Microsoft Excel for PC Logo
Posted on Jul 24, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Odd change added to an even dollar calculation
I am getting odd change amounts added to even dollar and number calculations,..all sells and formulas are even amounts but the values on the right of the decimal are not .00. As I change my figures for calculating this changes but it should always be .00 not .88 or .63.
Can't locate the problem.
Cosma Papouis
Level 3:
Master:
  • Master 409 Answers
  • Posted on Jul 24, 2009
Cosma Papouis
Master
Level 3:
Master:
Answers
409
Questions
Helped
116945
Points
1164
If you look in the options you will find a setting that says "precision as shown" turn that on and it should cure your problem
2answers
What is the method of calculating interest rate for fixed deposit?
Fixed deposit calculations can be done by both manual and automatic methods.Now let us figure out the fd calculation in both ways:
1.) Manual Calculation Technique: It is the conventional process to know your Fixed deposit interest calculation. The formula for manual fd calculation is used as below:
Where,A = Final Amount
P = Principal Amount (initial investment)
r = Annual Nominal Interest Rate (as a decimal, not in percentage)
n = Number of times the interest is compounded per year
t = Number of years
2.) Online Calculator Technique: Nowadays online FD calculator is very amazing technique and it is a very useful online tool that helps you to easily calculate your Fixed deposit return. Online FD calculators uses simple technique in which you need to put your amount, tenure, interest rate and can get accurate results instantly. You can easily calculate and compare the interest receivable by changing the deposit amount.
Mar 18, 2018 • Finance
2answers
How to use power and percent in el-531x scientific calculator.
To use the power, you use the y to the x key, above the EXP key. To enter 2 to the power of 4, you enter 2 hit the y to the x key and enter 4 and hit enter.
To use percent function, you enter the percent key after the number. To calculate Interest, where Interest = Principal x Interest x Time. For example, if the principal is $1,000, the interest rate is 8%, and time/term is 4 years, we would enter 1000 x 8 Percent x 4. When the8 is entered followed by the percent key, it should turn into 0.08.
Good luck,
Paul http://www.sharp-world.com/contents/calculator/support/guidebook/pdf/Operation_Guide_EL-531W_ser.pdf
2helpful
2answers
What is formula to find percentage of females in my workplace?
      To get around this, you can calculate your numbers as percentages first. For example, if you type the formula =10/100 in cell A2, Excel will display the result as 0.1. If you then format that decimal as a percentage, the number will be displayed as 10%, as you 'd expect.Aug 2, 2011
      How to do percentages in Excel - Office Blogs
      https://blogs.office.com/2011/08/02/how-to-do-percentages-in-excel/
    Feedback
    How to Calculate Percentages in Excel
    www.excelfunctions.net > Excel-Formulas
    Two Percentage Calculation Types. Calculate a Percentage as a Proportion.Calculate Percentage Change. Displaying Percentages in Excel Cells ...
    Excel formula: Get percentage of total ' Exceljet
    https://exceljet.net/formula/get-percentage-of-total
    Excel simply divides the values in column C by the total in C11. For the formula shown, the result is the decimal number .63. Because the Percentage number format is applied to cell E6, Excel displays .63 as 63%.
1helpful
HOW CAN I INSERT THE EQUASIONS IN TO CASIO FX-85GT PLUS, SO IN THE EXAM I WILL EDIT THE NUMBERS ONLY?
Same question, same answer.
Sorry, but you cannot.
You can type in a formula that involves the memory variables X,Y, A, B,C,D, E, =, . Such a formula is meant to be evaluated to get a solution (X by default). Once you type the formula you press the Shifted function SOLVE and you will be prompted for the constants, for Y etc. when you press the EXE/= key you get the value of X.
If you turn off the calculator or change the calculation MODE, it is wiped out of memory.
To make a long story short, you cannot STORE formulas in the calculator. Better try to memorize them (commit then to YOUR OWN memory).
How to calculate interest rate based on original balance and payment amount using BA II Plus
Work with the simple formula: Interest = Initial * rate * time
To find the total amount, add the Initial plus the Interest, then subtract what has been paid. This will change the amount of money that will be accruing interest, though, so if there is a payment schedule you will need to repeat this calculation to get an exact number.
Find more information on wikipedia: http://en.wikipedia.org/wiki/Interest#Simple_interest
Need a formulae for 'Interest calculation' for 'Over-draft loan'
Try this formula=((A1)*(1+A2))-A3 Where: A1 is the original Balance A2 is the interest rate A3 is the money paid for the preceding month
3helpful
2answers
TI 83
Yes you can use it, here is the formula: Y= V(t+ (i/c))^(tc) V=amount put in, t=time, i=intrest rate, c= amount of times it is compounded.
(I know this because I have a TI-83 calculator)
2answers
Can't reopen circular reference file in excel
  1. Click the Microsoft Office Button , click Excel Options, and then click the Formulas category.
  2. In the Calculation options section, select the Enable iterative calculation check box.
  3. To set the maximum number of times that Excel will recalculate, type the number of iterations in the Maximum Iterations box. The higher the number of iterations, the more time that Excel needs to calculate a worksheet.
  4. To set the maximum amount of change you will accept between calculation results, type the amount in the Maximum Change box. The smaller the number, the more accurate the result and the more time that Excel needs to calculate a worksheet.
2helpful
Calculated field in Excel pivot
Count will only work with numbers. So select another box where you want your number and use this formula: =count(x:x) This should give the count number then you will need to find the difference. In another box, use =sum(x-x). This should give you your difference.
If this helps you, please rate me. Thanks, Patty
Top Microsoft Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
k24674
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
