Question about Cuisinart Food Mixers
Hi I need board for Cuisinart stand mixer please let me know where I buy.thank you
hslincoln
  • 235 Answers
SOURCE: does stand mixer work in india ?
Hi VARSHA0803 - You would think that KA would make a 220-240v mixer for overseas sales, but I do not know if they do. You can contact KA Customer service directly on their website at: http://www.kitchenaid.com/flash.cmd?/#/page/customer-service/ Check the "Contact Us" box which provides you a toll-free phone number, or if you scroll down you'll find a 'Live Chat' link, where you can 'chat' online with a KA assistant who should be able to answer your questions.
I hope this helps. Good Luck! Howard from Burke, VA
If this solution has helped you, please rate it, thanks! - hslincoln
Posted on Nov 30, 2009
  • 857 Answers
SOURCE: Sir, I am the owner of a Cuisinart SM-70BC 7-Quart
Follow these steps to find out the problem else call Cuisinart { 1-800-726-0190 } for help :
•1
Remove the back cover by removing the small Phillips screw at the top of the back cover.
•2
Place a rag or cloth over the spring to keep it from moving.
•3
Plug in the mixer.
•4
Move the switch lever to "Stir." This may or may not start the motor.
•5
Turn the two adjusting screws counterclockwise evenly until the planetary turns approximately 60 times per minute.
•6
Test the planetary by holding a right hand finger lightly across the beater shaft. Count how many times the shaft touches the finger in 15 seconds.
•7
Turn the two adjusting screws until the shaft brushes the finger 15 times in 15 seconds.
•8
Lock the two lock nuts using an 11/32" wrench. Check the speed again.
•9
Make further adjustments, if necessary, without loosening the lock nuts on the control board. Unscrew the two adjusting screws.
•10
Move the planetary to speed 6. At this speed, the planetary should turn 180 times per minute. Check speed as you did for the first speed. The planetary will brush your finger 15 times in 5 seconds if the speed is correct.
•11
Turn the adjustment screw at the bottom of the control plate if the speed is less than 15 times in 5 seconds.
•12
Check the revolutions again. Keep adjusting the screw at the bottom until the correct speed is reached. You don't need to lock down this screw.
•13
Test all speeds from "Stir" to #10. If "Stir" and #6 speeds are properly adjusted, the other speeds should be correct automatically. If you notice a definite change in speed between #8 and #10, you have adjusted the mixer speeds correctly.
•14
Replace the back cover and screw in the back cover screw.
Posted on Sep 25, 2010
bbl242003
  • 1637 Answers
SOURCE: Hi and .. HELP! I am an American Soldier
CCONTACT THE SAME MANUFACTURER again, inform them of your military status and they will make an exception regarding fees, shipping, etc. To replace the board in these is going to cost a lot moer than having the factory replace the unit. From one military member to another, you stand to spend a large amount of money fixing this item yourself.
Posted on Jan 26, 2011
  • 10 Answers
SOURCE: my cuisinart 5.5 stand mixer
Make sure the plug is securely plugged into the wall.
Next, remove and reattach any mixing arms etc that may be attached to the mixer. Having one not attached properly can result in a start, start.
If problem persistes make sure the speed is reset.
If problem continues, here is an excerpt from the user manual found here.
http://www.cuisinart.com/share/pdf/manuals/sm-55.pdf
Problem: Your stand mixer has an
overload protection device and if
overloaded, it will shut down to protect
the motor.
Solution: In the unlikely even that this
happens:
• Turn off and unplug the unit.
• Reduce the load by removing some of
the ingredients, and allow the mixer to
stand for a few minutes.
Plug in and reset the speed. If the
stand mixer does not start when you
press the on button, allow the unit to
stand for additional time.
If you are still having trouble, the product comes with a 3 year limited warranty, so if you're bought it within the last 3 years it may be covered.
Good Luck!
Posted on Mar 01, 2011
  • 5 Answers
SOURCE: Capacitor value needed for KitchenAid stand mixer 3-C
had the same problem with mine, and couldn't read the values, so took one out of another mixer that was good. the tested value on the good one was around 107 nano farads. run your mixer without the cap for a short time only, to see if the speed problem is corrected. If slow speeds will work, then you know it to be the capacitor. Do not leave out for long period of time, you will burn out contacts and poss. outher components
Ken
Posted on Oct 27, 2011
How can i fix this problem
PDF]SM-70 INSTRUCTION BOOKLET 7.0 Quart Stand ... - Cuisinart
https://www.cuisinart.com/share/pdf/manuals/sm-70.pdf
Cuisinart7. Do not exceed the maximum capacities listed in this use and care instruction book. 8. ... Troubleshooting . ... extra-large Cuisinart™ 7 Quart Stand Mixer.
Jul 30, 2015 | Cuisinart 7 Quart Stand Mixer
How to add oil to cuisinart SM-55 stand mixer
The owners manual is available on the website. It doesn't mention anything about adding oil. What makes you think it needs oil. Mixer gears are usually lubricated with white grease and are maintenance free.
Nov 23, 2013 | Food Mixers
I need a replacement motor on a KitchenAid Professional HD Stand Mixer (Model KG25H7XSL).
The loud pop was probably the soft start circuit board on the motor. You can buy this board at repair sites or Ebay. And yes, they make 220V versions of this mixer.
http://www.samstores.com/product-kitchenaid-5ksm5ebu-heavy-duty-mixer-for-220-volts-%28cobalt-blue%29-16220.html
Dec 31, 2012 | KitchenAid Food Mixers
Cuisinart SM55 circuit board replacement or wiring chart.
I have a Cuisinart 5.5 quart stand mixer. but its count down model does't work. it move as fold model when I push on button. I guess the circuit board was broken. Is my guess right? Where can I buy the Cuisinart SM55 circuit board and how to replace it?
Jul 23, 2012 | Food Mixers
My cuisinart 5.5 stand mixer when you press the on button it starts for a second then it stops.
the motor.
happens:
Good Luck!
Mar 01, 2011 | Cuisinart SM-55 Stand Mixer
Food Mixers Logo
61 people viewed this question
Top Cuisinart Food Mixers Experts
Ross Keen
john h
Are you a Cuisinart Food Mixer Expert? Answer questions, earn points and help others
