Question about Refrigerators
Norcold refrigerator model 2117 IM refrigerator will not run on AC only on gas
  • 51 Answers
SOURCE: norcold rv refrigerator freezer
Make sure the thermister is attached firmly to the fins in the back. The boards on a Norcold can be reset a service center familiar with this process is your best bet. It takes disconecting the board and then shorting it out best to leave it to some one who is familiar.
Posted on Sep 08, 2008
SOURCE: Norcold RV Refrigerator
My Norcold fridge just quit cooling. Still getting power and/or gas. ???
Posted on Oct 26, 2008
  • 15 Answers
SOURCE: my norcold frig(RV) freezes food in lower level
in your refridgerator there is an internal thermostat on the cooling fan u can move up or down it should be placed on the last finn to the right looking at the fridge
thanks
cruz
cruz's mobile rv repair
Posted on Jun 17, 2009
  • 15 Answers
SOURCE: norcold refrigerator burner will not stay lit
u need to replace the thermocuple or be sure its near the pilot also be sure to blow out any and all dust in that area
Posted on Jan 29, 2010
ebaypolenz
  • 101 Answers
SOURCE: i have a norcold refrigerator in my rv. it works
go to http://thetford.com/ and look up the manual for the device.
there is a black box that the power lead goes to and all the wires plug into. (on many models) label all the wires connected and gently remove them. there should also be a set of wires to a white plug going up to the ignitor. remove the two screws holding the black cover on and gently remove the cover. there are two or three fuses inside. Also get a good look at the circuit board for burned or damaged areas. Mine had three damaged parts and it was easier to replace the entire board. look for the model number of the board on it and do a google search for the best price. Dinosaur electronics may be a good source. Good Luck.
Posted on May 17, 2013
I have a Winni Minni with Norcold refrigerator 682. I have change board and element,but its not working on electric only on gas, prpblems ?? I live in Norway.
Sounds like your selector knob may net be making proper contact with electricity. You have changed everything else. You could check power available with a multimeter to your element. If power not available to your element, back trace to source and check for burned wires or breaks in wiring.
Hope this helps!
Apr 18, 2016 | Refrigerators
I shut down the fridge. Not getting any power to it now. I have checked breakers and fuses. There is power to 110 outlet where it plugs in. No power to gas valve. What do you think the problem is?
Your Norcold refrigerator is powered by 12V DC, not 110V AC. You need to check input power at the power board. If the fuses are good and you have good 12V to the refrigerator, check to see if you are getting 12V past the 5amp fuse on the board. If not, you may have a bad board. Norcold Power Circuit Boards for Sale The Norcold Guy
Jul 12, 2015 | Norcold Inc Norcold 1210IM Refrigerator
Norcold fridge in my motorhome
Norcold fridges are now part ofThetford one of the largest suppliers of mobile and marine products. You do not quote the model so not sure if a 3 way (gas/mains/12v) or AC/DC. The most common problem with all mobile fridges is the heater unit is faulty. Thetford have discontinued spares for a large range of norcold models. Information can be obtained on the Thetfold.com website.
Good Luck
Jul 09, 2014 | Refrigerators
We have a Norcold model N811FLT, it is connected to power, but is continuously running on gas. We've tried resetting it with no change. Could it be the power board or the control board?
you can reset the control board . to do this you must ground the # 15 terminal with a jumper wire to ground. this is usually the terminal next to the white & violet wire. check diagram.
Jul 07, 2014 | Thetford Norcold RV Cooler/Freezer
Model 12110 IM Norcold-not cooling on AC or Gas..no fault codes coming up
Hi, if the burner lights in the 'gas' mode, the control board is OK. You most likely have a leak in the sealed refrigerant system, and you need to have the leak located and repaired. This is a job for a RV refrigeration technician. If you need to find the nearest Norcold authorized service dealer, go to www.thetford.com, and use their dealer locator menu.
Apr 13, 2011 | Thetford RV Refrigerator - N300 Model -...
I have a Norcold 323 Refrigerator in a camper that will not cool when operating on AC but does work on gas, ( I cant test the DC as I dont have a 12 volt power sorce). After running in on gas for a while...
the unit runs on gas(LPG) so the unit is operational
by ac I take it you mean mains power and by dc you mean 12 volts it being a 3 way cooler
you cannot "jump start" a gas system so I am a bit lost with that statement
check the heating element in the unit for continuity as both the mains and 12 volt power only heat and element that boils of the coolant liquid in the system the same as the lpg flame does
it could be a relay problem for the electrical part
May 26, 2017 | Thetford Norcold N323 1.7-cu ft 3-way...
My norcold N841 will not cool on AC or Gas it has power and the gas will fire up
Most of the time if the unit has lost a/c gas and 12 volts which puts the unit into a defrost mode so there is a simple reset that can be preformed by unplugging the a/c cord from the back of the fridge and the 12 power going into the control box. leave them disconnected for about 15 mins and then reconnect them in the reverse order and check the inside frezzer at the back and fins on the rightside of the inside of the fridge to see if the unit gets cold
Sep 02, 2009 | Refrigerators
My Norcold Fridge will not operate on AC
Check you 110 volt breaker in the converter panel to see if it is tripped
Apr 03, 2009 | Thetford Norcold RV Cooler/Freezer
Refrigerators Logo
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
