Question about Maytag Washing Machines
My maytag centennial is leaking water from below.
  • Whirlpool
    Whirlpool Jun 16, 2017
    Hello Jennie, we apologize about the frustration you have experienced with your Washer. If you still need assistance, please provide your name, the name of the site you were contacted on (fixya.com), your user ID name ( Jennie Lui ), your phone number, your address, the full model and serial number, and email the requested information to Maytag_Digital@Maytag.com. We would be happy to review your concerns further.
    Top Expert:
  • Maytag Master
  • 44,063 Answers
Suspect a defective pump
Posted on Apr 19, 2017
Repair manual Where I can download the repair manual for the maytag centennial washer
This is a manual. Since there are so many versions, you might need to search for the appropriate one. I searched for "Maytag centennial top load washer repair manual". There was a Maytag site, but download was very slow. http://applianceassistant.com/ServiceManuals/8178628_ml-3_maytag_centennial_top-load_washer.pdf#zoom=100#scrollbar=1#toolbar=1 http://applianceassistant.com/ServiceManuals/8178628_ml-3_maytag_centennial_top-load_washer.pdf
Jul 30, 2014 | Maytag Centennial Top Load Washer
Maytag Centennial Top Load Washer drains as it fills.
The water is probably siphoning out of the tub. Your drain pipe is either too low or the drain hose is down too far into the pipe. Take the drain hose out of the pipe and lift it high. I'll bet your problem goes away
Feb 06, 2014 | Maytag Centennial Top Load Washer
The drain hose on my maytag centennial was leaking where it leaves the pump so I pulled it out and tightened the connection, replaced the back, and moved it back into place. On the next load, it sensed,...
You may have interrupted the drain cycle so you may need to empty all the water out to reset sensor.maybe move machine to w/h door and lower the drain hose outside until most of water is removed then start wash again from scratch. Or your out of balance switch activated if you tilted the machine, if so reach in the back at top of bowl and you should find a lever arm, jiggle gently back and forth then try the machine again.
Oct 25, 2013 | Maytag Centennial 3.2 cu. ft. SuperSize...
Washing machine maytag centennial not rinsing, holding water, not spinning, what can I do
Hi michelledack,
Before the Spin Cycle should start, all water must be drained out of the machine. If it does not start, it could likely mean the Drain pump may be clogged. Please follow my below tip on the fix:
ACCESS, DRAIN & CLEAN THE DRAIN PUMP FILTER...
If this does not help, the drain pump may be faulty.
Kind Regards
JEDEMEYER1
* If this solution helped you, please rate it
Sep 05, 2011 | Maytag Washing Machines
Overfilling maytag centennial - brand new?
Sounds like a hose off pressure switch or faulty switch/ however make sure drain connected ok 1st....
Oct 02, 2009 | Maytag Centennial 3.2 cu. ft. SuperSize...
Washing Machines Logo
44 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
