics since it was already here when I moved in.
  • jackdo2 Apr 19, 2017
    Hi Asia, follow the link for some tips on how to reset the remote.
    https://www.youtube.com/watch?v=qo2l4Wml...
  • 86 Answers
SOURCE: I need a Remote plate for windows split ac
remote problem.replace remote
Posted on Mar 17, 2008
bobotfel
  • 236 Answers
SOURCE: replace remote control unit model ar-fb2
If your remote control have display but cannot transmit signal to the unit. Confirm first if the remote is really the problem, using your camera or cellphone camera as your eyes point the remote transmitter to your camera and "on" the remote. You should see light emits in your remote control, if no emitted light then the remote control is defective. But if there is a light the defect is in the unit receiver.
Check also if there is a reset or rst button in your remote control and reset it and try.
Check also if there are error codes in the unit, reset the unit by disconnecting the power supply in the unit for 10 sec. and "on" again and try.
The unit can be operate without remote control, use the manual button located in the unit.
If the remote control have no display replacement of remote is recommended.
Posted on Jan 16, 2009
  • 285 Answers
SOURCE: auto adjustment in progress popping up and
Right click on your desktop, go to properties, and navigate to the settings tab. There, try to set the monitors resolution to the largest available. That should fix your problem. If it doesn't just try some other resolutions until ou find one that works. I hope this helps, Yannick.
Posted on Jun 09, 2009
alishahid13
  • 8 Answers
SOURCE: How to use thermostat for heat on Fujitsu IAQ
This unit comes with a remote control (optional wall mounted wired thermostat available) as a standard feature. This unit is precharged with the environment friendly R-410a refrigerant. No additional refrigerant is needed if the line set is 49 feet in lenght or shorter. In addition to its very high 20 SEER efficiency rating, the 15RLQ is only 31 in. long which makes it the smallest Mini-Split System in its category through out the industry.
This category of equipment is ideal for smaller spaces where spot cooling is required. Several models in this category are ENERGY STAR Certified, meaning they save you money on your utility bill. Residential applications including sunrooms and additions are made easier with these air conditioners and heat pumps. Do you have a warm spot in your home? Fujitsu mini-splits can provide extra cooling capacity for those hard to cool areas. Commercially, their small size makes them ideal for small offices, providing individual temperature control.
Fujitsu's I.A.Q. Systems provide residential and commercial property owners an innovative solution for clean, temperature-controlled indoor air. The Halcyon IAQ systems deliver powerful heating and cooling, are designed for ease of use and maintenance, and feature an unobtrusive design which can be integrated easily into any decor. The Halcyon IAQ systems filter dust, pollen and odor making them the perfect addition to any home!
  • Wireless Remote Control
  • Plasma Filter
  • Sleep Timer
  • 24 Hour Timer
  • Dry Mode
  • Auto Louver: Up/Down
  • Auto Mode
  • Quiet Mode
  • Auto Restart/Rest
  • Auto Changeover
  • Low Ambient
  • Cold Prevention
Warranty All Fujitsu ductless mini-split air conditioners and heat pumps come with a 2 year parts and 6 year compressor warranty.
Important: All installations must be performed or supervised by a certified HVAC technician in order for the warranty to be valid.
Posted on Dec 08, 2009
SOURCE: Stuck on Standby, Fujitsu Plasmavision: Model pds4229e-b
I had exactly the same problem with a Fujitsu General PDS4208E. After looking at the forums etc bit the bullet and tracked down an ORIGINAL remote. Paid yesterday, arrived today - batteries in...screen back on!! One proviso here: Before you pay big money for an original remote (and ONLY they will work with these 2nd generation plasma screens not universal remotes) make sure that your screen WAS working before it was in the standby mode. try http://www.portables.co.uk/ on +44 208 968 1444. Ask for Andy. He seemed to know what he was talking about. About £50 +VAT plus next day delivery charge. Alternatively borrow mine at £5 a button press!! ;-))
Posted on Jan 26, 2010
We need a manual for fujitsu Halcyon ao09r2 model air conditioner. Can we move it?
get in an ac specialist who can pump the gas back into the compressor /receiver and then close off the system
after that is done you can move the units anywhere and after installing properly can release the gas back into the system
Apr 14, 2018 | Cars & Trucks
Aug 1, 2015 Where can I buy Remote for Fujitsu ASU18C1 quickly?
from a fujitsu service dealer or service agent for fujitsu ac
Aug 02, 2015 | Fujitsu Heating & Cooling
I have recently installed 1Te Voltas 2 star A.C. I need clarification on the following 1) In cool mode, what is system of auto cut. Suppose I put on remove temp 27deg C. Temp of the room goes up to 26 deg...
Dear Mahesh
In Cool Mode
Temp Diff - + - 1 deg C in Room Temp & Set Temp
This is auto cut
In Dry Mode
Comp Runs for 10 mins then get off for 5 mins then again get on for 10 mins this cycle continuues.
Oct 15, 2013 | Whirlpool ACQ158XP Wall/Window Air...
I need NOMA N1508 manual.
answer 1 Function and operation
1 - This timer has 3 working modes
a - Auto Mode(AU)
b - Auto and Temperature Control Mode (AC)
c - Manual Mode (LL)
Press "MODE" button and the LED display will cycle through these three modes.
2 - There is an output indicator light which turns Green (On all modes) and red (Off - manual mode)
3 - There is a bettery backup that can retain programs for about 1 week after power outage.
Operation
1 - On first use . Connect the unit to 125V AC power source. The LED display blinks 'C'. The unit at this moment is in initial state, where time and program need to be set.
2 - Press the "TIME" button, the LED display will now show "12.00", now the unit is entering time setting mode
a - The time interval for this product is 15 minutes
b - Press "TIME" button again. LED dislays 12:15 with each press of the time button the time increases by 15 minutes. If you press and hold the time button for 2 seconds the LED will increase rapidly.
c - After setting the time, press the enter button and the LED will display current time setting.
d - To change the clock press the "Enter" and the "TIME" buttons simultanously to enter the editing mode. Press the "TIME" button to adjust the time. Press the enter button to confirm
3 - To program press "mode" button once and the LED will display "AU" which stands for Auto Mode, press the "MODE" button once again and the LED will display "AC" which is the Auto and Temperature Control Mode. Press the "MODE" button once more and the LED will display "LL" which is Manual Mode. Press enter to confirm the selected mode. Press "MODE" button to role over these three options.
a - Auto Mode
Press "MODE" button and the unit will enter Auto Mode, LED displays "AU"
- Press "ENTER" button to confirm. LED displays "P". Press "TIME" button to set program ON time.
- After the program ON time is set press "ENTER" button to enter program ending time. LED will display "E". Press the "TIME" button to set the ending time.
- Press "ENTER" button to return to normal time display mode.
- The program indicator will be turned on after the ON time and ending time have been programmed
- Press the "TIME" button to review the program ON time setting and program ending time setting. The LED displays "P" and "E" respectively. After that the LED displays the current time.
- In case you want to modify the setting repeat step "a".
*** Note: When entering your program if no action takes place within 15 seconds it will go back to the time screen.
Press the "MODE" button and the LED will display "AU". Press the "MODE" button again and the LED will display "AC". press the "ENTER" button to confirm.
- The timer activates the load only when the folloewing two conditions are met:
1 The temperature is below -10
2 The program on time p is reached
For instructionsn on how to set the program ON time and the program ending time please refer to the Auto Mode fucntion
- The program indicator will be turned on after the ON time and the ending time have been programmed.
- When the program ending time is not yet reached, the load will be deactivated if the temperature rises above -7 and will be activated again if the temperature drops below -10. Once the prgram ending time is reached the load will be deactivated regardless of the temperature.
C - Manual Mode
Press the "MODE" button to select Manual Mode. When the LED displays "LL" press the "ENTER" to confim. The LED returns to show the current time. Press the "TIME" button to activate the timer the LEd will display ON. Press the "TIME" button again the LED will display off.
- In Manual Mode the output indicator will display red when the load is deactivated and green when activated.
- To exit manual mode press "TIME" and "MODE" buttons simultanously and the unit will return to Auto mode. The loading will be activated and deavtivated according to the previous setting.
4 Output indicator
1 - In Auto Mode ort Auto Temperature Control Mode when the loadind is deactivated the output indicator tunrs off.
2 - In Manual mode the outpur indicator turns red when loading is deactivated.
3 - In Manual Mode, Auto Mode and Auto Temperature Control Mode the output indicator turns green when the output is activated.
To reset all of your settigns including current time and programs, press and hold the "ENTER" button for 5 seconds from the "TIME" mode. answered 3 weeks, 2 days ago by Anonymous
Jan 11, 2011 | Sport & Outdoor - Others
We just moved into a rental. It has the Fugitsu wall-mounted Air-conditioner model: ar-jw2 but, there was no manual left behind and we are trying to use the heat, however, it just blows cool air, we're not...
Look, if you select a temperature above ambient temperature, it will switch from cooling to heating.(assuming that the aircon has a heat pump. most do these days.) Just dont rush the aircon because every time you make a setting change, it takes a while to regulate.
Aug 12, 2010 | Heating & Cooling
How to use thermostat for heat on Fujitsu IAQ halcyon
  • Plasma Filter
  • Sleep Timer
  • 24 Hour Timer
  • Dry Mode
  • Auto Mode
  • Quiet Mode
  • Auto Restart/Rest
  • Auto Changeover
  • Low Ambient
  • Cold Prevention
Dec 08, 2009 | Heating & Cooling
Heating & Cooling Logo
227 people viewed this question
Top Fujitsu Heating & Cooling Experts
Fotis Papastamatiou
AJMAL KHAN
Are you a Fujitsu Heating and Cooling Expert? Answer questions, earn points and help others
