Question about Filter Heating & Cooling
Which air filter should I buy for my nordyne model b5bm-x3orb, serial no. b5d070307341?
  • 1,799 Answers
Which ever air filter you want. Would not exceed a merv 10 rating. Too thick of a filter makes the fan motor work too hard to get air. Obviously the thinner the filter the more dust gets on the coil.
Posted on Apr 20, 2017
I need to know the wiring diagram for the thermostat, which is a 24 vac heat pump thermostat TA2000? HELP!!
What is the thermostat brand name? You can do a search in the Internet for the wiring diagram
Jan 20, 2016 | Gibson Nordyne/2 Ton Heat Pump Package...
What is the output for a Nordyne Model B5BM-X36K-B
http://gemaire.com/nordyne-b5bmx36kb-3-ton-13-seer-multipoise-air-handler-r410a-b5bmx36kb (via google search)
Looks to be about right. This is an older unit. Have you had it checked or serviced? I'd guess you have a freon leak and it will not work without the right amount of "blood". Or filter's havnt been chanded, or filters failed sometime and the coils are "clogged" especially if house had pets. Your careful inspection should revel those problems. If no problems and not been serviced recently call HVAC tech.
Mar 11, 2015 | Heating & Cooling
What year was this model made?
Your unit (B3BV-036K-BB) is a Westinghouse / Nordyne Unit.
Vertical Flow only, 36,000 BTU, 208/230 volts.
You cannot tell the manufacture date from a model number, only from the serial number. Try contacting manufacture with the serial number...
(nordyne.com)
Sep 13, 2014 | Frigidaire Heating & Cooling
Model #p3ra _030 nordyne h/c serial #p3d030200030
2.5 ton Nordyne unit. What is your question? Thanks!
Sep 01, 2014 | Heating & Cooling
We have a hvac Nordyne model P3RA-048K Everything
Hello
Either the filter is clogged and needs to be repaced.Or check the coil inside the unit and see if it is getting iced up.You can try shutting the unit down for an hour or raising the temp.If this helps the motor speed then you know the coil was iced up.
It is also possible the motor may be going bad,doubtfull though since they will run for a while then shut off.
Check your filter
Check for ice
Possibly clean the inside coil.
Jul 31, 2011 | Intertherm P3RA-048K Air Conditioner
Evaporator coil needs to be replace again. Installed w new manufactured home; 09/2005. Replaced 05/30/08. Needs to be replaced again 09/17/09. All due to leaks. Freon was added. Currently has small leak;...
the manufacture is only required to supply the part free of charge thru its warranty period. the installing company probably would only give a 1year labor warranty and honor the pparts thru the manufacture for 5 years but unless you paid additinal for an extended labor warranty i dont think you are going to have much luck. Make sure you change your air filters every 30 days a dirty filter is one of the biggest causes of evap coils prematurely leaking. Sorry wish i could be more help.
Sep 17, 2009 | Intertherm P3RA-042K Air Conditioner
Need Capacitor Size
try calling technical support of the company
Jun 04, 2009 | Intertherm P3RA-030K Air Conditioner
I think I have the wrong air filter in electric furnace
Measure the width and length, then buy a filter that size.1" is correct for thickness.
The arrow points into the return. Not into the room.
Feb 18, 2009 | Intertherm P3RA-048K Air Conditioner
Heating & Cooling Logo
50 people viewed this question
Top Filter Heating & Cooling Experts
MightyMikeJr
Vernon Taylor
Are you a Filter Heating and Cooling Expert? Answer questions, earn points and help others
