Question about Dishwashers
Where can I get impeller for mastercraft pedistal sump pump model 062-3509-6
    Master:
  • 604 Answers
3 year warranty,https://www.wolseleyexpress.com/localassets/prodtec/7108000h.pdf
Posted on Apr 19, 2017
Impeller runs, no water comes out. Removed output hose, air is blowing out when removed from sump.
Remove bottom cover, check for clogged intake holes, and make sure the impeller is solidly attached to the shaft. Can you see the water in the sump? Is the sump full of sand at the bottom?
Jun 28, 2015 | Utilitech 1/2-HP Cast-Iron 83 GPM...
My Flotec Model FPSC3200H-01 1/2hp sump pump stopped working.The motor hums but impeller will not turn.
Well I know it a dirty job but someone has to did. Unhook the pump from the plumbing and take the pump out so you can see what fell into the sump pit and is lodged in the impellers.
If you have it out already turn the impiller backwords and see if that frees it up.
Feb 05, 2011 | Flotec Plumbing
The pump has gotten where it pumps a few seconds and stops ,I thought maybe it's low on oil
Most sump pumps are sealed so they have no way to add oil. I would see if your pump discharge line has a check valve installed in it.It should have a check valve installed so that waste can only flow away from pump.Otherwise the pump can cycle for a short period,shut off and have water in vertical pipe flow back into sump basin causing pump to cycle again. Also if your pump does have a check valve in it make sure that it doesn't have anything caught in it that would stop it from closing completely. Some pumps have a check valve installed on the pump. It is also possible that you may have something caught in the pump impeller. you will need to remove pump to inspect the impeller. Hope this helps you. Thanks
Nov 22, 2010 | Water ACE SUBMERSIBLE SUMP PUMP 1/3 HP
Pump runs but nothing is pumped out
I just had a tech over,have the same problem with my SHE45M. Was told the plastic impeller is spinning on shaft. New to replace the drain pump.
Oct 16, 2010 | Bosch 24 in. SGS43C12 Classixx...
How to troubleshoot toilet sump pump?
Unplug the sump pump. Bail out the sump pump to expose the pump's machinery.
Inspect the rod attached to the motor on the top of the sump pump. Move it up and down manually to see if it moves smoothly. Corrosion will keep the rod from moving smoothly. Clean the float road with steel wool.
Inspect the float ball. If it contains water, you need to replace it. Unscrew the float ball from the end of the float rod and screw on a replacement float ball.
Inspect your sump pump's check valve. It has an arrow on it. The arrow should be pointing away from the pump. If it's pointing towards the pump, remove and reinstall the check valve.
Locate the small weep hole between the check valve and the pump. Clean it out with a pipe cleaner.
Inspect the impeller, which is the fan-like piece that sits near the bottom of the pump's tank. If it is clogged by debris, then it will not turn properly. Unbolt the impeller and clean away any debris you find. Reinstall the impeller with new gaskets and sealant. Locate and replace the mesh filter in the sump pump, since only a damaged or missing filter would allow debris to get near the impeller.
Below is troubleshooting work, web link, through to assist you in that.
http://www.plumber-washingtondc.com/articles/sump-pump-troubleshooting
Jun 25, 2010 | Plumbing
I have a broken sump pump, Flotec model # FPOF360AC
Same pump, same problem. H/D sells the pumps, but no parts. Here's a link to a vendor of Flotec parts. http://www.pumpvendor.com/Flotec_Parts_List.html
Apr 01, 2010 | Flotec Simer/Flotec/Omni 2105 Swimming...
The water fills the tank but does not go out of the hose and drain to the sump pump as designed
Check the hose for clog up as well as your sump pump. Have your hose unclogged and let it run. Check the sump pump if this is running. And if it is, and still no water goes out. Open the sump, and check the impeller for defect. Impeller is the one that turns around to push the water out. If it is defective, you must replace it to make it run.
Once you are done, power it up and start it.
Sep 27, 2009 | Haier HDN655E Dehumidifier
LG LDF8812ST WONT DRAIN JUST INTERMITTENT BUZZ NOISE
Hi, there may be an obstruction in the pump housing that is causing the motor to freeze or, the impeller may be stripped and , jamming the pump. this will cause the hum you are hearing. the best way to inspect is to , extract the drain pump by, removing
the bottom drain filter housing or sump. manually
move the pump impeller to self it is moving freely. if the impeller is stripped, it will not be able to produce the draining surge necessary to pull the water out.
If the impeller is fine and, there are no obstructions visible, this will confirm pump failure.. replace the pump in this case
Some models have two impellers inside the pump - one, wash impeller, takes care of the wash cycles, the other, drain impeller, drains the water out. If the drain impeller is broken (broken blades, shaft), the dishwasher would not drain. Replace any broken pump components.
Jun 19, 2009 | LG LDF8812 Stainless Steel Built-in...
1/3 hp wayne pedistal sump stoped working
yes there are brushes,, but there is also a shaft that goes thru the tube make sure it is not broke or bent,, it happens,, suggest to get a zoeller submersable pump its the best cast iron, float is attached to the unit, will fit in small pits, only 1 plug needed,, cost for pump 100
Dec 31, 2008 | SPV Wayne Pumps Spv500 1/3hp Cast Iron...
Dishwashers Logo
42 people viewed this question
Top Dishwashers Experts
