Question about Dryers
I have a check cord error on my dryer after replacing the heating element. We also replaced the cord as well
    Master:
  • 604 Answers
Cord could be on wrong
Posted on Apr 19, 2017
catriver
  • 878 Answers
SOURCE: replacing the heating element Kenmore dryer 110 64892
nestor, on the posted model, you want to drop the lower front panel. Take a puddy knife and push in on the clips on each side and it will pull off. Kill the power to the dryer. On the right you will see the heater housing. The housing will have a front deflector. You can remove that deflector by removing the screw on the bottom or simply just bend it down out of the way. Remove the 2 wires on the left that attach to the element itself. On the left side of the housing there will be a quarter inch screw that holds the element in place. Use a small socket set to get it off. Now the element will pull right out of the housing. Sometimes they are difficult to pull out but it will come out. Did you ohm out that element to make sure that was the culprit? Catriver.
Posted on Dec 09, 2007
  • 1028 Answers
SOURCE: replacing Kenmore dryer parts
that one is old enough to vote..if filter on top remove back find small hole on right just below top may be hidden by pasted on tech sheet..through hole insert long socket 5/16 or reach up from underneath with short ratchet and socket remove screws and attached wires lift element housing up slightly and pull bottom of housing out and down..5/16 screw on backside holdes element in
Posted on Jun 19, 2008
AlmostBob
  • 550 Answers
SOURCE: Replacing Heater Element in Roper Dryer
before you replace the heater most common cause of heating failure is burn out of the thermal cut-out. (also called thermal fuse, overtemp cutout and probably half a dozen other names) These are a small screw on device on the exhaust duct, when exhaust air reaches too high a temperature, like a blockage, they fail before a fire.
examin the exhaust duct inside the dryer for devices that look like this 641e982.jpg or like this dd7fd44.jpg with wires connected to the terminals. there may be 2(hi lo), test with a ohmmeter -conductivity good, no conductivity replace.
there are only a few different kinds the local parts guy will have them all. take the dud one for him to match.
Posted on Aug 27, 2008
  • 1122 Answers
SOURCE: Cabrio Electric Dryer Heating Element
have you checked the high temp thermostat?
Posted on Sep 05, 2008
  • 188 Answers
SOURCE: dryer will not heat
Check to make sure you have 240V at the outlet. If you do, check the continuity of the element and thermostats. If still no heat, it could be the temperature setting switch, the timer or the motor.
Posted on Feb 21, 2009
Why do i have no heat on my dryer after cord was replaced after it caught on fire?
I would check the heating element for continuity. If you don't have a multimeter, you could buy a cheap one or borrow one maybe? I found a video on youtube in case you need to know how to do it. Good luck
Aug 06, 2014 | Admiral Dryers
Change a four prong cord to three prong cord, dryer heats, turns but does not dry, vents have been cleaned
test this steps and fix it. God bless you
1. No power to the dryer
Make sure there's power getting to the dryer. Check for tripped circuit breakers or blown fuses. An electric dryer uses two circuit breakers or fuses, and if only one of two is tripped or blown, the dryer might still run but not heat. Sometimes the power cord disconnects or burns at the dryer, if this is the case, the wiring and the terminal block must be repaired or replaced.
2. Heating element
A burned out heating element will show no continuity when measured with a meter. Replace the element if found defective.
3. Thermal fuse
Most dryers have a thermal fuse, which burns out when the dryer overheats, in which case the dryer will either not run at all or stop heating. The fuse is usually located on the vent duct, inside the dryer. A blown fuse will show no continuity when measured with a meter. Before replacing the fuse, make sure the blower wheel is not broken or clogged, and there is nothing blocking the venting.
Read more: http://www.appliancepartspros.com/repair-help/dryer-repair-help.html#2-2#ixzz2ab3IwDXf
Jul 31, 2013 | Frigidaire FEQ332E Electric Dryer
Kenmore stacked laundry unit. when it was plugged in sparks flew and small parts of the heating element fell and the power cord is ow black. can we replace cord and be ok
Heating element must be replacedas well as the cord. Make sure the drum screws were not screwed into anything electrical.
May 18, 2013 | Kenmore Dryers
We moved into our new home, we connected the washer and dryer, the dryer was working fine, our dryer is a whirlpool dryer and it electric, it a duet, the model number is GEW9260PW0 the dryer was working...
sounds like the element could have went out. if you cant take the dryer apart you should call a service co. always disconect the power before working on it.
Dec 23, 2010 | Whirlpool Dryers
MY ROPER DRYER QUIT HEATING STILLS WORKS NO HEAT
The thermal cut-off , which is the small t-stat looking piece located at the top of the element housing ( on vertical mount elements ) or the far front of the element housing ( on horizontal mount elements ) , is usually the cause for no heat .
Aug 02, 2010 | Roper REX4634KQ Electric Dryer
I'd like to know how to change a heating element in my dryer (29' whirlpool) I'd like to know exactly how to take it apart and where to find the element. I'am not sure of the dryer #
first you nead to unplug the dryer,next you nead to remove the vent hose,next you nead to remove the back panal and the power cord cover,on the left side you will see the heater housing,at the bottom you will see the heating element,there are four wires,the two at the bottom are hooked to the element,you nead to pull them off,the other two wires are hooked to the high limit switch,you nead to pull them off,next there are two 1/4"screws,one on each side off the heating element,remove them,now pull out on the bottom of element,with element removed,remove the high limit switch from old element and put it on the new element,take new element and put it back in the heater housing and replace the two 1/4" screws,you will see that the two wires that go to the element are biger than the two going to the high limit switch,put the two wires to the element,now replace the two wires to the high limit switch,replace the back panal and the power cord cover,replace the vent hose,plug power cord in and check element out.
Nov 25, 2009 | Whirlpool LER5636P Electric Dryer
No heat from dryer maytag atlantis mde7600ayw had heating element them fuse and thermostat checked ok check ciruit breaker turn on and off decided to replace fuse dyer still didn't heat check outlet...
most dryers have a thermal switch or breaker in the cavity somewhere, they can become worn over time and will stop heating, the item probably looks like a copper arm that touches a contact similar to a old morse code key by looks
Sep 18, 2009 | Maytag Atlantis MDE7400AY Electric Dryer
No heat in dryer model # 96591420
Check the following to address this issue.
2. Heating element
3. Thermal fuse
Jul 31, 2009 | Kenmore Dryers
Kenmore dryer makes no heat
replace the heating element. Or the control panel has weakening capacitor not sending correct current flow to the heating element
Jul 09, 2009 | Dryers
Dryer running but not heating. How do I check heating element?
Check the following to address this non heating issue
2. Heating element
3. Thermal fuse
Jun 02, 2009 | Whirlpool Dryers
Dryers Logo
26 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
