Question about Coffee Makers & Espresso Machines
Sw 30 brim coffee maker will not brew coffee
I push the brew button but all it does is beep. Thin in goes to warm the empty pot
Coldcut
  • 1554 Answers
SOURCE: turn off beeping alarm when the coffee maker is done brewing
you can't ,its up in the top behind the controls.
you have to take the pot totally apart.
only a trained tech should attempt this.
Posted on Apr 02, 2008
  • 5 Answers
SOURCE: does not brew a full pot of coffee
I had the same issue, poured in 8 and out came 6. Here's what I did to clean and fix.
1) Unplug the NHB
2) Remove accessories like the pot and basket
3) Bring NHB over to the sink
4) Snap off the entire top cover (not the swing lid) by starting at the front and lifting upward (the top cover is about 1/4" thick). The back of the top cover will pivot a bit and then pop off exposing the pour reservoir. Remove the flow stopper inside the pour reservoir by lifting it straight up.
5) Place the top cover and flow stopper aside.
6) Remove the brew diffuser (located underneath the top where the brew basket goes. Twist counterclockwise gently but forcefully enough to snap it past the lock tabs which hold it in place. You'll know that it you've done this correctly when it just falls out.
7) Still over the sink, tip the NHB in a fashion where the back side is facing upward and the brew side is facing down into the sink. You'll be holding the NHB horizontally by the top and bottom of the unit. This will allow any water in the tank to pour out the brew spout. Begin to tip the unit as if tipping upside down as this will allow any remaining water to drain out. If this does not work the brew spout hose may be clogged and you can just tip the unit entirely upside down to empty it from the fill hole in the pour reservoir.
8) Return the NHB to the upright position in the sink.
9) Using a scotch brite sponge and some baking soda, clean the inside of the pour reservoir and rinse.
10) Using the tool Bunn provided, clean out the brew spout hose which is located under the brew hat. This is the little hole where the water comes out. If you don't have the tool Bunn provided you could use something like a plastic tie-wrap. Don't use anything metal as the hose you're cleaning is made of plastic tube and could become punctured. Clean this hose for just a minute or two to ensure that there are no significant obstructions.
11) With the NHB upright in the sink, pour a slow stream of hot water from the faucet, about two cups, directly into the fill hole located in the pour reservoir.
12) Tip the unit horizontally, as in step 7, and place the tip of your finger over the pour reservoir fill hole covering it completely.
13) Shake the unit back and forth horizontally so the water in the tank splashes around and frees anything which may be built up in the tank. Some water may splash out of the brew spout hose.
14) Tip the unit as in step 7 to drain the tank water out.
15) Fill a 16 ounce glass with hot water and 2tbsp baking soda, mix and pour into the pour reservoir fill hole.
16) Repeat steps 13 and 14 once.
17) Repeat steps 11 through 14 three times.
18) Clean the pour reservoir cover, swing lid and flow stopper.
19) Put the flow stopper back in place.
20) Attach the top cover.
21) Clean the exterior of the NHB.
22) With the boil and warmer switches off, plug the NHB into the electrical outlet.
23) Turn the boil and warmer plate switches on.
24) Fill the NHB with one pot of cold water and close the swing lid. Wait one minute.
25) Fill the NHB with another pot of cold water. Place the pot on the warmer plate and close the swing lid. If water does not yet come out, fill with one more pot of water.
26) Allow water to drain from brew spout until it stops draining.
27) Empty pot.
28) Fill pot to 10 cup line and pour into the NHB. You should find that the NHB now delivers 10 cups back to the pot. Empty the pot.
29) Clean brew spout diffuser and replace back in the brew hat.
30) Clean the pot, pot lid and brew basket.
31) Wait ten minutes for the water in the tank to boil.
32) Brew your coffee as you normally would.
The only issue I experienced during this process was with the warmer plate switch. It appeared that the light in the switch blew although the warmer plate still warmed normally. Shortly after the water in the tank started boiling the warmer switch light started operating again.
Posted on May 23, 2008
SOURCE: warmer stopped working
the coffee maker brews but the pot warming plate isn't hot
Posted on Nov 08, 2008
  • 2039 Answers
SOURCE: Coffee takes forever to brew
normally when that hapen is the coffee is grinded to fine water has trouble filtering thrue it try corser one and coffee filter pierre
Posted on Feb 14, 2009
freetek
  • 5568 Answers
SOURCE: Coffee maker brews MUCH slower and makes less coffee
It may not help but won't hurt; put a couple of cups of plain vinegar into the water chamber, turn on briefly until it starts to pump, then turn off and leave overnight - at least, if not longer. The mild acid content may clear some lime buildup.
Posted on Apr 14, 2010
Instructions for brim sw 30 coffee maker
Here's a link to the manual for your coffee maker: https://www.manualslib.com/products/Brim-Size-Wise-Sw20-3660959.html
Apr 17, 2017 | Coffee Makers & Espresso Machines
How much apple vinegar do I add to 4oz of water
Hello Linda Mohr,
1/2 White vinegar +1/2 water (wait 30 minutes = success.
This from the HUFFINGTON POST...
Fill the coffee maker's water chamber with equal parts white vinegar and water. Using a paper filter, allow to brew until half the chamber is empty. Turn the coffee maker off and let it sit for 30 minutes, then finish brewing. Rinse the machine by using a new paper filter to brew a pot of clear water.
I would stay away from apples.. grapes,
wine & balsamic vinegars...
I like a strong cup of coffee... but wit a
COFFEE FLAVOR (nothing else).
If you can NOT find WHITE VINEGAR use a commercial
POT CLEANER...
Carnac the Magnificent
Feb 12, 2017 | Coffee Makers & Espresso Machines
My mr. coffeemaker beeps 5 times and doesn't brew the coffee I just purchased this coffee pot last month aug 2014. what could be the problem
I see two problems that you've described.
First, you have a bad empty-reservoir sensor. Mine went out on my first Mr. Coffee within the first month also. The purpose of the sensor is to trigger the beeping to simply let you know when the coffee is done. The coffeemaker would normally work fine otherwise.
Second, you have a bad heating element. This is the core function of your coffeemaker and renders it useless for anything but a nice warming plate.
I recommend replacing the coffeemaker.
In the future, make sure you do not add water to the reservoir unless the coffeemaker has been turned of for at least five minutes. This will help prolong the life of the heating element.
The heating element will naturally degrade over time. But, it can incur sudden damage when the reservoir is refilled with water too soon - while the element is still hot. Because of the simple design, if the coffeemaker is on, then both the warming plate's heating element and the reservoir's heating element are on. So, after a brewing cycle is complete, the reservoir's heating element stays on. Without any in the reservoir to keep it cool, the heating element superheats. So, if water is put in the reservoir while the coffeemaker is on or before the element has adequately cooled, the sudden burst of steam from the water contacting the element can be quite violent.
Sep 21, 2014 | Mr. Coffee Coffee Makers & Espresso...
My mr coffee optimal brew just beeps constant when you press the brew now button
My hubbub and I "downgraded" to an "upgraded" Cuisinart to Mr. Coffee Optimal Brew 12 cup carafe, mainly d/t the carafe keeping the coffee hot with no burn taste and the stylish st. steel carafe. We've had 2 cuisinart's and both gave us leaking issues after 3 years of hard use (2 pots daily). The cuisinart leaked and also had the burned coffee taste, We unpacked the Mr. Coffee, cleaned all parts, after several attempts, finally stopped beeping and ran the first clean cycle. We are past ready for a great cup of joe...NO.pot ready, grounds in, attempt to turn it on and...that beeping almost got and may still get this apparatus taken back, traded, gone....but after reading my book that never says a word about beeping, I googled and saw MDLS1 replied and while I thought it was crazy I was not giving up without pulling out crazy, and it worked. After a solid hour, I found an answer... You can't just tap it here and there, I took resevoir off, banged it good, forceful but not to hurt my hand, took the basket out and banged the top and clapped around all sides, filled her up, turned it on and walla.made a perfect 10 cup = about 5 "normal" cups of joe, and it was good...pot made in 8-9 minutes, stayed hot over an hour when it was finished. Tonight, I have a hot cup, hubbub got his,and we are happy campers...however, one more beep and it's gone.
Dec 06, 2013 | Mr. Coffee 10-Cup OptimalBrew Thermal...
Kenmore Elite coffee maker Model # 100.9101670A Is this model on a recall? How can I get a manual for it? And what is the filter reset button?
I have a manual with mine and as far as "recall" goes on this model, I've not found anything recalling this particular model...<br /> <br /> The most important thing in the manual, that I have found, is how to clean and change the filter. If all else fails unplug the pot for 10-15 seconds; replug it...this resets it...(if it ever acts up, do this; it helps)<br /> <br /> The filter reset button: Your coffeepot should flash a small message stating: "change filter and clean" To do this you first, turn off the pot, remove filter~(the filter is in a long thin black plastic thing and the filter cover simply snaps and pulls apart to expose the charcoil filter; Remove the Filter, then fill the coffee pot with 7 cups of vinegar plus 7 cups cold water; Place a paper type regular coffee filter in the brew basket, or a thin paper towel works well too~(This traps and holds particles that get trapped inside the pot)<br /> <br /> Before brewing; PLEASE NOTE, brew the first pot of vinegar/water mixture only HALF WAY then TURN OFF and let it sit for a good 15 minutes to soften any deposits...<br /> Turn the pot BACK ON and brew the remaining solution. When brew stops turn OFF coffee pot, empty the solution, and discard the paper filter...<br /> <br /> Refill reservoir with cold water and turn ON; you may want to dump this and refill with more cold water to ensure the vinegar taste/smell is gone...<br /> <br /> Now, wash the brew basket and the glass pot...Open the black skiny Water Filter and replace with a new charcoil filter...Put Filter back in pot...fill brew basket with coffee and brew some mighty fine tasting coffee!!! Hope this helps....Good Luck
Jun 29, 2010 | Coffee Makers & Espresso Machines
When i make coffee sometimes the water that comes out is cold or luke warm
The brewer has not had enough time to reach its operating temp (usually 7 mins after a brew cycle). If that is not hte case then the machine needs to be descaled.
Feb 18, 2010 | Bunn VPR Coffee Maker
I put in 12 cups of water and only 4 cups come out with coffee what is wrong with this. It is only one month old
This occurs occasionally if the unit needs cleaning or you are brewing a new pot of coffee immediately after emptying a hot pot of coffee.
Run a cup of vinegar through the coffee maker twice, run at least 2 pots of clean water through to rinse the vinegar out.
This should clear the problem until it needs cleaning. The suggested frequency of cleaning is every 30 pots, but this varies depending upon the type of water you use.
Nov 16, 2009 | Cuisinart Grind and Brew 10 Cup Coffee...
My kenmore 12 - cup coffeemaker, model # 80666 is beeping every few minutes. I hit the brew button but nothing happens
In the manual that came with the coffee maker, the beeping is the freshness alert. When coffee is finished brewing it beeps 5 times. Every 15 minutes it beeps to let you know your coffee is 15 minutes less fresh! I just purchased this coffee maker and was looking on here how to dis-assemble the beeper. Whomever came up with the "freshness beeper" on a coffee pot needs a new job! Usually when I make coffee the whole house is asleep, now the beeping is waking everyone up! Very frustrated with this coffee pot!
Nov 02, 2009 | Kenmore Coffee Makers & Espresso Machines
Do not know how to program fresh start oasis full button over fil
Remove the brew basket and water defuser (sprinkler head) it should come off with a 1\2 turn.
Place your measuring pitcher or empty pot in place.
Turn the main power switch off in back of unit.
Press and hold the Brew(full pot) button.
While holding the Brew(full pot) button turn the main power button in back to on.
Once the red light flashes over the Brew(full pot) button release it, then press it once to start the brew cycle.
Let it flow until desired level in pot or measuring pitcher.
Press the Brew(full pot) button once to Stop.
Press the Brew(full pot) button once again to lock the settings into memory. Memory will store the settings even if machine is unplugged.
Half pot button is automatically set.
Apr 09, 2009 | Oasis FreshStart 80 oz 10-Cup Coffee Maker
Coffee Makers & Espresso Machines Logo
91 people viewed this question
Top Coffee Makers & Espresso Machines Experts
Colin Stickland
Colin Stickland
Kolbrun...
Are you a Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
