Question about Garden
We have a 50 inch zero turn riding mower and the blades kick off when you back up, then when you go forward they won't engage what could the problem be?
SOURCE: Stalls when engage blades in forward, but cuts fine in reverse
Did you try to disengage the safety feature that should shut the tractor off when the blades are engaged and the tractor is placed in reverse? I believe that it is located under the shift leaver
Posted on May 15, 2009
SOURCE: Craftsman 18.5 riding mower when I engage the
craftsman decks have a positive stop adjustment for the decks. A spring atached to the blade ingadgement arm pulls the tension pully into position if the cable is rusted inside the sleeve it wont put enough pull on the ingadgment pully and thus the blades dont spin full force the belts on the mowers have no adjustments only the pully . second thing is you may want to drop the deck and clean around that pully by scraping any rust off the surface under the pullys slide good luck
Posted on Jun 20, 2009
wadembly
  • 448 Answers
SOURCE: Craftsman riding mower blades will not engage
maybe the safty switch under seat might be starting to go out if that switch doesn't work the blades wont come on at all for safety
Posted on Jun 28, 2009
  • 109 Answers
SOURCE: Cub cadet Z Force 48 inch zero turn blades won't engage
I hope this will help you...under the side panels on each side of the mower, there are "reverse lockout safety switches", they are supposed to stop the blades when both handles are pulled back. If one or both of the switches are out, the deck will not engage. Also, under the right side panel (when sitting on seat) there should be 3 relay switches, the one closest to the motor controls the PTO., if this is out, the PTO will not engage.
Posted on Jun 29, 2009
SOURCE: Craftsman zero turn - blades won't engage
The PTO switch contacts to operate the clutch that starts the blades is defective. I have replaced mine and the new one just failed again. Sears must know this is a defect problem but so far they are quiet about the problem
Posted on Nov 24, 2010
Why aren't the blades engaging all the time?
Faulty connection or partially broken wire, from ignition to blade engage switch or from engage switch to electric clutch.
Aug 07, 2015 | Cub Cadet RZT L50 50" 23HP Zero Turn Mower...
Blade engagement
PTO issue the blade should engage even if your not moving
Jun 21, 2013 | Cub Cadet 50 in. 23 HP Kawasaki Twin...
Troy-bilt riding mower won't move in forward or reverse
I had a similar problem with my TroyBilt 50 inch zero turn mower. Was cutting grass when it stopped going either forward or backward even though it would start and the PTO would move the cutting blades. Turned out the tensioner spring for the belt that drives the motors near the rear wheels had gone missing. Searched the yard where I had cut and moved the machine but couldn't find it. A new one cost me about $7.50. Put the new one on and it worked fine.
Apr 19, 2013 | Troy Bilt 175HP Manual 42" Riding Mower
My 50" troy bilt zero
All riding mowers have a seat safety, blade engage safety and a brake clutch safety, some mowers have a reverse mowing safety. Seat under the seat, blade and brake you will have to check the linkages underneath, and if there is a reverse mowing one I have seen them near the shifter handle right under the fender.
Aug 23, 2011 | Garden
Model RZT42. When you back up the blades shut and when I go back to forward, the blades will not engage.
Some of the newer riding mowers have a safety system on them that won't let the blades work while you are backing up. If the blades are engaged and you put it in reverse they will stop. You usually have to reset the blades, turn them off then back on, when you put it back in forward.
Jul 06, 2011 | Cub Cadet Op's Manual Model Lt1042 Lt1045...
Won,t move
Check the pump.Thanks for asking and I hope this helps out.Please leave me 4 thumbs up.
Jul 20, 2010 | Husqvarna Zero Turn Mower Z5426
Cub cadet rzt 50, hit stump, blades wont engage but not bent
The blades on this cub cadet are activated with air pressure. Chances are that when you hit that stump, you either blew a fuse or the control module that allows the blades to spin. Begin by checking the fuses. J.
May 28, 2010 | Mustang Rzt 50" Zero Turn Riding Lawn...
Jun 25, 2009 | Cub Cadet Street Sign- tractor lawn riding...
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
john h
