Question about Ford Garden
BELT DIAGRAM FOR A FORD RIDING MOWER YT MODEL 16 HORSE TWIN
scrodamoon
  • 659 Answers
SOURCE: i have a 16 hp
well that took alot of work on my part but hopefully one of these will help you out if not well im out of suggestions.
I uploaded the manuals to my server
I know your model is yt16cr and the manuals are slightly diff but hopefully can provide sufficiant info for you.
http://www.files.hpifdesigns.com/pdf/YT160AR-PARTS-LIST.pdf
http://www.files.hpifdesigns.com/pdf/YT160BR-PARTS-LIST.pdf
Posted on Aug 02, 2008
  • 24 Answers
SOURCE: Ford YT-16-G lawn mowers
I need the model number of your mower. Like for example....09GN2151
Posted on Aug 15, 2009
SOURCE: ford YT 16 riding lawn mower won't start. will
Sounds like you have a Fuel Blockage, or a Carburettor problem. Check your Fuel supply, to carb, then check that the "Jets" are clean, and float bowl is OK.
First, check if you have gas. We've all made this mistake, and we've all kicked ourselves later.
Next, pull the air cleaner off. Inspect it to see if it's clogged with dirt, and if so, try starting the engine with it off.
If you're still hunting, grab a can of starting fluid and give the carb a squirt. This is a highly combustible material that gives the engine a short shot of fuel, even if the carb is plugged up and not delivering gas.
When the engine starts with the starting fluid, but dies quickly you'll know that you've got a fuel delivery problem, or a fuel/air mix problem.
Carb ProblemsFor delivery problems, pull the carb off and disassemble, looking for problems and clearing all passages. Most often the problem is just "gunk", but their could be a diaphragm problem, seal problem, etc. Check with a dealer or good book for your carb if you clean it and still have problems.
For the fuel/air mix, pull the needle valve screw out and inspect. Careful not to wrench these down, be gentle. B&S usually call for 1.5 turns out from the seated position.
Use good gaskets on the carb to tank and carb to block connections, otherwise a vacuum leak could be getting you.
http://repairfaq.cis.upenn.edu/samnew/lmfaq.htm
link above is for a comprehensive troubleshooting go through.
Posted on Mar 30, 2010
  • 150 Answers
SOURCE: I need a belt diagram for a 46 inch 17.5 horse
that diagram is usually on mower deck check there
Posted on Sep 28, 2010
  • 3074 Answers
SOURCE: need the belt diagram for a 42" murray riding
http://www.askmehelpdesk.com/attachment.php?attachmentid=21971&stc=1&d=1247528750
Posted on May 06, 2011
How do I acquire a belt diagram for a craftsman 54'' mower deck?
Search for your model number on sears site. If 0 results, search google with your model number. Owners manual usually has diagram.
Jun 07, 2014 | Craftsman YT 4500 54" Kohler 26 hp Gas...
I have a Craftsman YT 3000 cutter. The top belt ( drive train ) belt slipped off how can i get it back on
If you could supply the number under the seat like the following I can answer your question with a diagram.4_10_2012_8_58_29_pm.jpg
Apr 10, 2012 | Craftsman YT 3000 42" Kohler 22 hp Gas...
Need diagram to replace murray 42 inch cut belt
http://www.ereplacementparts.com/ type in model number of your mower ie 40560x50c All parts and diags ypu need ,Yours Henry
Aug 07, 2010 | Murray 38 Lawn Mower Blade Belt '90'96...
I am looking for a belt placement diagram for a 42" murray riding mower-drive belt.
Use your model number & go online for Murray Riding Lawnmower & search. Most of the time you will find it. If not reply back with model numner & HP (horse power)
Aug 03, 2010 | Garden
What year is my simplicity lawn tractor model number 169420 s/n 4248
You are missing one digit on the model number, but I believe it to be a Regent 16hp 2001-2002
Nov 22, 2009 | Garden
My Ford YT-18H model tractor will not accelerate when either in forward or reverse gears. It moves slowly but not with enough power to climb even a snall incline. Could it be a transmission problem, or a...
I need a belt diagram for a Ford Riding mower, Model YT 18H. A diagram for the tractor belts would be greatly appreciated.
bilp07@yahoo.com
Oct 20, 2009 | Ford Garden
I was given a sears riding mower model #917.252631. it has no belts on it. can someone tell me the dimensions and a diagram for installing them. Thank you in advance. sears parts direct does not have a...
Here's a link to Gates Company, an aftermarket company that sells belts like you are looking for. I put all of your info in and these are the two belts they say are correct for your riding mower
Mower Deck FHP Medium Horse-Power V-Belt 6878 pixel.gif Mower Drive FHP Medium Horse-Power V-Belt 6861
When you go to this link, use the drop-downs to specifiy your tractor and follow if you'd like to verify. http://www.gates.com/part_locator/index.cfm?location_id=3598
Sep 08, 2009 | Craftsman Garden
Aug 01, 2009 | Ford Garden
Garden Logo
Top Ford Garden Experts
Dennis Key
Dennis Key
donald boissonneault
fordexpert
Are you a Ford Garden Expert? Answer questions, earn points and help others
