Question about Tablets & eReaders
Can I get a replacement battery for my RCT6103W46 android?
My tablet went out and I have not had it a year.It will not come on.
If it's still on warranty, return it to the shop where you bought it for service.
Maybe it's just the battery? Get it checked but if not on warranty, I'm afraid that to repair it might cost you more then it's value. You can buy this tablet for about 50$ so you should ask how much might cost to repair it.
Aug 13, 2015 | RCA CA 7" Tablet with 4GB eory 28458515
Why cant i update or upgrade my rct6103w46 rca tablet
make sure the account you are using is good, check settings on your tablet. check storage if you got room, delete your store and load up again, last reset it or after back up factory reset it. Good luck
Jul 03, 2015 | Tablets & eReaders
My RCA tablet model#RCT6293w23 locked out of tablet due to a virus/scam cannot access anything on tablet how do Ifactory reset when I can't use the settings or access any part of the tablet
You must then do a factory reset using the Power and Volume
Here is a good link that tells and shows how to do it:
The model number is not the same but it should work anyhow.
There is a typo in Step 1, however so do this instead:
With the tablet turned OFF (not sleep but OFF) press and hold down at the same time both the Volume(-) button and the Power button. Continue to hold both of them down until you get a screen with the Android Robot, and or green text. That should set you up to follow the instructions.
Good luck.
Jun 02, 2015 | Tablets & eReaders
Sceern locked up, battery life full. cannot shut off as well.
try holding down JUST the power button for 120 seconds may soft reset then
Jan 01, 2015 | Tablets & eReaders
Change battery in irulu 10.0 tablet
Hello Sonny,
These tablets have a "life long" battery, meaning that it is not user replacable... Looks like it is time to get a new tablet.
Best regards,
Oct 24, 2014 | Irulu 10.1 inch Android 4.0 Touchscreen...
Tablets & eReaders Logo
96 people viewed this question
Top Tablets & eReaders Experts
Are you a Tablet and eReader Expert? Answer questions, earn points and help others
