Question about Radio Communications
I have very much noise in my base station recieve,it gets worse after sunset! I do have high power electrical transmission lines about 200' from my ground plane antenna cant find help anywhere
CORDLESSGURU
  • 106 Answers
SOURCE: siemens 8825 gigset 2 line phone
If your system was working fine, and it all of a sudden started doing this, it sounds like your base has taken a surge of some kind. Your base needs replacing. You can try re-registering the handsets, but from my experience the problem is fatal. Now if this is a new installation and the handsets never work yet on the base, you just need to register them. You can download the manuals or get tech tips at Siemens website, gigaset FAQ pages.
Posted on Feb 11, 2008
LizDahl
  • 75 Answers
SOURCE: Harmony power head parts
I work for Aerus Electrolux, my office #570-326-1731 if you call with the model #s and etc I can find out what you will need. Liz
Posted on Feb 23, 2008
  • 1894 Answers
SOURCE: I have a KX-TG6700 base
you are right its the problem of base station
for this you have to call a tech to fix it
also you have to tell him to check your phone line also
Posted on Mar 16, 2008
blueextc3221
  • 15935 Answers
SOURCE: Radio Stations are all static
If the antenna isnt there... that may be the problem!! LOL
Have you tried an aftermarket antenna directly to the radio to see if it works properly?
Fixed MAST antennas usually designate a standard 31" antennas protruding from the wheel well on either the passenger or Driver side.... not the bumper.
A solution to the fixed mast/car wash problem is to go with an interior glass mount or hidden antenna. This keeps your wiring out of the outside corrosive environment as well.
http://www.autotoys.com/pics/793new.jpg is one version
http://motorcyclestuffwarehouse.com/images/14721_kur_853_tt_h_pu.jpg is another type.
Finally...
http://akamaipix.crutchfield.com/products/2005/120/h12044UA200-f.jpeg
Posted on Jan 10, 2009
thetez
  • 32 Answers
SOURCE: CB Base Station picking up electrical interference
i dont know what AC DC adator your using. you should look into a 12V power supply. or plugging that into a RF canceling power strip, like a monster power strip. TV's that are on or other appliances may cause high noise levels on the CB, make sure your coax is good, your antennas good, and all jumpers are good. its hard to tell with out looking at it, but do a quick once over of the system.... you are using a base antenna right? if not you need to create radials for a mobile you plan on using for a base.
Make sure the connectors on the coax are all on right, this causes problems a lot of the time. sometimes even brand new coax have bad connectors installed.
Posted on Jan 11, 2009
Buzzing or static noise on AM radio; is there a fix?
AM radio signals are very susceptible to what is called spurious radiation that is to say for instance high power electrical lines, noise from the car's electrical system like the alternator and the ignition system. I would have to hear the noise to know which you have. You also may just have a defective radio. Check one thing make sure the antenna is well grounded to the chassis of the car where it is mounted.
Jun 10, 2016 | Cars & Trucks
I have a KX-TG6700 base station and 4 Handsets. When I have been calling on the handsets I have recently found that there is static on the line. Later I realized that there is problem with the DTMF being...
The KX-TG6700 manual at: http://www.panasonic.ca/PDP/OperatingInstructions/kxtg6700-oi-eng.pdfhttp://www.panasonic.ca/PDP/OperatingInstructions/kxtg6700-oi-eng.pdf
States:
For best performance
Base unit location/avoiding noise
The base unit and other compatible
Panasonic units use radio waves to
communicate with each other.
For maximum distance and noise-free
operation, we recommend the following:
LPlacing the product away from electrical
appliances.
LPlacing the base unit in a HIGH and
CENTRAL location with no obstructions
such as walls.
LRaising the antennas vertically.
LIf you use the handset near a microwave
oven which is being used, noise may be
heard. Move away from the microwave
oven and closer to the base unit.
LIf you use the handset near another
cordless phone’s base unit, noise may
be heard. Move away from the other
cordless phone’s base unit and closer to
your base unit.
Have you considered all these points?
Is there a way you can move the base station to another location in your house to see if the problem get better? I don't beleive your base station is faulty, I suspect interference from something.
I don't think the 2.4GHz set is causing any issues, but you never know, try unplugged it for a while to investigate.
If you do determine that the base station is faulty there probably isn't many options to get it repair other than sending it to Panasonic. May be cheaper to buy a new base station to go with your extra handsets.
Good Luck!
Mar 14, 2008 | Lands Phones
On AM radio, there is often a sound, like a hammer hitting a 55 gal. drum interrupting the program. Does not do it on portable radio carried in the car.
all stations AM?
is the engine running?
for get the portable, some have vastly better a/m radios than any car has. in fact many cars radios a/m OR of horrid quality.
i can tell you why but its boring. (AGC, read up on that)
did you try the radio in car, parked say across town.?
did you try all stations
are you like 1 block away from an AM radio station, overloading yours.
AM radios are basically noise making radios., that is why FM was invented to stop that noise, (i cant hear it so.........?????)
are you listening to far away stations, this is normal
in fact you might hear 2 stations on same channel (freq)
and they will beat against each other.
on case of is in S.Calif where your station is clobbered by high power mexican stations 50,000 watts. strong.
and worse a night, does it get better in the day?
here is my advice, many AM stations have a rebroadcast on FM.
go there and listen. (use SAT radio?)
AM radio is subject to vast sources of noise.
ignition noise., high voltage power transmission line noise.
machinery noises, (electric)
or even illegal transmitters in your hood.
many new cars the AM radio is junk, they use this very cheap
chip inside that does this very poorly, but allows them to say
it has AM. ( for $1 cost)
the FM side is 10x better, or more. move up to FM like we all did back in 1967. (i used to build and sell converters back then)
answering for , all other modes work perfect, but AM radio..
Oct 28, 2015 | 2015 Jeep Grand Cherokee
The antennas on both 1,2 are blinking how can i get them to stop and to connect to my phone line,and plus they say that no link.reconnect base ac adaptor? And how to reset them to work again?
When both handsets have the antenna symbols blinking the base set is not working. So check that part. It has nothing to do with the phone line, because the connection between base station and handset should also work without the line connected. Check the power supply of the base station or its cable. When you are 100% sure the power supply is giving the correct voltage and enoug current I'm affraid the base station is defect.
Mar 26, 2015 | Lands Phones
No transmit or recieve
sounds like a repair for a tech to me.
Jan 16, 2014 | Galaxy Radios SSB Echo Base Station CB...
1997 Lexus LS400 electrical problems
The short answer to you question is yes, eventually. The transmission fluid on the wires can harden the insulation on the wires which then cracks when the wires flex and at that point it can short out. The lights dimming and the wipers slowing are indications of a high power draw and add to that it gets worse when it's wet make it a lock that you have, probably, bad wires. Carefully inspect the full length of the wires. If you find cracked or worn insulation either repair the short if it is worn or replace the wiring harness if the insulation is at all cracked. Most likely it will be a major power line. Good luck.
Jan 12, 2014 | 1997 Lexus LS 400
Panasonic phones say "line in use", have unplugged batteries in all phones and have unplugged and plugged in again all phones. Any suggestions?
The base station may have gotten 'zapped' by a high voltage transient, they are not very well protected against transients arriving via the telephone line. Try removing the line from the base station to see if the display no longer gives you that 'line in use' message. If it does, the base station is toast. If it doesn't, dig around and find an non-electronic phone to plug into your phone jack to see if you have a dial tone. We keep at least one of the old style phones to use during power outages since cell phones are useless in our area.
Mar 08, 2010 | Uniden Cordless Phone
Jan 02, 2009 | Cobra 29 LTD CB Radio
Panasonic Phones are on mute and will not work
The following is generic for most cordless phones:
Did you check to make sure that the phone is not in the intercom mode? If this phone has a base station speaker phone, make sure it is not on mute. Some of these phones have a fax connection. Make sure your phone line is not accidently pluged in to the fax section. Also if the phone has a fax monitoring feature check the the setup menu that the fax is not enabled. If the phone has an answering machine mode, make sure that this feature is turned off.
In the worse case:
There may be a defect in the X-Mit section of the phone. I would suspect the fault to be in the base.
Jerry G.
Apr 09, 2008 | Panasonic KX-TG5632 Phone
Radio Communications Logo
29 people viewed this question
Top Radio Communications Experts
eradiostore
eradiostore
Are you a Radio Communication Expert? Answer questions, earn points and help others
