Question about Toshiba Satellite A15-S127 Notebook
All I receive is a blinking power light when I press the power button. This occurs whether I have it plugged in or try starting with just the battery. I get know sounds from anything, fan, hard drive, etc.
  • Ricky Stewart Jul 24, 2009
    The AC LED blinks 5 times, then 2, then 1 and keeps repeating that same pattern.
  • 689 Answers
Issue can be a mainboard lockup. Please perform full discharge/power cycle
- Unplug AC adapter and all other attachments (If any, such USB drive etc)
- Press and hold the power button about 7-10 seconds
- Put the AC adapter back and turn it on
If issue due to temporary circuit lockup unit will turn on
If issue persist please post more by indicated more symptoms, such as heat, pattern of the blinking light etc.
Good Luck
Posted on Jul 24, 2009
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. Blinking power light means that the issue your Toshiba Satellite A15-S127 is facing with is due to water/liquid damage. To resolve the issue you need to strip it and clean off the corrosion and it will be recovered for which you may use a toothbrush. If still the problem persists, then it is due to water damage to the motherboard down the middle over the CPU, chipset or any other component and these are required to be replaced.
The other issue may be due to some kind of memory problem (RAM problem). You should change the slot of the RAM and then try to start the note book. If it still doesn't work then as soon as your Notebook boots start pressing f-12 then reboot from last known good configuration. Please check it by connecting to some other note book.
You can also install a new copy of Operating System. Before that you should backup all the data by removing your hard disk from notebook and connecting into another.
Revert for further assistance.
Thanks
Rylee
Won't power on
Hold the power button down for about ten seconds and it'll actually turn off. Press the power button and see if it restarts.
Nov 03, 2015 | Computers & Internet
Canon mx320 printer error has occurred 5200
You need to reset the printer. Try the steps:
• Plug in the power cord of printer.
Press Resume button 2 seconds
then press the power button until the green light on (when pressing the power button,Resume button)
• Then release the resume button, but do not release the power button.
• While the power button is still pressed, press the Resume button 5 times. Led will light turns green orange with the last glow orange.
• Release both buttons simultaneously.
• Led will blink briefly and then will glow green.
• And the computer will detect new hardware, just ignore ...
• Press the power button again then the printer will flash and. Printer is ready for use.
Feb 06, 2013 | Canon PIXMA Office Equipment & Supplies
Error 2000_0333
When does this error occur?
When you plug in the power cord is there any lightswhatsoever on the laptop, where the plug goes in or on the AC Adapter of thepower cord?
When you press the power button do you hear fans running, hard drive spinning,lights on the computer, hear any beeps or lights constantly blinking, hear theDvD/CD drive click and the light on the drawer of the DvD/CD turn on for asecond or two? If so the laptop is trying to boot or may have booted, butthe screen is not showing for some reason.
Beep tones and blinking lights tells the technicians what is going on with thelaptop and why it is not booting. Most times it's a motherboard issuewhen you hear beeps or blinking lights continuous.
Maybe your power cord is bad if you don't get anything to happen whatsoeverwhen you press the power button. And if that's true maybe you wasoperating off the battery the last time you had it on and since the power cordis bad, it was not charging the battery so the battery is drained and the powercord is bad.
Maybe you have a Static Charge Buildup. Remove the Power Cord, Remove theBattery, then Press and Hold the power button for 30seconds. After 30 seconds plug the power cord back in (leave the batteryout) and hit the power button to see if it boots. If it does, you can putthe battery back in and let it charge.
Mar 30, 2012 | Dell Inspiron 15 Laptop
BLINKING POWER LIGHT WON"T RESET
A Blinking Power light on a wrt-54g usually indicates that the firmware is corrupt. You can try to wipe the firmware by following the steps below:
unplug the router
using a paper clip or pin, press the reset button
plug the router back in while the reset button is still pressed down and hold it for 30 seconds.
once you let go of the reset button the router should go through a reset. if it still blinks try the process again.
if the issue still occurs then it may be bricked.
May 27, 2011 | Linksys Wireless-G WRT54G Router
How to install
Plug in the reciever into the computer and make sure the mouse has fresh batteries. Once you are in Windows, press the link button on the receiver. The indicator light should start blinking. Then within two seconds press the link button on the bottom of the mouse, the indicator light should quit blinking. After re-linking the devices move the mouse to see if it moves the cursor. If the cursor does not move, then move the mouse and see if the indicator light on the receiver blinks. If the device does not blink then try re-linking the devices again.
Jan 18, 2011 | GE 97985 Mouse
I have dish network and a new rca tv with dvd the
You can power scan for the code.
Turn ON the electronic device you want to program the remote to control.
Press the Mode button( sat,tv,dvd,aux) on the remote until the appropriate mode light is flashing.
Press the Power button. The mode light will stop flashing and stay lit.
Press the Up or Down arrow button to set the remote to the next code. The Down arrow button scans backward and the Up arrow button scans forward.
When the correct code is reached, the device (whether a TV, VCR, or other) will turn off.
Press the pound key button to store the code in the remote control memory. If the code is valid for your remote, the mode light will blink 3 times.
Turn the device back ON by pressing the Power button.
Press sat mode key once you power back on the tv to be able to operate the receiver box.
Try some other functions to make sure you have the correct code. Occasionally the Power button may work when others do not.
If the other buttons work you are finished.
If the other buttons do not work, repeat the previous steps. The scan will resume from the last code stored.
The mode light will flash rapidly when the scan has returned to the starting point and all codes have been tested for that mode. The remote control may not control some device models.
Mar 11, 2010 | DISH Network 322 DTV Receiver
Can I do something myself when this shows up? Error Number : 1700 The waste ink absorber is almost full. Press the printer's RESUME button to restart the printer. An error may occur if you continue to use...
Try to do this:
1) Close the print head cover, and turn off the printer. While pressing the Resume/Cancel button, press the Power button. (Do not release the buttons. The LED lights in green to indicate that a function is selectable.)
2) While holding the Power button, release the Resume/Cancel button. (Do not release the Power button.)
3) While holding the Power button, press the Resume/Cancel button three times, and then release the Power and Resume/Cancel buttons. (Each time the Resume/Cancel button is pressed, the LED lights alternately in either orange or green, starting with orange.) During initialization, the LED blinks in green.
4) When the LED stops blinking and lights in green, press the Resume/Cancel button the 4 times. (Each time the Resume/Cancel button is pressed, the LED lights alternately in either orange or green, starting with orange.)
5) Press the Power button. The LED lights in green, and the
selected function is performed. (When the operation completes, the printer returns to the menu selection mode automatically.)
6) Power off then back on and test.
Oct 07, 2009 | Canon i80 InkJet Printer
Optical light on Mouse not working
maybe the battery?
follow the steps below to troubleshoot the mouse
Wireless mouse does not respond (generic instructions)
Try to Resynchronize your device with the receiver(connector)
Follow these steps.:
Note When you synchronize the mouse or the keyboard with the receiver, put the device near the receiver and put other wireless keyboards and mouse at least 6 feet away.
1. Press the button on the receiver, and then verify that the light on the receiver starts to blink.
2. If a dialog box appears on the screen in several seconds, follow the instructions that appear on the screen. Otherwise, go to the next step.
2. Press and release the Connect Channel button on the bottom of the mouse or the keyboard.
3. Check the green light on the receiver. A steady green light means the synchronization was successful. If the problem persists, try steps 1 through 3 again.
For the Wireless Notebook mouse: This issue can occur if the micro-switch on the bottom of the mouse is not released. Use a pin or a pen to try to release the button if it is depressed.
or
Try different port and restart your computer.
or
Reinsert the batteries or install fresh batteries
If you have the possibility check whether the problem is because of your computer or the device, try the mouse or the keyboard on a different computer.
Sep 06, 2009 | Microsoft Wireless Notebook Optical Mouse...
Akai hdtv 1080i no picture
Those blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
http://homenol.blogspot.com/
If blinks continue without any pause, the main board is faulty.
Sep 02, 2017 | Akai PTH5498 54" Rear Projection...
Toshiba Satellite A15-S127 Notebook Logo
143 people viewed this question
Top Toshiba Computers & Internet Experts
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
