Question about The Office Equipment & Supplies
The cover on my fx1218 will not close. The pin is broken. How can I get a replacement
I have a FX1218 and I can't get the lid off to replace the battery
This appears to be a smoke detector, not a camera
Mar 08, 2017 | Cameras
Dtergent dispencer does not open
Dispenser Lever
If the dispenser is broken and doesn't open or close properly the dispenser lever might need to be replaced.
Detergent Dispenser Cover
If the detergent dispenser cover is broken and the detergent dispenser doesn't work, the dispenser assembly should be replaced.
Wax Motor Actuator
If the dispenser will not release the detergent the actuator connected between the wax motor and the dispenser might be broken. Check the wax motor actuator and replace it if necessary.
Detergent Container
If the dishwasher dispenser doesn't work the detergent container may need to be replaced.
Dispenser Lid
If the dispenser is broken and doesn't open or close properly the dispenser lid may have to be replaced.
Detergent Dispenser
If the dishwasher dispenser doesn't work the problem is often related to the release mechanism. If the problem is with the dispenser itself, it may be easier to replace the entire dispenser.
Dispenser Door Spring
If the dispenser is broken and doesn't open during the wash cycle the dispenser door spring may have to be replaced.
Dispenser Latch
If the dispenser is broken and doesn't open or close properly the dispenser door latch may have to be replaced.
Dispenser Door Pin
If the dispenser is broken and doesn't open or close properly the dispenser door pin may have to be replaced.
Enter your model number to see parts for your dishwasher.
Dispenser Actuator
If the dispenser is broken and doesn't open or close properly the dispenser actuator may have to be replaced.
Dispenser
If the dispenser is broken and doesn't open or close properly the entire dispenser assembly may have to be replaced.
Wax Motor
There is an electrically powered device called a wax motor which opens the detergent dispenser. If the dispenser is broken and will not open to release the detergent, the wax motor might need to be replaced.
Bi-Metal
If the dishwasher dispenser doesn't work the bi-metal actuator might be burned out or defective. The bi-metal is a simple metal loop which acts as a latch for the dispenser door. As electricity is applied to the metal loop, the loop deforms and bends away from the latch, releasing it. If the bi-metal is burned out it won't deform or release the detergent door.
Dispenser Slide
If the dispenser is broken and doesn't open or close properly the dispenser slide may need to be replaced.
Dispenser Repair Kit
If the dispenser is broken this dispenser kit may need to be replaced.
Main Control Board
The main control board provides power to nearly every component of the dishwasher including the detergent dispenser. If the dispenser will not actuate the main control board might be defective. You should first check for more common parts. Many times control boards are replaced unnecessarily because the problem was not diagnosed properly.
God bless you . see the photo attached.401f2962-5d22-48f3-89be-c1db11d8eabe.jpg
May 23, 2013 | Hotpoint-Ariston FDD914 24 in. Built-in...
Troubleshooting
Dispenser Lever
Wax Motor Actuator
Dispenser Lid
Detergent Dispenser
Dispenser Latch
Dispenser Door Pin
Dispenser Actuator
Dispenser
Wax Motor
Bi-Metal
Dispenser Slide
Main Control Board
Gd bless you
How to remove battery from an old firex fx1218 smoke detector
I agree that removing the battery can be a pain.
As you look up at the FX1218, turn the smoke detector a few degrees counterclockwise.
The detector should fall from the ceiling and hang by a few wires.
Those wires are connected to a plastic connector. It's the plastic connector that has to be squeezed using pliers. I prefer slip-joint pliers (see picture).
remove-battery-from-old-firex-fx1218-pakrl1cso4l3msuzip5hmw52-1-0.png On the plastic connector you will see two plastic "arms". Squeeze the arms and the plastic connector and cover plate to which it is attached will come out of the detector exposing the battery. Be prepared for the detector to screech.
Replace the battery.
Reattach the connector/plate. It is keyed so it only goes in one way. Be careful no to bend the interior male pins into the female plastic connector.
Apr 24, 2012 | Home Security
Canon machine message front cover is close but
there are switch behind the front door that are activated by the front cover. you may have a broken or missing actruator pin on the front door. look very carefully on the door for anything that seems to be missing. if ther is just use a piece of paper to actuate the switch. jaime
Jul 15, 2010 | Canon imageRUNNER 400S Copier
Drain in the close position the drain handle is not working
Remove the 2 screws on the drain cover in the bath tub to gain access. Drain plug should be connected to trip lever on drain cover probably using a cotter pin with ends bent to keep it on. Do not yet remove the cotter pin.
To know for sure if it is the trip lever broken, you can hold the trip lever down and tub will drain. If you let go, trip lever on cover returns to upright position and stops draining. You can also feel the spring tension stay on it when you press the trip lever down. Most likely, the drain trip lever (spring action) which is a part of the cover itself is broken.
First have ice pick, thin screwdriver, (even a large paper clip (or 2 for strength) bent straight may do) or anything small enough to go through same hole in drain assembly as cotter pin, while long enough to go across hole in bathtub to hold drain assembly up till you install new drain cover attaching it to assembly with same or new cotter pin.
Now unbend the cotter pin (sort of looks like a heavy duty metal bobby pin) ends using pliers. Using pliers pull cotter pin out while holding drain assembly so it will not fall back into tub wall.
Next secure assembly using the above ice pick or large paper clip while you take trip lever (which is the cover)
to hardware store, etc. to pick up generic tub trip lever.
CHANCES ARE THE ABOVE SOLVED PROBLEM, BUT IN CASE IT WAS NOT THE TRIP LEVER WHEN YOU TESTED USING THE METHOD ABOVE TO DIAGNOSE THEN BELOW IS HOW TO REMOVE ENTIRE TUB DRAIN ASSEMBLY
There is a metal stem with a threaded rod coming up in it with a nut on it, and on the end of this is a round metal weight looking much like a very small upside down can. you will not be able to see all this unless it is neccesary to remove entire drain assembly which you can then take it to a Home Depot or Lowes type store to replace. Most can be replaced with a generic tub drain.
Now to get the assembly out once you've removed the 2 screws gently work metal stem assembly up and out at a slight angle. You may have to move nut on assembly to shorten the length in order to get it to clear the tub. IMPORTANT! If so, 1st mark the position of the nut on the threaded rod so you can put it back in same position when reinstalled before lowering assembly all the way back into tub wall.
Apr 17, 2010 | Home
Broken orange battery tab
Contact Pentax and see if they will send you the part, for the tab + S/H it should cost you approximately $25, although I have recently heard they will not provide these items to customers anymore. If they're no longer providing replacements, your device will need to be sent to them for repair (approximately $70 incl labour).
Or... Get a piece of tape and place it over the battery and close the casing, other "ghetto rig solutions" include folding a piece of paper, placing it atop the battery (between the battery and the closing cover) and closing the flap, the paper will hold the battery against the pins and allow function.
Dec 08, 2009 | Pentax Optio T10 Digital Camera
Coffee maker
The beeping is typically caused by the grinder safety interlock. There is a small pin on the clear grinder cover that needs to be in place so that it is depressed into the safety switch when the cover is closed. The interlock switch prevents the grinder from working when the cover is open. Check to be sure that the pin in the grinder cover is not broken.
Dec 29, 2008 | Cuisinart DGB-500 Coffee Maker
I have a Lexmark 3480. Although the lid is closed it tells me that it is open. Can you help me on this please. Many thanks Roberta
You have probably broken off a small pin on the back of the cover that you open when you are to change the ink cartridge. Had the same problem my selv. This pin touches, when cover closed a small button that gives the printer a signal that the cover is closed. Solved this with putting something on that button, and taped it so it wouldnt go away.
(please excuse my not to good english)
Nov 07, 2008 | Lexmark Office Equipment & Supplies
The Error says "Cover Open Front" but it is not open
Most printers have a plastic pin on all of the covers that pushes a switch when it is closed. This then sends a signal to the printer telling it "I'm closed".
Probably the pin is broken off (quite by accident I'm sure). A solution is to push a piece of paper in the hole where the pin is, closing the switch, to fool the printer into thinking that the cover is closed. You can try this by pushing a pen point into the hole to see if the message goes out. (Don't forget to remove the paper when you open the cover. The switch is there to keep things out of the mechanism while it is running. May not hurt you but will damage the printer mechanics irreparably.)
Anything else is an error with the printer software and processor and can't be fixed easily.
Sep 02, 2008 | Konica Minolta Magicolor 2530 DL Laser...
12 people viewed this question
Top The Office Equipment & Supplies Experts
Gareth Cockram
Gareth Cockram
Tygh Duval
Tygh Duval
Jerry Greenberg
Jerry Greenberg
Are you a The Office Equipment and Supply Expert? Answer questions, earn points and help others
