Question about Poulan Garden
My pp4620avhd poulan PRI chainsaw has hard compression, with the carb and muffler removed it is still hard, with the spark plug removed it is easy. What could be the problem?
  • Greg Gibson
    Greg Gibson Apr 20, 2017
    The compression is so hard I can barely pull the rope
  • richie46 Apr 20, 2017
    Some of those units can be a bear to start because of the high effort involved in pulling the starter. That is why some of the units have a somewhat compression release to make it easier to pull and start. I keep hurting my back when I use my power gear and it is getting to the point where I might have to have others do the pulling for me!!!!!!
    Top Expert:
  • Poulan Master
  • 12,962 Answers
Unless unit has some sort of compression release for easier starting, it is something that you will just have to live with.
Due to the high compression, it should have plenty of power after starting
Posted on Apr 19, 2017
  • 45 Answers
SOURCE: Husqvarna Chain Saw Rope Pulls Very Hard, what is the cause?????????
Has it always done this or has it developed?
Some saws have a decompression button to make it easier to pull over.
Posted on Oct 07, 2008
  • 97 Answers
SOURCE: Chainsaw will not start
Remove muffler and check for carbon blockage.
If that is ok check crankshaft seals for leakage.
Posted on Mar 14, 2009
  • 226 Answers
SOURCE: can,t hardley pull starter cord. I've removed
What i have to occasionally do for a chain saw after it sits all winter is to put something like WD40 in the spark plug hole and crank it over several times. What happens to me is that the piston gets gunked up from the gas that ran down into it during the winter and it won't crank over hardly at all. This is probably your problem. I have also found that if i store my saws with the tank down, the gas cant get into the carb and do this. (Although it's better to drain tank).
If this has been a running saw instead of a stored one, you probably need a rebuild kit if the piston is scored.
Posted on Apr 15, 2009
llbigcat2000
SOURCE: Won't start. Has compression. backfiring through
On many riding mowers there are two wires that at the bottom of the carb bowl, these wires go to a solenoid which closes a valve so gas will shut-off when the start key is turned off. When this solenoid is bad it will not close which let gas keep going to the carb so the eng will bang through the carb or muffer. Hope that this will Help. Hugh Lyon
Posted on Aug 02, 2009
dontbother10
  • 2220 Answers
SOURCE: poulan 34cc chainsaw. wont start. replaced
Set the gap as Drallim suggests then follow this to test the ignition system, the entire system.
Ignition Coil Test by SmallEng.com
http://www.youtube.com/watch?v=L7WNBDRG4C4
You may need to use a jumper wire between the threaded part of the plug and the cooling fins. You do not have to bend up the electrode. HTH
Lou
Posted on Feb 24, 2010
Poulan 40cc 18". Not starting. Muffler full of liquid (gas?). Very hard to pull with plug installed, easy with it removed. New plug, good spark.
You might have a hydraulic lock in the engine if you squirted too much fuel in the engine while trying to start it. take the plug out, hold the throttle wide open and pull starter rope 5-6 times to clear it. Put plug back in and try to start it.
Feb 21, 2015 | Poulan Garden
How do you remove a clutch drum on Poulan Pro PP4620AVHD chain saw
YouTube can be a great help with video's of 'how to' do things.
I have attached a video from 'donnyboy73.' I found his video's to be very informative and well put together. The video link is not of your exact saw but is a Poulan and I hope will be helpful to you.
HOW TO Remove Clutch & Sprocket on Poulan 2150 Chainsaw. The same procedure can be applied to many other chainsaws.
http://www.youtube.com/watch?v=zf28-ztoHfg
Oct 17, 2014 | Poulan Garden
Poulan 38cc wont start
quick check would be to pull muffler from engine check the screen if the screen is ok start engine if it starts without the muffler the muffler needs to be replaced.if it still dont start do pressure and vaccum checks on carb.
Jan 28, 2013 | Poulan Garden
Poulan 2150 saw will not start.
Many saws today have a alluminium key moulded into the flywheel, if the key has sheared the timing will be out and it will never start, remove the flywheel and check the key.
Jun 05, 2012 | Poulan Garden
Can't get it started after new spark plug (gets spark), new gas, good compression tried starting fluid. Whats the problem?
Quick way to check condition of the engine is to remove the muffler. Also make sure that the spark arrest screen is clean. With muffler off, examine the condition of the piston and cylinder. If the piston looks burned and cylinder is scratched, saw will be hard to start. The cylinder and piston should look very smooth. Secondary test to verify condition of engine is to spray plenty of wd40 in cylinder and around piston, then pull the starter slowly. If you see lots of bubbles as you pull, indicates compression is leaking and will be hard to start. If cylinder/piston are in good condition, use new spark plug and retest.
Oct 18, 2011 | Poulan Wild Thing 2375 18" Gas Chain Saw...
I have a poulan pp3816 pro 38cc that leaks gas out the muffler
Its either well flooded, or the carb needle is leaking, remove the spark plug, with the ignition switch off crank the engine to evacuate any fuel left in the cylinder, leave the machine for a couple of hours, re fit the plug and try to start useing no choke, if it still does not start, remove the spark plug again, rest it on top of the cylinder ( away from the spark plug hole ) crank the engine and check for a spark, if it has a good spark and the plug is soaked with fuel it could be a carb needle leaking, remove the carb, remove the metering cover held with four screws, replace the rubber tipped needle.
Jun 21, 2011 | Poulan Pro 16-Inch 38 cc Anti-Vibration...
I have a poulan 2150, won't stay running, why?
Fuel starvation - 'lean fuel' condition
Basic things to check:
1) spark plug
2) spark arrestor in muffler
3) fuel lines and tank filter
4) turn adjustment needles out (counterclockwise) 1/4 to 1/2 turn
Chain Saws:
5) check impulse tube and intake boot for cracks or leaks
*if all of the above are OK and/or do not improve performance then:
Remove Carburetor
6) replace gaskets/diaphragms
a) use a spray carb cleaner to clean jets, holes, and body of carb
b) fuel pump diaphragm goes against the carb body,
then the gasket towards the outside
c) metering gasket goes against the carb body,
and the diaphragm goes towards the outside
No-start
Basics to check:
1) Spark plug - brown or dark brown - OK
a) is it carbon or fuel fouled (black and carbon deposits)
b) is there spark
2) Muffler remove for inspection
a) exhaust screen clean or plugged
b) inspect cylinder wall/piston as the flywheel is slowly rotated
3) Check cylinder compression
Nov 13, 2009 | Poulan Garden
Can,t hardley pull starter cord. I've removed muffler and carb. It will pull fine if the spark plug is removed (w/or with carb and or muffler . this is a poulan pro 18"
Apr 14, 2009 | Poulan Pro Chain Saw 46cc 20"
Mar 14, 2009 | Poulan Garden
Garden Logo
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
