Question about Drills
What do the xifferent lightsmean on the battery charger. The light is flashing red off and on.
  • Drills Master
  • 16,982 Answers
Since you did not post the make and model, I am going to say that the light means the battery is bad, this is the case with most other chargers.
Posted on Apr 19, 2017
What does flashing red lights on the charger mean
Red lights on the charger means it is still charging.
Jun 28, 2014 | Parrot AR.Drone 2.0
Red light flashing on charger
A red light indicates the charger is charging the battery, an amber light means it has switched from fast rate charging to trickle to keep the battery topped off, and green would mean the battery is completely charged. But don't be fooled waiting for green, many times the charger will only be on green for a moment before changing to amber and keeping the battery topped off.
Flashing can be a sign of a problem on some chargers.
A rapid flashing red can on some chargers indicate a bad or shorted battery, or a bad battery contact in the charger itself. If in question, try a different battery on the charger or compare with another charger to determine if the blinking is normal.
Best regards.
Nov 19, 2013 | Motorola htn9042a charger,120v,single unit
Red blinking light
Hi, Ephraim. The flashing red light indicates that the device is showing "low battery". It could be that the LG phone charger fits the charging port on your bluetooth headset but it is not compatible with your device. In order for you to know that it is charging, the device should show a steady red light(means charging).
Please take a look at the table reference below.
•With the Charger Plugged In
______________________________________________________________________
•Headset Indicator Headset Status
Red-----------------------------------------------Charging (battery level less than 50% charge)
Yellow-------------------------------------------Charging (battery level more than 50% charge)
Green--------------------------------------------Charging complete
With No Charger Plugged In
Off ---------------------------------------------Power off
Three blue flashes------------------------Powering on/off
Steady blue --------------------------------Pairing/connect mode
Rapid blue/purple flashes -------------Connection successful
Quick blue flash --------------------------Incoming/outgoing call
Slow blue pulse --------------------------Connected (on a call)
Slow blue flash ---------------------------Standby (not on a call)
Slow red flash ----------------------------Idle (not connected to phone)
Slow purple pulse -----------------------Connected call muted
Steady red ---------------------------------Attempting to connect
Quick red flash ----------------------------Low battery
Note: After 20 minutes on a call or of inactivity, the light stops flashing to conserve power, but the headset remains on
Hope that'll help you in some way.
**Please rate my post and/or leave a comment** ...Thanks...
Sep 25, 2013 | Motorola Mobility H560 Bluetooth Headset
How do I know when an EN-EL! for the Nikon Coolpix 5000 is fully charged? what do the following conditions indicate? 1. Charger red light flashing 2. charger red light steady 3. charger red light...
Charger flashing red indicates the battery is still not full and is in the process of recharging.
Red light steady indicates your battery is fully charged and ready to operate with your Coolpix 5000.
When red light is off it indicates there is no battery inserted or the charger is not pluged in.
Mar 26, 2011 | Nikon EN-EL1 Battery + Charger...
What does the flashing red light mean?!?
The flashing red probably means that the charger is working correctly and is indeed charging the batteries. The light should turn green when charging is complete after anything from 1 to 16 hours depending on how this charger works.
Do the following test: Fit the charger with your batteries and connect it to the mains. After 1 hour check if there is a detectable temperature rise in the batteries. You can do this without interrupting the charge cycle by touching the cells with the back of your fingers. If the temperature is still low, let it continue for another 15 hours or so, checking every now & then for any temperature increase. Should the temperature rise more than a few degrees, then stop the charging by removing the charger from the mains. Should the red lamp remain flashing after 16 hours, then I suspect you to have a defective charger.
Dec 27, 2010 | Duracell AAA NiMH Battery Charger with 4...
My charger is flashing red when i place the battery in it
Ridgid charger lights read as follows: Solid red; charger has power. Flashing red; charger is evaluating the battery, checking if it's cool enough to charge and if it is in chargeable condition. If the battery is hot, i.e. just came off the tool after extended use, it won't charge the battery until it cools down. Flashing red & green; the battery is defective and the charger will not charge it. Solid red & flashing green; battery is charging. Solid green; battery is full.
Dec 07, 2010 | Ridgid Drills
12v 1.5amp fully auto, alwyas worked, hook up to battery 12v 8.5amph, alwys red light flashed, went solid while charging, then off, or flashed, and off cause was already fully charged. now red light just...
I really don't have any idea as to what you're talking about here other than a battery and maybe a charger. Seems as if you're saying that you have a 12 volt 1.5 amp automatic battery charger connected to a 12 volt, 8.5amph battery but the red light on your charger is blinking. The blinking red light indicates that the charger is not seeing a proper connection such as crossed polarity connection or simply a poor connection. You say that the battery voltage has dropped from 12.5 volts to 9.1 volts with the charger connected. If this is the case, the battery is badly discharged and the charger is not charging the battery for some reason. The charger may be bad but check the connections to make certain they are correct and good. If they are, I'd replace the charger.
Good luck
Steve
Aug 10, 2010 | Harley Davidson FXR Super Glide...
My Duracell battery charger has a blinking red light.Use to be a constant red then green when it was charged. Now, just red..then blinking red..then not at all.
I had the same problem with flashing red lights. Both sides on a four battery charger. I swapped the batteries to another charger and the batteries were fine. They charged normally. I put some different batteries in the charger and the same flashing light situation. Those batteries also charged normally in a different charger. I looked closely at the back of the charger and, low and behold, "made in China". Why does that not surprise me. The bottom line, it may not be a battery issue.
May 08, 2010 | Duracell NiMH AA/AAA Battery Charger with...
Battery charger flashing red light
Clean contact points of both battery and charger with q-tips dipped in rubbing alcohol. This solved my problem with blinking lights and not charging of the batteries.
Nov 03, 2008 | Olympus Stylus 710 Digital Camera
Drills Logo
73 people viewed this question
Top Drills Experts
Are you a Drill Expert? Answer questions, earn points and help others
