Next step to check - Computers & Internet
I put the battery in and the it loads goes and have a quarter left and then is goes white and says jvm error 545 and reset please help me now
Step #1
Before starting make sure that BlackBerry Desktop Software is installed on the computer.
Step#2
Make sure that you have installed updated device software installed in your PC. Check this link to get update device software from carrier OS download site.
Step#3
Users can perform a full or selective backup of the data using the Backup and Restore tool in BlackBerry Desktop Manager by completing the following steps:
  1. Connect the BlackBerry device to the computer running BlackBerry Desktop Manager.
  2. Open BlackBerry Desktop Manager.
  3. Double-click Backup and Restore.
  4. Select Backup to perform a full backup or select Advanced to perform a backup of specific databases.
  5. Choose a location to save the backup file, then click Save.
Step#4
To perform a clean install of the BlackBerry Device Software, perform the following steps:
  1. Connect the BlackBerry smartphone to the computer and open BlackBerry Desktop Manager.
  2. Double-click the Application Loader icon.
  3. Click Next to start the installation process.
  4. Type your BlackBerry smartphone password, if prompted, and click OK.
  5. Click the check boxes next to the names of the applications you want to load, and then click Next.
  6. Click Advanced, and then click the check box beside Erase all currently installed applications.
  7. Click Next.
  8. Click the check box next to Do not automatically backup the application data during the loading process.
  9. Clear the box next to Backup and restore applications installed wirelessly.
  10. Click Next > Finish.
  11. When the process has completed, the message The loading operation was successful will appear. Click Close to return to BlackBerry Desktop Manager
May 03, 2011 | RIM BlackBerry Storm 9530 Smartphone
I have JUM error 102 on my blackberry pearl phone and now it wont power up, is there a way to fix it without having to replace the whole phone?
Try to put a good battery,if it still not working flash it with desktop manager and a new blackberry firmware.
Mar 20, 2010 | RIM BlackBerry Pearl 8100
1998 buick park ave. rear window defroster not working. fuse is good, has anyone replaced the black box located next to rear window where element plugs into along with the antenna. element on window is not...
Rear Defogger Inoperative, But Heated Mirrors Operate Correctly
1. Connect scan tool. Turn ignition switch to RUN position. Turn rear defogger on. Using scan tool, display BCM
outputs. If rear defogger is being requested on, go to next step. If rear defogger is not being requested on, go to
step 10).
2. Ensure ignition switch is in RUN position. Remove rear defogger relay from rear junction block, located on center
right rear of passenger compartment, under rear seat. Connect test light between ground and defogger relay
harness connector terminal F3 (Brown wire). If test light illuminates, go to next step. If test light does not
illuminate, go to step 11).
3. Connect test light between ground and defogger relay harness connector terminal A2 (Red wire). If test light
illuminates, go to next step. If test light does not illuminate, go to step 12).
4. Connect test light between defogger relay harness connector terminals A2 (Red wire) and B3 (Purple wire). If test
light illuminates, go to step 13). If light does not illuminate, go to next step.
5. Disconnect rear defogger positive and negative feed bus connectors. Connect a jumper wire between defogger
relay harness connector terminals F3 (Brown wire) and A4 (White wire). Connect test light between ground and
positive feed bus connector terminal "A" (Black wire). If test light illuminates, go to next step. If test light does not
illuminate, go to step 8).
6. Connect test light between positive feed bus connector terminal "A" (Black wire) and negative feed bus connector
terminal "B" (Black wire). If test light illuminates, go to next step. If test light does not illuminate, go to step 9).
7. Repair open in Black wire between rear defogger and ground. Recheck system operation.
8. Repair open in Purple wire between rear junction block and heated backlight antenna module. Recheck system
operation.
9. Check for proper terminal contact at rear defogger connectors. Repair as necessary. Recheck system operation.
10. Check for proper terminal contact at BCM. If terminal contact is okay, replace BCM. Recheck system operation.
11. Repair open in Brown wire between rear junction block and instrument panel junction block. Recheck system
operation.
12. Repair open in Red wire between rear junction block and underhood junction block (located in right front corner of
engine compartment, between battery and strut tower). Recheck system operation.
13. Connect test light between defogger relay harness connector terminals F3 (Brown wire) and A4 (White wire). If
test light illuminates, go to next step. If test light does not illuminate, go to step 16).
14. Reinstall defogger relay. Disconnect BCM 32-pin Pink connector C2. BCM is located behind right side of instrument
panel, near rear of glove box. Using DVOM, check voltage between ground and BCM harness connector C2
terminal A3 (White wire). If any voltage is present, go to next step. If no voltage is present, go to step 17).
15. Repair open or short to ground in White wire between rear junction block and BCM. Recheck system operation.
16. Check for poor connection at defogger relay terminals. If connections are okay, replace defogger relay. Recheck
system operation.
17. Check for proper terminal contact at BCM. If terminal contact is okay, replace BCM. Recheck system operation.
Feb 25, 2010 | 1998 Buick Park Avenue
My pc wont turn on
Follow the below Steps:
1st Step: Check whether you have connected the power cable and display cable? If no, connect the same. If yes, then follow the next step.
2nd Step: After switch ON the system, check whether the keyboard lights are flashing? If no, then the problem with the SMPS of your system, replace the same will resolve your problem. If yes, follow the next step.
3rd Step: Try to go to BIOS mode and check whether the HDD has been detected. if no, then check the HDD cables., If yes, follow the next step.
4th Step: Check for any beep sounds. Also check whether the RAM has been properly inserted.
Revert back for more assistance and give your valuable feedback/rating for the solution provided.
Thank you for using Fixya.
Feb 13, 2010 | Sony VAIO VGC-RB42G PC Desktop
Jvm error 547
Here is the procedure to resolve:
Step #1
Step#2
Step#3
Step#4
Click Next.
When the process has completed, the message The loading operation was successful will appear. Click Close to return to BlackBerry Desktop Manager.
Jan 18, 2010 | RIM BlackBerry Pearl 8100
Displaying on my 8310 error 545 incompatible or corrupt filesystem How can I fix it
Try this and please leave 4 thumbs up for me :)
http://www.blackberry.com/btsc/search.do?cmd=displayKC&docType=kc&externalId=KB10406&sliceId=SAL_Public&dialogID=96226826&stateId=0%200%2096222866
Step #1
Step#2
Step#3
Step#4
  7. Click Next.
Nov 29, 2009 | RIM BlackBerry Curve 8310 Smartphone
Suddenly device went to white screen and JUM Error 545 came up, nothing works, will not reset
Step #1
Step#2
Step#3
Step#4
  7. Click Next.
Hope it helped.
Nov 26, 2009 | RIM BlackBerry Pearl 8100
How do I download software back on blackberry
Step #1
Step#2
Step#3
  7. Click Next.
Please rate this if it fixes your issue
Jun 08, 2009 | RIM BlackBerry Storm 9530 Smartphone
Blackberry endless reboot
Try a firmware update on your blackberry. I do not know which country you are in which service provider you are with so please check carefully when going through step 2.
Check below steps for OS upgrade -
Step #1
Step#2
Step#3
Step#4
  7. Click Next.
  11. When the process has completed, the message The loading operation was successful will appear. Click Close to return to BlackBerry Desktop Manager.
May 27, 2009 | RIM BlackBerry Curve 8310 Smartphone
My blackberry 8310 dispaly JVM error 545 and 547 then it power off and never power on again. i tried relaoding it using the software but the pc does not recognise that it is connected. why?
Step #1
Step#2
Step#3
Step#4
  7. Click Next.
Mar 10, 2009 | RIM BlackBerry Curve 8310 Smartphone
Computers & Internet Logo
19 people viewed this question
David Payne
David Payne
