Question about Vizio Televison & Video
Vizio vx37L only showing blue screen saying NO SIGNAL. The manual buttons on side of cabinet are not functioning,except on and off switch, same with remote
After connecting a my ipad,( not the 1st time), as i started to put input sorce to hdmi,with manual buttons , it froze up and now is showing only blue screen with no sitnal. cant choose other input options or any other function on either remote or manual buttons
SOURCE: Input select function... without a remote?
Whew! Found the NE116UD replacement for the EWF2704 Emerson TV (there are other models on the list as well), it can be ordered here for 24.95:
http://www.emerson.newremotecontrol.com/catalog_item.php?catnum=NE116UD
Hope that helps. This problem is certainly very irritating. I have never heard of a remote for 24.95, nice job Emerson -- never again!
Posted on Jun 04, 2009
  • 20 Answers
SOURCE: HDMI connection problem
On your TV set remote are you selecting the proper input; for example when you have different devices connected to the back of your tv set, dvd player, vcr, cable box etc; you have to tell the tv which device you want to use by selecting the right one on your tv remove input selection. Hope this was any help.
Posted on Sep 08, 2007
SOURCE: VIZIO vx37l tv remote control code for cox tv remote
0178 will work but you have to keep the set-up button pressed down for more than a few seconds after you press TV on your cox remote. (You will see the tv button light up 2 or 3 times after pressing it and holding the set-up button down)
Posted on Feb 19, 2008
SOURCE: unit "froze" Is there a reset?
I had a similar problem with a MX-3000 2 years ago. The unit would continually freeze. I think it was a problem with the first few units. Since then I've bought a new one and had no problems. Then this weekend, it froze for the first time (the battery is not holding a charge so I think that led to the problem).
If you open the back cover, there is a silver button just above where the battery plugs into the remote. Pushing that button should perform a reset. As an alternative, you can remove the battery at the connector. It is recommended that you use the button and not the connector. It is in there tight on my unit and pulling on the wires can cause a break.
Gary
http://twitter.com/GaryHuff
Posted on Feb 28, 2009
SOURCE: Have a Vizio VX37L that when it is turned the
HERE'S THE FIX: I just went through this with my Vizio VX37L. TV is stuck in RGB input. This is the fix.... TV is stuck in RGB input.
(option 1) Power on TV, and press the INPUT button repeatedly and rapidly until you can change to a different input, such as AV.
If that doesn't work, try:
(option 2) With the TV off, press and hold the INPUT button on the side of the TV for about 5 seconds. The TV should power on and the input list will appear. The TV will no longer be locked, and the INPUT button should function properly after that.
Option 2 worked for me!
Posted on Dec 13, 2011
Vx37l blue screen
If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/
Sep 29, 2016 | Vizio 37" vx37l hdtv widescreen lcd/tv...
My vx37l powers on get a blue screen then shuts down
Displays blue screen and shut down; denotes no signal input to TV. Check all the signal inputs, Ariel, AV or so. If all are found OK, the tuner to this TV is faulty. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Dec 22, 2014 | Vizio VX37L Television
MY VIZIO 37 INCH TV
I think you may have the same thing going on that we had happen several times, I think its stuck in RGB mode. Go to the TV itself, and turn it on manually. As SOON as you turn it on, hold the input button on the side of the TV for 30 seconds. This should get it back to the normal TV mode. We got this fix from Vizio ppl.
Jul 12, 2012 | Vizio VX37L Television
My vizio tv,VX37LHDTV10A darkened and shows shadows in the back ground from previous channel. Do i need to replace the back light inverter master or the main unit part?
This may work for you. My Vizio went black except for the blue channel rectangle in upper right corner; I couldn't change the channels or power off. I called Vizio, was told I needed a hard reset, and this fixed my problem: I unplugged the TV; held down the on button for one minute, then plugged it back in. It works fine now.
Mar 30, 2010 | Vizio VX37L Television
Jan 24, 2010 | Vizio VX37L Television
Vizio light is on on the front of tv, but when you turn it on it says no signal and turns off. VX37L
Your TV may be in RGB mode. Immediately after turning your TV on, press the TV button on the 'input' section of the remote. Hopefully that works for you. Your TV is designed to turn itself of in RGB (monitor) mode if no signal is present.
Jan 02, 2010 | Vizio VX37L Television
Our Visio VX37L comes on with blue screen and "no signal" at top of screen, then turns off in about 5 seconds. Does not respond to any of the other buttons such as "input". Once off then will not come back...
Television was repaired under warranty. A new motherboard was installed but did not fix the problem. A new front panel assembly was installed and fixed the problem.
Jul 28, 2009 | Vizio Televison & Video
Vizio vx37l green/red/blue sparkles
Call Vizio tech support and start a case. i am having the same issues with mine and i have sent it back. they will be replacing it this time.
Jan 12, 2008 | Vizio L37 Television
Televison & Video Logo
Top Vizio Televison & Video Experts
CoppellTVRepair.com
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
